I’m having an issue with arming failure notifications for a garage door… the notifications are happening immediately upon arming. I have an arming delay set, but as soon as I set mode to away and HSM arms away, I get an alert that my garage door did not arm properly (it only starts closing upon mode change to away). I would expect that if HSM delay is set, it would only try to arm at the end of the delay time and I would only get the alert at that time if the garage door remains opened. Isn’t that the point of an arming delay - so I can exit and close any doors before it arms? Is there perhaps a bug? Thanks!
More info:
- Arming triggers garage door to close.
- HSM is configured to auto arm/disarm Arm-Away 30 seconds after Mode Away
- Garage Door is configured to auto-bypass
- Notifications are configured for arming failures/bypass warnings (these happen immediately upon Mode-Away instead of at the end of the 30 second period if door is still open)
Same unanswered question here: https://community.hubitat.com/t/hsm-delays-and-notifications/58462
