How to save data every X minutes for trending/analysis offline
In SmartThings, I had set up a google sheets integration that worked to pull points I wanted into Sheets. From there, I could use basic spreadsheet capabilities to analyze and graph data offline.
I'm finally looking to do the same for Hubitat. I found some database solutions (which I have yet to find a tutorial that I'm capable of succeeding on!), as well as this thread for google sheets (also struggling, I think it's outdated a bit), and also the WebCore graphing/trending that saves stuff locally (I've got it working but it is buggy and breaks a lot, I'd consider it barely functional right now).
Is there anyone working on a solution that is simple and works for the masses for something like this? I would gladly pay for this capability, personally.
If anyone knows of a really nice tutorial for graphana and influxDB, please pass my way. I've been trying to figure out how to install a docker on QNAP and use that with Hubitat, I've just had zero success because nothing is specific enough for this use case I believe.
Do a search for 'Watchtower'.
This may do what you want.
unsure if you want to go all in or not - but the use of Influx with grafana has become so simple - people are trading templates!
Even I could do it. Oh. and bonus - you can implement your own Echo Speaks while you're at it.
what guide did you use for influx/grafana?
@bobbles that looks very promising!
something I wrote around here somewhere - last I looked it was no longer accurate as Grafana had a major version change. on your qnap, load influxdb 2, then use HPM to install Influx logger - pick some devices to connect and push out data. On the influx side, create a DB, be careful the name you use, case sensitive - and the user token. Put the token into the HE influx logger with the URL (the instructions will give some help) and finally load Grafana on your qnap and hook it too Influx as the source. then play play play. Grafana is great - but initially it isn't easily intuitive until you start playing.
If you were using the Google Docs Logger on SmartThings, the good news is that it also just works on Hubitat. I'm using 3 instances on my C-7.
(the author, Check Schwer, was an early Hubitat employee).
Can confirm it "just works" and it works well!
Hi - does anyone know why the above link to "How-TO: Import Hub/Device Date into Google Spreadsheets" goes to a message stating "Oops that page does not exist or is private"?
I tried to set this up about 3.5 years ago and was not sucessful, but I'd like to have another go at it.
The linked thread (or post) was probably either moved or deleted after the link in this thread was posted.
Thanks.
Better questions that get at the issues:
  1. How can we access the instructions that were in the original post?
  2. Once we have a new location for the instructions in the original post, can we put something at the original post link that redirects to the new link, because that original post is linked in numerous threads on this topic.
@bobbyD ?
I was able to find the original post on the waybackwhen machine here:
Unfortunately, it seems that since the directions were written, Google has changed their user interface so much that a new set of directions is needed. Back to the drawing board.
