Hubitat Elevation platform update 1.1.3 is now available:
Please note, the update process takes about a minute to download (depending on your Internet connection) and extract the hub update, and 1-2 minutes to perform the update after you click 'Update Hub'. We recommend that you periodically download a backup of your setup from the Settings page, Backup and Restore.
Changes from 1.1.2:
Additions / Changes
- Long running Apps and Drivers are limited to 120 seconds.
- New drivers:
- Fibaro wall plug
- Ecolink Siren
- Fibaro Single Switch 2
- Fibaro Flood Sensor
- New App for linking multiple hubs:
- Link to Hub - Beta (see this post)
- New Integration:
- Sharptools (see this post)
New Features
- Button Controller: Added repeat actions
- Hubitat Safety Monitor:
- Added %device% and %value% for messages
- Throw hsmSetArm events for other apps
- Support keypads for arming/disarming
- Hubitat Simple Lighting: Update to sunrise/sunset event scheduling NOTE: you must open every Simple Lighting rule that uses sunrise or sunset, and hit Done for them to work properly after this update.
- Mode Lighting: Added option to adjust levels on mode change
- Rule Machine:
- Added thermostat heat setpoint and thermostat cool setpoint as conditions or trigger events
- Added back every n seconds or minutes to Periodic
Bug Fixes
- Fixed Nanoleaf Aurora next and previous effects, general speed improvements.
- Fixed Life360 refresh driver not working.
- Fixed virtual motion driver not respecting initial auto inactive settings.
- Fixed Hue motion refresh and config errors.
- Fixed Safari on Mac OSX App List: unable to click child apps or status page links
- Fixed error messages in Alexa Skill logging and occasional unable to control device.
- Fixed Hubitat Dashboard double confirmation on mobile devices and double sending of commands
- Shutdown telnet connection properly on device removal.
- Motion Lighting: Fixed “Don’t turn off if already on” for switches and bulbs
- Rule Machine:
- Fixed bug for Periodic with Triggered Rules
- Fixed private, update and stop for This Rule
- Hubitat Safety Monitor: Fixed external armHome/armAway conflict
