OK I admit that Tile Master is too complex for me. And while I appreciate the developers penchant for going his own way, not using HPM is a royal pain too. I tried and failed to use it to do something I thought was kind of simple. Is there another way to do this in one tile:
In this sample the current temp is a sensor value and the min/max are hub variables. I use multiple tiles for this now. And it take a lot of space and doesn't have a degree symbol. Seems like there should be a way, but I'm stumped. And I'm not really open to Tile Master for the reasons above. Convolution much? Thanks for any tips/pointers.
I agree multiple tiles on a dashboard, while achievable (including the degree I am sure.... But can't figure out just now...), is not an ideal solution in this case. I think if you can find or someone can develop a small app and/or driver to record the current, min and max for a given temperature device, perhaps with a tile output, this would make things easier. If not a tile output in a new driver, then it would certainly make the display easier using @thebearmay 's Device Data Item Display. I also think others would find a small app like this a useful addition, removing the need to setup albeit a small set of rules. For extra points, if the app could aggregate the min / max across mutliple sensors that may also be something people find useful.
Funny you should ask because I’m working on a solution for that exact problem. Everything about it is customizable, colors, borders, font size, alignment, attributes, titles, column headings, etc and supports highlighting for keywords such as the word open in this case. My guess is I’m about 1-2 weeks from release because I don’t like releasing buggy software.
Bottom line is that you can construct a tile with as many attributes and style it with as much CSS as you can fit in 1024 characters. Doesn’t do variables at the moment but it’s an easy add so maybe next week if I have time.
You might want to take a look at @gslender 's Hubivue (www.hubivue.com) 100% local and allows customizable tiles easily. You can see here I have Temp and Humidity but you can pretty much do as many of what you want
In the list of hub attributes, it doesn't give you the current weather description (ie Clear, Cloudy, Storm, Rain etc) - how do you propose that is derived from the API ??
Oh... so what you're doing is using a hub connected device to send "some" weather data to the hub, but you expect the dashboard to connect to the API server of the device to collect "more" weather data to build a more complete picture of the weather at home?? That level of complexity won't be available initially, but will look into that over time - obviously combining that level of complexity isn't easy (as I'd need to support a bunch of APIs as everyone has their favorite).
@syepes Yes I did finish it but I'm going to be gone for two months with only my iPad mini and did not want to try and provide support etc. without my desktop, so I won't be releasing it until March. I also need to write up some documentation as the capabilities are fairly extensive and I don't want to answer a million questions. The good news is that the capabilities of the finished product exceeded my own expectations. There are two child apps right now so it looks like this in the app interface.
The first child app allows you to publish data for a single attribute across multiple devices. Here is a sample. The tile sizes are all limited to 1,024 bytes, so less flashy tile allows more rows of data.
The second allows you to publish tiles based on the activity attribute. This sample demonstrates some of the built in templates display almost identical data. This type of tile can be used to monitor most recently\least recently active which is helpful in finding devices with dead batteries or things such as most recently active doors\windows, repeaters etc.
All of these are generated using a point and click interface. The only CSS editing that is occurring here is this to hide the tile background and title. #tile-0 {background-color: rgba(128,128,128,0.0) !important;} #tile-0 .tile-title {display: none;}
Some things not apparent from these screenshots. The first is the ability to include animations that fire whenever the data changes. Secondly the ability to configure thresholds for displaying text in alternate size and colors, i.e. display <50% battery in red at 125% font size. Finally the ability to substitute device attribute values with icons such as "on" with or "not present" with "Away" for example.
So, I'll be releasing these as donationware in March for a few $$. If there is reasonable interest I'll add two other child apps. The first would be a tile that can contain a mix of different devices and attributes. The second would support actions using the maker API. Using animations it should allow for the creation of some very appealing animated controls like switches, dimmers and light bulbs.
One last feature I will point out is the ability to save a configuration as a text string and share it with others via these forums. It's quite a lot of fun generating these various designs but it would be even more fun to share ideas with others and see what other people create.
