I think you are missing a driver. Look just above the "release notes" grey bar in both of our screen shots.
Did you install an app code, and a driver code?
I sorta indiscrimantly grabbed the drivers that sounded like what I needed but I did not grab them all. However now I'm not sure I'm in the right place on github.
Can you steer me to the right github link?
Did you use this repository?
This should be the Raw links.
Driver WITH a door tilt sensor https://raw.githubusercontent.com/dcmeglio/hubitat-myq/master/devicetypes/brbeaird/myq-garage-door-opener.src/myq-garage-door-opener.groovy
Driver if you do NOT have a tilt sensor https://raw.githubusercontent.com/dcmeglio/hubitat-myq/master/devicetypes/brbeaird/myq-garage-door-opener.src/myq-garage-door-opener.groovy
You should consider something else that might be easier for you. Hubitat package manager. It can install the drivers and app code for you. Once you install Package Manager, run it, and you can select this garage door to install. It takes care of all the behind the scenes stuff. You then would just go to the Hubitat app page, install the MyQ app without all the raw code and so on.
Thank you, that is exactly what I'm looking for...to start over from scratch.
However I was able to delete the Dashboard button, the App, the AppCode but received this error when trying to delete the driver...any ideas?
It looks like you still have a device in the Devices tab, did you get rid of that too?
Ok got it working and dashboard buttons for open and close added!!
Do you know how to configure a button for the status...ie closing, opening. It states that when you're in the device on the right under "Current States" but couldn't figure out how to see that one the dashboard, nor do they discuss it in the forum link you shared. I tried adding a button with Device set as "Garage Door Opener" and Template as "Door Status" but that didn't show any info on what was happening
Use Garage (control) as the device in Dashboard, and that part should show your current state.
Glad you finally got this far! It will only get easier from here. The first few things are tough. Wink spoiled us a bit, but it is worth the bit of aggravation to have things just work for a change.
Ok will give that a try and...I'm sure you're right regarding acclimating to Hubitat. And it's nice to have such a supportive forum community which didn't exist for Wink, at least that they hosted and monitored
Did you see my earlier post?
Sorry my heads been spinning with transitioning a zillion sensors to Hubitat with multiple little challenges in different areas so missed that comment, BUT THANK YOU.
For now I'm content with just using the Ring the app but at some point may investigate into the Alexa option you pointed out.
Ah! Yes! That was it. Sorry, I could not find it anywhere when I looked again.
Sorry I was not more help.
