Did you use this repository?
This should be the Raw links.
Driver WITH a door tilt sensor https://raw.githubusercontent.com/dcmeglio/hubitat-myq/master/devicetypes/brbeaird/myq-garage-door-opener.src/myq-garage-door-opener.groovy
Driver if you do NOT have a tilt sensor https://raw.githubusercontent.com/dcmeglio/hubitat-myq/master/devicetypes/brbeaird/myq-garage-door-opener.src/myq-garage-door-opener.groovy
You should consider something else that might be easier for you. Hubitat package manager. It can install the drivers and app code for you. Once you install Package Manager, run it, and you can select this garage door to install. It takes care of all the behind the scenes stuff. You then would just go to the Hubitat app page, install the MyQ app without all the raw code and so on.
