I have a problem with a C-7 hub and I bought another C-7 to replace it.
I want to subscribe to be able to use the Hub-to-Hub Migration. Since i won't use the first hub anymore after the migration, do I have to subscribe on the first one or can i subscribe only the new one ? I don't want a subscription on the one i will throw away. I'm not sure if I have choice to subscribe to only one of them or I have to do it for both ?
I wrote to support one week ago and got no answer.
It was working for many weeks. But now, many times per day i cannot control a thing over ZWave. I have to shutdown the hub, then unplug it and replug it for my zwave devices to work. And then later during the day, same thing happens.
Those would be a problem then - sounds like they didn't completely finish the pairing process. May be partially functional, but at other levels won't be properly responding. I'd try removing those, excluding, and then re-including them.
I was able to remove the 2 faulty devices. I won't add them until I'm sure everything is fine. I'll see today and let you know if it fixes my problem. Luckily I did not buy the second hub. Thank's
The problem came back. I am unable to control Zwave devices. I tried different brands. All clusters seem to be ok, I rebooted the hub after removing the faulty devices. It was working for about 15 minutes. Any idea after that ? I
I have 2 other Zooz Plugs (I had 4 but just removed 2). They report often the power. Should I try to remove them ? It was working for many months and suddenly stopped working fine.
Edited: I change the power reporting from 30 seconds to 5 minutes.
