Hello everyone. I have a C-7 ver 2.3.8.139. I recently move all the devices form Smartthing over to Hubitat. I have noticed that z-wave switches stop responding from the app everyday for a few minutes. Basically the switches will stuck in whatever states they are in. I can't turn on or off a light switch. The motion sensor will detect motion but the light won't turn on. After a few minutes (5-10), everything is back to normal. I have updated to the latest platform. I have reboot the hub multiple times from the browser. Any suggestion is appreciated.
My initial thought is that something is causing interferences at those times. Have you checked your logs when it occurs? Could you share a screenshot?
Thanks for the reply. Can you tell me which event log I should be looking at when it happen? I check the individual device log (light switch), I notice that command was issued but the switch didn't executed the command.
This happen to all the devices during the time when the hub is not working. It will come back in a few minutes and everything work again.
This gives me the impression that you may have a Z-Wave mesh issue. Could you share screenshots of your Z-Wave Details screen (showing all devices)?
The screenshot needed is from Settings > Z Wave Details (not the Device list) as that shows the route information we need to see that would indicate a mesh issue. You're looking for devices that don't show a route in the end column as that may indicate a failed pairing/ghost.
Also please have the hub running with devices in use for at least 12 hours since some of the stats reset when you reboot. Please indicate how long hub was running when you took the screenshots.
I'll leave it to someone more experienced but I'm guessing that you may have as many as 8 ghost devices there (all of the entries that have no route in the last column and no 'Device'). These are usually the result of failed inclusions and will wreak havoc on the Z Wave network until removed.
Yes try to remove some of those dead nodes with no device listed. There are some instructions in here How To: Remove Ghosts using hub tools or a UZB Stick
Also your master bath dimmer seems to be having a hard time with 71 route changes. Does it have any sort of metal in the way that might be causing interference? Or do you have any rules that do the long fade with multiple commands? You might be overwhelming it in that case.
Thanks for the instructions. I will look into removing ghost devices. The light switch is next to 2 other switches (Master Bath Fan and Master Bath Light). There isn't any rule I am using for this switch. However, I am using Motion and Mode Lighting App to turn it on and off with a zigbee motion sensor. I notice it is now 241 routes change. Is there anyway to fix it? Is it better to remove and add it to the hub again?
Can you post your Motion app setup? I think there might an option in there that does the slow fade with multiple level commands.
Usually removing and adding again wont do much good.
Do you know what Jasco switch it is? Is it possibly old and not Z-wave plus, and being polled?
Also, a certain time range of manufacturing of the Jasco stuff I think had capacitor issues. I believe I have seen some reports of them spamming and taking down the mesh when they were on their way down the path to total failure. Do you have any spare replacements?
I experienced this with an Enbrighten dimmer that was a month old. Had to cut power to the circuit since it was overwhelming the hub as well.
The following is the setup for my motion sensor routine. I have shut off power to the dimmer switch (GE Z-Wave plus Smart Dimmer). It seems to help because now the route changes have dropped down to 4.
I am able to remove 5 out of the 8 ghost nodes. I am having problem with the remaining 3. The log keep saying "Failed node 61 remove status: 0 SDK failure node is no longer in failed node list."
I plan to get a z-wave stick to see if I can remove them.
Also, I notice 2 of the nodes have blank under device name but the route is not blank. Do I need to remove those?
They could possibly be attached to powered devices, but if they are, you dont have them linked to a device on the hub so you cannot do anything with them. Sometimes the old routes just get stuck in there and never go away even on dead devices/nodes. Best to get rid of the nodes and if you figure out what device it was you can re-include it.
Using the Z-Wave stick, I am able to remove all the ghost devices and dead nodes. The light switches seem to response faster. The max. route changes so far is 10. Thanks for all the help.
The issue with the delay or no response from the motion sensor is still there. It has improved from all devices to only a few light switches not turning on when motion sensor is trigger. Checking the event log, it still shows command is issued but switch is not there to response. The following is when the motion routine is working correctly.
When the routine is not working, this is the event log I get.
The command is there but the switch is not on the next line to execute. It will fix itself in a few minutes if I keep making motion at the motion sensor. It doesn't limit to 1 switch but all the switches that I have a motion sensor link to it. I can't find a pattern since it happen on different switches at different time. Will a Z-Wave repair help in this case?
If you just got rid of the dead nodes recently a repair might help, otherwise it should sort itself out within a few days anyway.
Can you confirm your z-wave firmware does not need an update? If there is an update the z-wave details page would have an "Update Firmware" button. If button is not there it should be updated already.
How many lights are you trying to turn on at once with this motion sensor?
Possibly putting them in a group with command metering enabled may help, then the motion rule would just turn the group on/off.
I am not sure what version of the firmware I am on. There is a button for update firmware but when I try to update, I got the following message "Z-Wave Updater: ERROR. This firmware target is not upgradable". I use the "yourHubIP*/hub/advanced/installZipgateway718" to update to 7.18 but I still have the update firmware button.
I have 13 motion sensors which control 13 different switches. Each motion sensor only control 1 light (switch). When the problem arise, some or all of the switches that activate by the motion sensor will stop working. Every switch event log will show a command was issued (motion detected) but the switch didn't response. It will turn on after a few minutes if I keep activating the motion sensor.
Since each of the motion sensor control only 1 light, I don't think grouping will help. However, I did try to group all the lights from downstairs and see what happen. I have turn off optimization and enable metering (set the delay to 50 milliseconds). I notice not all the light will turn on (23 switches and 7 dimmers). I have to hit the on button 2-3 times to have all the lights on. The same goes with the turn off button. I am not sure if 30 switches are too many for grouping.
I asked about the Z-wave firmware because your issues are exactly what happens on the old firmware, Z-Wave is very unreliable. I think your problems will mostly go away once you get updated.
Follow these instructions to get the firmware updated. Basically you have to downgrade the gateway first so the firmware can update, then update the gateway back to 7.18
