Well, that took about 30 min. I'm down again
What are the chances its hardware related
Seems possible, thats why I was hoping someone would look at the back end logs.
You could file a warranty claim to get that started if it is possibly hardware:
Thanks i filed the other day. Just got an email from Hubitat turning down my request for replacement. They told me to check out the community for resources. Not to sure what to do now.
After turning off those apps, what do your logs and app and device stats say?
@bobbyD @support_team We are out of ideas and tagged support multiple times?
Thanks guys. Appreciated the help.
Is there any way to disable a device other than to exclude it, like we did with the apps.
I would assume from all this that it must be a device thats bringing the hub to a hult.
Yes, same feature exists for devices as for apps.
But it won’t stop a device from spamming the mesh, if that’s what is going on.
As they said, yes and no. You can disable a device but it only stops the hub from acting on anything with the device, it wont process incoming messages and it wont send anything out. If the device itself is spamming out messages for some reason disabling it on the hub wont stop that.
If you have anything that would be sending reports to the hub like sensors, or anything with power metering I would start there. If you can cut power to just those device that would be a way to stop them without excluding or resetting. Typically a light switch is not very chatty unless something is wrong with it and its going haywire.
OK got it. I read a post from bobbyD that talks about Power plugs and how they can report power too often and jam up the network. I have 4 of them that I have unplugged right now to see.
My question is all these things I used with Smartthings why was there no problem then?
The only explanation anyone can come up with is that ST used a 500 series zwave chip and the C7 uses a 700 series. SiLabs has made some major improvements to the firmware since the C7 launched which Hubitat has tested and made available for us. Still seems like some things may not be up to par with the older ships yet though. I see in one of your screenshots the "Update Firmware" button is not there on the zwave details page so you must be updated already.
Also possibly the DTH you used in ST was automatically setting your device parameters to minimize the reporting. Once you excluded / reset the device it went back to defaults. For some reason a lot of MFG think that reporting the power watts every 5 seconds is a great idea (hint: its not). The Hubitat driver a lot of times will keep the device defaults and it is up to you to change the settings.
If you tell us what device(s) is it, might be able to find the manual and offer some tips.
I use two of these
and two of these
bobbyD suggests that any power monitoring plugs should be WiFi
Ill keep that in mind for future purchases
I’ve had very good luck with Zigbee power monitoring plugs. Zigbee has 2.5X the bandwidth of Z-Wave. It seems to be much more resilient to this and doesn’t need to be polled like WiFi devices.
I would test for a while with them all unplugged. If that solves the issue:
The Zen15 can be heavily adjusted to reduce the reporting. Try this driver [DRIVER] Zooz Smart Plugs Advanced (ZEN04 / ZEN05 / ZEN14 / ZEN15)
The defaults I set on that driver should not be too bad but you can fine tune it more. Turn on both logging options and you will be able to see every report that comes in (for 30 mins on debugging). Disable or increase thresholds for any power reporting you do not use.
I will check out that dome plug later.
It depends on how they're used.
For Example:
I have a ZEN15 on the washer. One power report during a cycle tells me it's running and one more after the cycle ends to know when to push a notification. So, I have the power reporting threshold set to 300W. This gets me the proper notifications without flooding the z-wave network. If I didn't want the notification, I wouldn't even monitor power and would just pull energy every so often.
In a nutshell...minimize power reporting to the bare minimum for your requirements and you'll be fine. Just definitely don't leave it to report every 1W change.
Yes, this. Don't overdo it.
For the Zooz plugs, pick one or maybe two items for power reporting. You don't want everything turned on, and you don't want minimum values set for anything.
For my washer I use 100W and 2 minutes. I do not use percentage change, Energy/Current/Voltage intervals, or anything else. Turning on all those will certainly bomb out a hub, especially if you have multiple plugs reporting that many events.
OK Guys thats what Im using them for the Washer and Dryer
So Ill I need to do is report the power like this
That should work. I would just check the logs after a wash cycle (assuming the rest of your issues get squared away) to make sure it's not creating too much reporting, then tweak as need from there. I picked 300W as a "Delicate" cycle on my washer only peaks at around 360W.
The ZEN15 always reports a return to 0W.
I have a zen-15 and still haven't used it. Sitting in my "gonna get to it one day box". Once I got started with @iotawatt and use that for monitoring my washer, dryer, water heaters, and a few other things. I have some sengled plugs that report power, but man... Iotawatt does it so much more cleanly.
