Screen shots usually work best
Perfect, we can download and enlarge if required...
Quick observation:
0x74 high RTT (Round Trip Time) 65K and no route designated yet (lack of route is probably due to reboot)
This one may be doing a lot of rebroadcasting trying to find a good route.
I also saw 2 devices with no route. I tried a repair on these devices but it did not work.
Routes will eventually fill in as the devices check in with the hub - not unusual after a reboot for them to be blank for a while. Battery devices tend to be blank longer do to the nature of their check in cycle.
A high RTT and/or negative relative signal strength (RSSI) are indicators that a device may be having issues communicating - may not be causing an issue, but may need a repeater or two to help them.
I have 2 aeotec extender.
It was working fine for few months ans stopped working without adding a new device.
Shuold I buy a new hub ?
Don't think you need another hub from a number of devices standpoint as there are several people on here with more devices. You mentioned that you took the power reporting down to 5 minutes, has that helped? May want to check to see if any of your devices are ones that are known problems on the C-7 (the ZSE40 Zooz 4-in-1 comes to mind -List of Compatible Devices - Hubitat Documentation).
Also can check the device runtime stats to see if there are any that seem to occupying a high % of the activity. (http://hub-ip/runtimeStats#device-stats-panel)
If I buy a new hub is because I suspect a malfunction in mine.
These Zooz devices (ZEN25) are listed without any problem.
Here is the activity:
Would these 2 others happen to be these?
Edit: Disregard I didn't see the last post
Hi there, I see that you have sent us an email today (ticket 22394) and the last ticket we had from you was back in January (ticket 20290). Do you happen to have a ticket number for the email you sent us a week ago?
For today's ticket, we will further investigate and get back to you as soon as possible.
Sorry I don't have my ticket number. So I decided to resend my email today and this time I keep my ticket. Probably I did something wrong in my first ticket.
I WAS WRONG !!!! I just check on the devices and they are ZEN25 and NOT ZEN30. I'm at the right firmware, latest Hub update. But I don't know which one is parameter 18. I will exclude my 4 Zooz devices and see if it helps. Thank's for the good advice.
If you don't get an automated email that a ticket number was assigned, chances are that we didn't receive your email. Someone last week, for example, sent emails to my personal address, which has restrictive spam filter and I rarely check the spam folder. Please be sure to send emails to support@hubitat.com.
Good to know. Thank you very much. I know Hubitat is the BEST !
I excluded all 4 Zooz devices, shut down the hub, unplug and replug it.
Same problem
I took a look at your hub's error log and I don't think you have a Z-wave problem, but rather a database problem. Something appears to be locking your hub. I see errors from several custom integrations. I would screen the logs more closely to identify which integrations may be locking your hub. Also, if you didn't do so already, I suggest performing a "Soft Reset" with restore by following instructions in below document:
I just did a soft reset and restore and I was unable to control my zwave devices. Same problem again, zwave devices are not responding anymore.
How can I identify if a custom integration locks the hub ? There should be some specific errors ?
As you said in your email I will try to disable custom code and let you know during the weekend if it fixes the problem.
Was it only Z-wave that wasn't responding?
Hub is looking good after reset. I see the Z-wave queue was full the other day. If you didn't do so already, please unplug the hub from the wall outlet for a minute before plugging back in. Going forward you may need to adjust frequency of Z-wave polling and/or the number of events the radio receives, to avoid filling up the queue. That may explain the problems you've been having with the Z-wave devices. Unfortunately, moving the mesh to a new hub will not resolve this problem.
