Is there a away to display the current IP address of the HE on the dashboard?
@thebearmay has released a 'Hub Information' driver.
This has an attribute that displays the local IP address.
You could display that attribute on a dashboard.
As @aaiyar has said below though, it is best to set up DHCP reservation for your hub.
It may be. However, it is strongly recommended to setup a DHCP reservation for the hub, so it’s IP never changes.
correction, I'm looking for the current "public" IP address to the HE, I want to display the "public" IP in the dashboard. The amazon hubitat server must know the public IP in order to host the data on the dashboard, correct? So does the HE also know the public IP?
Once again, hub information driver can do this for you.
awesome, thanks
