I just installed a couple of these on my front and back doors. And plan to add some more for windows, love them so far, adding 1 for the garage door isnt a deal breaker. Does it continue to work with MyQ as in will it know if the door is open or close, or does that not really matter?
I am just trying to automate the parts of my house that is needed, but really would like to NEVER open the other apps....
If you have a GoControl contact (door/window) sensor (WADWAZ-1), it can be converted very easily into a tilt sensor by connecting a tilt switch (costs about 50 cents or less) to the external contacts. Here's an example from my garage door.
@dman2306 HEOS, really? I saw that my new Denon (basically bought for atmos) had this feature, but havent even looked at it. What functionality do you gain out of it? I could probably be convinced. Honestly havent even dug into what all my new receiver can do in the connected category....
I have a bunch of HEOS speakers around the house (plus in the AVR) and I use them for text to speech announcements and music control. I have a HEOS integration for HE built, there is also a built in device driver for Denon AVRs.
Yeah except if you buy a sensor you’ll stop using the nosensor version and switch to the one that uses a sensor. The nosensor doesn’t report state whereas sensor does
Thanks.... Not in possession of an extra sensor yet. And my current Garage Control button isn't working. Do I need to go back to the two button method until i do this?
Apologies for not reading the "Read Me" in, as the answer to my question may already be in there.
I have a MyQ enabled garage door motor. This means that it does not have a separate sensor for the garage door open / closed, but the information is there somewhere. (Both the MyQ app, and Wink was able to determine if the door was open or closed).
Does this version of the app / driver support the open / close data coming from a MyQ enabled motor?
@aaiyar, I agree that not after June 1st, but that's besides the point. The reason I have a Hubitat is that it replaces the Wink, so it's a lot sooner than June 1st in this instance.
Is it that the current version of the code does not support getting position data from the motor? And if so, is it the driver or app (or both) that requires updating to include pulling this data?
I installed the no sensor driver version before I got a sensor. That only ever worked with the two button method setup (or the two buttons hidden behind applicable virtual button/switch - up/on to Garage Door Opener, down/off using Garage Door Closer).
