This hub normally uses about 25 to 36 Mb for the database. It started going up to over 2000 Mb. It is now at -2101 Mb. Any suggestions, @bravenel ?
Thanks. I never know who to tag. Is there a list that shows their expertise?
Negative is an overflow condition. Recommend downloading a backup, doing a soft reset and then restoring the backup.
That did the trick. Thanks. I wasn't sure if the negative db size was problematic, but apparently not, as this solution still worked.
The negative database size bug will get fixed in 2.2.8.
Also, there will be a very insistent advice to do a soft reset if the database is that large, with an easy way to initiate said soft reset right there on the alert page.
How do you access this information?
