Hub error 500
Best to just sit tight and wait. I do not recommend rolling back to 2.1.0.
The restore should take no more than 10 minutes, it's possible that the browser hung or timed out. Refresh the page and see if it's back up and running.
Don't think so, After the first 90 minutes I decided to do a (hubip):8081/resetHub Soft Reset, after I clicked through the TOS the screen went blank white, had to manually put (hubip)/hub/edit to get to the settings page to select backup/restore.
Now when I selected stop in the browser and refreshed it came back up to the backup/restore page with no other settings/apps/devices sidebar available.
I will reboot my pc and see if anything changes.
UPDATE:.....no changes with rebooting PC still same above screenshot, trying a different restore file other than the one I manually saved before the update.
After performing a soft reset and clicking yes on TOS, I get the very first screen, when clicking "next" it goes blank. (I'm using Chrome)
Clearing browser cache? Site data???
Yep just rebooted PC before this, just got the email that says to click the restore from backup from "bottom" of the green screen (never even noticed that hidden there) to not even go into the "get started" trying that now.
Unless you have set a clear everything on exit, rebooting doesn't clear cache or site data. Hopefully what you are trying works.
Last Tuesday , I had " Hub Error 500 " on 1 of my 3 hubs, firmware version : 2.1.1.114. I had to pull the plug, run backup about 15 minutes. It's run OK now with firmware 2.1.1.119.
00
So after 2 1/2 hours of nothing but the screen above. (over 9 hours messing with this today) it's time to "try and see".....so while it was STUCK on this restoring backup screen, and since a "hotfix" was release to fix the issues, I tried typing ipaddress /hub/firmware to see if it would go ahead and update.
Surprise it worked, PROGRESS!!!! ..... Except for NOW it's stuck on THIS screen
And if I right click to open in a new tab any of my devices/apps.......ALL gone except my phone and "dashboards"......wonderful AND when going into hub settings.....it didn't take....back to square one
Hub update 2.1.1.120 has been released.
This hot fix release fixes these bugs:
  • Fixed the random 500 errors some users have reported
  • Fixed the Getting Started blank screen during tutorial
get5000
NOT FIXED!
What is app:865 in your Hubitat Hub? Might give more of a clue why your getting that error..
App 865 is HubConnect, and it's throwing the error because my coordinator hub has been completely down for 16 hours still waiting for support to help.
So ya you're probably right it may be fixed if I could ever get the hub back up
EDIT: FWIW, now that my coordinator hub finally blue lighted and is now unreachable, the error on these remote hubs is still there but instead of being a error 500, it is now an error 408
After my error 500, the hub came right back up after a pull power/re-cycle, but boy howdy was all my automation jacked up. Stuff fired randomly, didn't fire... that was yesterday, today seems to be better.
Now let's see what happens with the .120 hot fix...
Rick
update: Took a backup :), then updated to .120, came back up and logged back in approx. 5 mins later, no issues. Good job team
update 2: my sunset automation worked just now... :slight_smile:
Were you ever able to get the hub back up?
Nope it's finally blue lighted....bobby's going to look more into it tomorrow.
I thought blue light indicated operational, is that wrong?
Whenever it's "booting up" blue light is normal......if the blue light doesn't turn green, usually means it's the kiss of death.
HMM, mine is blue and operational. Have not upgraded yet, waiting to see resolution to your problem. I know "oh goody i'm a trail blazer!"
Hope it fixed soon
Rooting for ya. Keep us posted.
C-5 hub?
