Has anyone started working on drivers for Stelpro Allia thermostats (product code SAT402ZB) ?
No, the Maestro drivers do not work, nor the Ki drivers.
Stelpro told me they are not supported in Smartthings or Hubitat.
I looked at the existing Maestro drivers, and I am at a loss on how to modify it to get them working with those new thermostats.
If it helps, they are supported in HomeAssistant through Zigbee2MQTT, but I don't know what to make of this code...
Anyone has a clue as to what this means ?
Desc Map: [raw:catchall: 0000 8021 00 00 0040 00 CF57 00 00 0000 00 00 C300, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:CF57, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[C3, 00]]
It would appear that this device has two fingerprints. Could that be the source of issues ?
When I connect that device to the hub, this is the pairing info that I get:
Manufacturer: Stello
Endpoint 19 application: 21
Endpoint 19 endpointId: 19
Endpoint 19 idAsInt: 25
Endpoint 19 inClusters: 0000,0003,0004,0201,0204
Endpoint 19 initialized: true
Endpoint 19 manufacturer: Stello
Endpoint 19 model: HT402
Endpoint 19 outClusters: 0003,000A,0402
Endpoint 19 profileId: 0104
Endpoint 19 stage: 4
Endpoint F2 application: unknown
Endpoint F2 endpointId: F2
Endpoint F2 idAsInt: 242
Endpoint F2 initialized: true
Endpoint F2 manufacturer: unknown
Endpoint F2 model: unknown
Endpoint F2 outClusters: 0021
Endpoint F2 profileId: A1E0
Endpoint F2 stage: 4
And it seems that the hub "records" the second one, not the first one (which seems more complete)
system
Closed
4
