Honeywell T6 Z-wave driver modification
Ok, I am messing with things way above my pay grade (again). I have been using the custom driver 'Advanced Honeywell T6 Pro Thermostat' for years now and love it. But one thing I would love to be able to control is ISU parameter 520, Temperature Control. This would allow me to remotely switch the active indoor sensor from the thermostat to the remote sensor.
I copied the code for the other parameters, and now it appears in the Hubitat device page, but it doesn't control. Is this because the Honeywell API doesn't allow it? My edit is the last line in this excerpt from the code I modified:
@Field static Map configParams = [
        1: [input: [name: "configParam1", type: "enum", title: "Schedule Type", description: "", defaultValue: 2, options: [0:"No schedule/Occupacy based schedule",1:"Every day the same",2:"5-2 Schedule",3:"5-1-1 Schedule",4:"Every day individual"]], parameterSize: 1],
        2: [input: [name: "configParam2", type: "enum", title: "Temperature Scale", description:"", defaultValue: 0, options: [0:"Fahrenheit", 1:"Celsius"]], parameterSize: 1],
        3: [input: [name: "configParam3", type: "enum", title: "Outdoor Temperature", description:"", defaultValue: 0, options: [0:"No", 1:"Wired"]], parameterSize: 1],
        4: [input: [name: "configParam4", type: "enum", title: "Equipment Type", defaultValue: 2, options: [0:"None", 1:"Standard Gas",2:"High Efficiency Gas",3:"Oil",4:"Electric",5:"Fan Coil",6:"Air to Air Heat Pump",7:"Geothermal Heat Pump",8:"Hot Water",9:"Steam"]], parameterSize: 1],
        5: [input: [name: "configParam5", type: "enum", title: "Reversing Valve", defaultValue: 0, options: [0:"O/B on Cool", 1:"O/B on Heat"]], parameterSize:1],
        6: [input: [name: "configParam6", type: "enum", title: "Stages", defaultValue: 1, options: [0:"0", 1:"1",2:"2"]], parameterSize:1],
        7: [input: [name: "configParam7", type: "enum", title: "Heat Stages Aux/E stages", defaultValue: 1, options: [0:"0", 1:"1",2:"2"]], parameterSize:1],
        8: [input: [name: "configParam8", type: "enum", title: "Aux/E Control", defaultValue: 0, options:[0:"Both Aux and E", 1:"Either Aux/E"]], parameterSize: 1],
        9: [input: [name: "configParam9", type: "enum", title: "Aux Heat Type", defaultValue: 0, options:[0:"Electric", 1:"Gas/Oil"]], parameterSize: 1],
        10: [input: [name: "configParam10", type: "enum", title: "EM Heat Type", defaultValue: 0, options:[0:"Electric", 1:"Gas/Oil"]], parameterSize: 1],
        11: [input: [name: "configParam11", type: "enum", title: "Fossil Kit Control", defaultValue: 0, options:[0:"Thermostat",1:"External"]], parameterSize: 1],
        12: [input: [name: "configParam12", type: "enum", title: "Auto Changeover", defaultValue: 0, options:[0:"Off",1:"On"]], parameterSize: 1],
        13: [input: [name: "configParam13", type: "enum", title: "Auto Differential", defaultValue: 0, options:[0:"0°F",1:"1°F",2:"2°F",3:"3°F",4:"4°F",5:"5°F"]], parameterSize: 1],
        14: [input: [name: "configParam14", type: "enum", title: "High Cool Stage Finish", defaultValue: 0, options:[0:"No",1:"Yes"]], parameterSize: 1],
        15: [input: [name: "configParam15", type: "enum", title: "High Heat Stage Finish", defaultValue: 0, options:[0:"No",1:"Yes"]], parameterSize: 1],
        16: [input: [name: "configParam16", type: "enum", title: "Aux Heat Droop", defaultValue: 0, options:[0:"Comfort",2:"2°F",3:"3°F",4:"4°F",5:"5°F",6:"6°F",7:"7°F",8:"8°F",9:"9°F",10:"10°F",11:"11°F",12:"12°F",13:"13°F",14:"14°F",15:"15°F"]], parameterSize: 1],
        17: [input: [name: "configParam17", type: "enum", title: "Up Stage Timer Aux Heat", defaultValue: 0, options:[0:"Off",1:"30 minutes",2:"45 minutes",3:"60 minutes",4:"75 minutes",5:"90 minutes",6:"2 hours",7:"3 hours",8:"4 hours",9:"5 hours",10:"6 hours",11:"8 hours",12:"10 hours",13:"12 hours",14:"14 hours",15:"16 hours"]], parameterSize: 1],
        18: [input: [name: "configParam18", type: "enum", title: "Balance Point (Compressor Lockout)", defaultValue: 65, options:[0:"Off",5:"5°F",10:"10°F",15:"15°F",20:"20°F",25:"25°F",30:"30°F",35:"35°F",40:"40°F",45:"45°F",50:"50°F",55:"55°F",60:"60°F",65:"65°F"]], parameterSize: 1],
        19: [input: [name: "configParam19", type: "enum", title: "Aux Heat Lock Out (Aux Heat Outdoor Lockout)", defaultValue: 0, options:[0:"Off",5:"5°F",10:"10°F",15:"15°F",20:"20°F",25:"25°F",30:"30°F",35:"35°F",40:"40°F",45:"45°F",50:"50°F",55:"55°F",60:"60°F",65:"65°F"]], parameterSize: 1],
        20: [input: [name: "configParam20", type: "enum", title: "Cool 1 CPH (Cooling cycle rate stage 1)", defaultValue: 3, options:[1:"1",2:"2",3:"3",4:"4",5:"5",6:"6"]], parameterSize: 1],
        21: [input: [name: "configParam21", type: "enum", title: "Cool 2 CPH (Cooling cycle rate stage 2)", defaultValue: 3, options:[1:"1",2:"2",3:"3",4:"4",5:"5",6:"6"]], parameterSize: 1],
        22: [input: [name: "configParam22", type: "enum", title: "Heat 1 CPH (Heating cycle rate stage 1)", defaultValue: 3, options:[1:"1",2:"2",3:"3",4:"4",5:"5",6:"6",7:"7",8:"8",9:"9",10:"10",11:"11",12:"12"]], parameterSize: 1],
        23: [input: [name: "configParam23", type: "enum", title: "Heat 2 CPH (Heating cycle rate stage 2)", defaultValue: 3, options:[1:"1",2:"2",3:"3",4:"4",5:"5",6:"6",7:"7",8:"8",9:"9",10:"10",11:"11",12:"12"]], parameterSize: 1],
        24: [input: [name: "configParam24", type: "enum", title: "Aux Heat CPH (Heating cycle rate Auxiliary Heat)", defaultValue: 9, options:[1:"1",2:"2",3:"3",4:"4",5:"5",6:"6",7:"7",8:"8",9:"9",10:"10",11:"11",12:"12"]], parameterSize: 1],
        25: [input: [name: "configParam25", type: "enum", title: "EM Heat CPH (Heating cycle rate Emergency Heat)", defaultValue: 9, options:[1:"1",2:"2",3:"3",4:"4",5:"5",6:"6",7:"7",8:"8",9:"9",10:"10",11:"11",12:"12"]], parameterSize: 1],
        26: [input: [name: "configParam26", type: "enum", title: "Compressor Protection", defaultValue: 5, options:[0:"Off",1:"1 minutes",2:"2 minutes",3:"3 minutes",4:"4 minutes",5:"5 minutes"]], parameterSize: 1],
        27: [input: [name: "configParam27", type: "enum", title: "Adaptive Intelligent Recovery", defaultValue: 1, options:[0:"Off",1:"On"]], parameterSize: 1],
        28: [input: [name: "configParam28", type: "number", title: "Minimum Cool Temperature", description: "degrees fahrenheit", defaultValue: 50, range: "50..99"], parameterSize: 1],
        29: [input: [name: "configParam29", type: "number", title: "Maximum Heat Temperature", description: "degrees fahrenheit", defaultValue: 90, range: "40..90"], parameterSize: 1],
        30: [input: [name: "configParam30", type: "enum", title: "Air Filters", defaultValue: 0, options:[0:"0",1:"1",2:"2"]], parameterSize: 1],
        31: [input: [name: "configParam31", type: "enum", title: "Air Filter 1 Reminder", defaultValue: 0, options:[0:"Off",1:"10 run time days",2:"20 run time days",3:"30 run time days",4:"45 run time days",5:"60 run time days",6:"90 run time days",7:"120 run time days",8:"150 run time days",9:"30 days",10:"45 days",11:"60 days",12:"75 days",13:"3 months",14:"4 months",15:"5 months",16:"6 months",17:"9 months",18:"12 months",19:"15 months"]], parameterSize: 1],
        32: [input: [name: "configParam32", type: "enum", title: "Air Filter 2 Reminder", defaultValue: 0, options:[0:"Off",1:"10 run time days",2:"20 run time days",3:"30 run time days",4:"45 run time days",5:"60 run time days",6:"90 run time days",7:"120 run time days",8:"150 run time days",9:"30 days",10:"45 days",11:"60 days",12:"75 days",13:"3 months",14:"4 months",15:"5 months",16:"6 months",17:"9 months",18:"12 months",19:"15 months"]], parameterSize: 1],
        33: [input: [name: "configParam33", type: "enum", title: "Humidification Pad Reminder", defaultValue: 0, options:[0:"Off",1:"6 months",2:"12 months"]], parameterSize: 1],
        34: [input: [name: "configParam34", type: "enum", title: "Dehumidification Filter Reminder", defaultValue: 0, options:[0:"Off",1:"1 months",2:"2 months",3:"3 months",4:"4 months",5:"5 months",6:"6 months",7:"7 months",8:"8 months",9:"9 months",10:"10 months",11:"11 months",12:"12 months"]], parameterSize: 1],
        35: [input: [name: "configParam35", type: "enum", title: "Ventilation Filter Reminder", defaultValue: 0, options:[0:"Off",3:"3 months",6:"6 months",9:"9 months",12:"12 months"]], parameterSize: 1],
        36: [input: [name: "configParam36", type: "enum", title: "UV Devices", defaultValue: 0, options:[0:"0",1:"1",2:"2"]], parameterSize: 1],
        37: [input: [name: "configParam37", type: "enum", title: "UV Bulb 1 Reminder", defaultValue: 0, options:[0:"Off",6:"6 months",12:"12 months",24:"24 months"]], parameterSize: 1],
        38: [input: [name: "configParam38", type: "enum", title: "UV Bulb 2 Reminder", defaultValue: 0, options:[0:"Off",6:"6 months",12:"12 months",24:"24 months"]], parameterSize: 1],
        39: [input: [name: "configParam39", type: "enum", title: "Idle Brightness", defaultValue: 0, options:[0:"0",1:"1",2:"2",3:"3",4:"4",5:"5"]], parameterSize: 1],
        40: [input: [name: "configParam40", type: "enum", title: "Clock Format", defaultValue: 0, options: [0:"12 hour", 1:"24 hour"]], parameterSize:1],
        41: [input: [name: "configParam41", type: "enum", title: "Daylight Savings", defaultValue:1, options:[0:"Off",1:"On"]], parameterSize: 1],
        42: [input: [name: "configParam42", type: "enum", title: "Temperature Offset", defaultValue: 0, options:[(-3):"-3°F",(-2):"-2°F",(-1):"-1°F",0:"Off",1:"+1°F",2:"+2°F",3:"+3°F"]], parameterSize: 1],
        43: [input: [name: "configParam43", type: "enum", title: "Temperature Control", description:"", defaultValue: 0, options: [0:"Thermostat", 1:"Wired", 2:"Average"]], parameterSize: 1]
You should post that to the main thread and see what @thebearmay can do for you
Will do. Which is the main thread? Developers?
