So, what is the getInfo command supposed to yield as a result ?
I don't see anything more in the device page, and I see only this in the logs:
dev:2072022-12-06 16:03:28.121infoZigbee parsed:[raw:A81F19020126024021060008402333030000094023D4160000, dni:A81F, endpoint:19, cluster:0201, size:26, attrId:4002, encoding:21, command:0A, value:0006, clusterInt:513, attrInt:16386, additionalAttrs:[[value:00000333, encoding:23, attrId:4008, consumedBytes:7, attrInt:16392], [value:000016D4, encoding:23, attrId:4009, consumedBytes:7, attrInt:16393]]]
dev:2072022-12-06 16:02:58.457infoZigbee parsed:[raw:A81F1902010A0000299808, dni:A81F, endpoint:19, cluster:0201, size:0A, attrId:0000, encoding:29, command:0A, value:0898, clusterInt:513, attrInt:0]
dev:2072022-12-06 16:02:41.818infoZigbee parsed:[raw:A81F19020126024021060008402333030000094023C9160000, dni:A81F, endpoint:19, cluster:0201, size:26, attrId:4002, encoding:21, command:0A, value:0006, clusterInt:513, attrInt:16386, additionalAttrs:[[value:00000333, encoding:23, attrId:4008, consumedBytes:7, attrInt:16392], [value:000016C9, encoding:23, attrId:4009, consumedBytes:7, attrInt:16393]]]
dev:2072022-12-06 16:01:57.782infoZigbee parsed:[raw:A81F1902010A0000299808, dni:A81F, endpoint:19, cluster:0201, size:0A, attrId:0000, encoding:29, command:0A, value:0898, clusterInt:513, attrInt:0]
dev:2072022-12-06 16:01:43.569infoZigbee parsed:[raw:A81F19020126024021060008402333030000094023BF160000, dni:A81F, endpoint:19, cluster:0201, size:26, attrId:4002, encoding:21, command:0A, value:0006, clusterInt:513, attrInt:16386, additionalAttrs:[[value:00000333, encoding:23, attrId:4008, consumedBytes:7, attrInt:16392], [value:000016BF, encoding:23, attrId:4009, consumedBytes:7, attrInt:16393]]]
dev:2072022-12-06 16:01:16.632debuggetting info for unknown Zigbee device...
dev:2072022-12-06 16:00:58.486infoZigbee parsed:[raw:A81F1902010A0000299808, dni:A81F, endpoint:19, cluster:0201, size:0A, attrId:0000, encoding:29, command:0A, value:0898, clusterInt:513, attrInt:0]
dev:2072022-12-06 16:00:57.560debuggetting info for unknown Zigbee device...
dev:2072022-12-06 16:00:57.114infoZigbee parsed:[raw:A81F19020126024021060008402333030000094023B4160000, dni:A81F, endpoint:19, cluster:0201, size:26, attrId:4002, encoding:21, command:0A, value:0006, clusterInt:513, attrInt:16386, additionalAttrs:[[value:00000333, encoding:23, attrId:4008, consumedBytes:7, attrInt:16392], [value:000016B4, encoding:23, attrId:4009, consumedBytes:7, attrInt:16393]]]
dev:2072022-12-06 16:00:55.538debugconfigure() called...
