How to Factory Reset a Hubitat Elevation C7
I received a Hubitat Elevation C7 which apparently had be previously sold to another customer, returned, and used to fulfill my order. I cannot register the device to my email account because it is still associated with the email address of the previous buyer.
How can I do a factory reset to clear the previous data and register this device to me? Even thought I can locate the hub on my network, I cannot register it because I can't change the admin email address.
The registration isn't actually on the hub, so resetting the hub won't alleviate your issue. The original owner should deregister the hub.. but as a recipient of an Amazon blunder, there's probably not a useful path. (Amazon has repeatedly been given instructions by Hubitat to return all returns to Hubitat.. but clearly don't follow the instructions well.)
@support_team May be able to resolve this for you.
Normally a Hub would be de-registered here:
https://my.hubitat.com/
Unfortunately, this wasn't an Amazon blunder. It was ordered directly from Hubitat. Order confirmation number is #MJT6TFRFK.
Tagging @bobbyD
FWIW, Amazon fulfills orders made on hubitat.com ……
Perhaps the blunder was relying on Amazon for order fulfillment... Amazon has caused Hubitat to have one very unhappy customer.
Yea, it happens. It makes us all sad.
I know I wish that everyone had the same amazing experience i've had and I'm on my 10th Hubitat hub. Five of them are retired now. I only have two C-8's and three C-7's powered these days.
Sorry for the troubles, please check the notifications in the upper right corner. I sent you a private message.
bobbyD - Happy Camper here... Sorry for the delay but my project got interrupted. I received the replacement hub, got it connected, configured, and working! Thank you very much for your help. Great job with turning a bad experience into a very satisfied customer. Your support rocks!
It doesn't happen often but once in a while amazon puts a return of the shelf and they shouldn't but honestly overall you can't beat their logistics... Glad you're up and running!!! (Also surprised you didn't order a c8!)
Since you're new to hubitat, have a look at this post. It will help you avoid some gotchas...
I purchased a used C-7 on eBay and would like to hard reset it before placing it in my system... How do I do this?
Settings -> Z-Wave Details - Reset Z-Wave Radio (if there's anything there)
Settings -> Zigbee Details - Reset Zigbee Radio (if there's anything there)
Settings -> Hub Details - copy MAC address
Settings -> Diagnostic Tool - paste MAC address
Select "Soft Reset"
Hard reset?
There is no such button. What I described above is, for all intents & purposes, a hard reset.
Yeah, there may never have been a 'button', but in reading threads, the hard reset option was hidden.
How certain is a soft reset will be enough to wipe out whatever was there?
Do I need to then re-register it?
Completely certain.
Here, I'm not as sure. @bobbyD may have to check to see if your hub is registered and if so, purge the record so that you can register it.
You can’t. But the original owner can. Unless you know the email address and password they used to register your hub.
Yes, but if you can't it means the previous owner didn't deregister it.
It was hidden then removed. What @Bullfrog laid out for you is what tech support will tell you to do.
Is there any chance, even remote possibility, that a previous owner could have hacked the main code?
Unlikely, why do you ask? Because it's used? After it's setup simply update it, the platform will be wiped and rewritten.
