@kuzenkohome Well what happened?
No events regarding battery status. Even though the battery status message is in the log, had a battery event about 2 hours ago.
Self test produced an immediate event.
I still get the same as before:
I'm going to try updating the driver again just in case I made an error last time.
That 193 cells report makes no sense to me........... I get a similar message.
Maybe you smokie needs to get it's config again...... If you hit configure when the device is sleeping then I don't think it gets through, But if you were to hit the test button on the device it will wake up and then immediately hit configure....
Are you getting periodic "all clear" messages ? You should be.
If all else fails, re-pair the device.
Did the configure within 2 seconds of selftest will see what happens.
No periodic all clear messages either, neither in log or events.
Will try repair on second sensor as it isn't logging battery events.
Update: 9/5 Above actions made no difference still no battery or all clear events
I have the same problem. No battery info, no any other info. Only test smoke when I press the test button.
Are you getting any catch-all (that is, unparsed) messages in the log ????
Hey @simon
I just received 5 of these direct from Heiman that I 'd forgotten about (they took so long to arrive!!)
Installed your driver, put one into pair mode and it showed up instantly
It reports battery every 4 hours 8 minutes (and a few seconds)
I have a driver update suggestion...
Event "Test Button Pressed"
The test button sends the "Smoke Detected" followed by "All Clear" a second or so later.
On receiving the Smoke message, start a delay (maybe 2 - 3 seconds)
If "All Clear" received, set event "Test Button Pressed" True
If delay times out without All Clear message, set Smoke event True.
I can do this in RM, obviously, but it won't work in HSM. Needs to be in the driver to prevent HSM going into full panic mode when you press the test button....
Karyn
Now that's a very good idea !!!!
I'll have a look at that....
New version..........
Based on @karyn.andrews suggestion I have added logic to detect a test event as opposed to a real smoke event. You have an input option to enable or disable this functionality. The driver now keeps a record of when the sensor was last tested... I think that's a very useful enhancement. Thanks Karyn.
I do need to give this a test with some real smoke.... I'll get to that shortly.
* Heiman Zigbee Smoke Detector
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Original DTH on SmartThings by cuboy29
* Converted to Hubitat and extensivly modified by Scruffy-SJB
* Code snippets copied from veeceeoh, Daniel Terryn and Marcus Liljergren - with thanks.
// Ver: 1.5 - Added ability to detect a device test and to trigger a last tested event
// Ver: 1.4 - Parsed another unhandled catch-all
// Ver: 1.3 - Updated to support Zigbee 3.0 version HS1SA-E
import hubitat.zigbee.clusters.iaszone.ZoneStatus
metadata {
definition (name: "Heiman Zigbee Smoke Detector", namespace: "Scruffy-Sjb", author: "cuboy29") {
capability "Configuration"
capability "Smoke Detector"
capability "SmokeDetector"
capability "Sensor"
capability "Refresh"
capability "Battery"
command "resetToClear"
command "resetBatteryReplacedDate"
attribute "smoke", "string"
attribute "batteryLastReplaced", "string"
attribute "sensorLastTested", "string"
fingerprint profileID: "0104", deviceID: "0402", inClusters: "0000,0001,0003,0500,0502", outClusters: "0019", manufacturer: "HEIMAN", model: "SmokeSensor-EM", deviceJoinName: "HEIMAN Smoke Detector" //HEIMAN Smoke Sensor (HS1SA-E)
fingerprint profileID: "0104", deviceID: "0402", inClusters: "0000,0003,0001,0500,0502,0B05", outClusters: "0019", manufacturer: "HEIMAN", model: "SmokeSensor-N-3.0", deviceJoinName: "HEIMAN Smoke Detector 3.0" //HEIMAN Smoke Sensor (HS1SA-E)
def SensorTestOptions = [:]
SensorTestOptions << ["1" : "Yes"] // 0x01
SensorTestOptions << ["0" : "No"] // 0x00
preferences {
input "SensorTest", "enum", title: "Enable Sensor Testing", options: SensorTestOptions, description: "Default: Yes", required: false, displayDuringSetup: true
def descMap = [:]
if (description?.startsWith('zone status')) {
descMap = parseIasMessage(description)
}else if (description?.startsWith('enroll request')) {
List cmds = zigbee.enrollResponse()
descMap = cmds?.collect { new hubitat.device.HubAction(it) }
}else if (description?.startsWith('catchall')) {
descMap = parseCatchAllMessage(description)
}else if (description?.startsWith('read attr')) {
descMap = zigbee.parseDescriptionAsMap(description)
if ((descMap?.cluster == "0500" && descMap.attrInt == 0x0001) && (descMap.value == '0028')){ //Zone Type
log.debug "Zone Type is Fire Sensor"
}else if ((descMap?.cluster == "0500" && descMap.attrInt == 0x0000) && (descMap.value == '01')){ //Zone State
log.debug "Zone State is enrolled"
}else if ((descMap?.cluster == "0500" && descMap.attrInt == 0x0002) && ((descMap.value == '20') || (descMap.value == '0020'))){ //Zone Status Clear
SmokeOrClear("clear")
}else if ((descMap?.cluster == "0500" && descMap.attrInt == 0x0002) && ((descMap.value == '30') || (descMap.value == '0030'))){ //Zone Status Clear
// log.debug "${device.displayName} reports status is all clear"
}else if ((descMap?.cluster == "0500" && descMap.attrInt == 0x0002) && ((descMap.value == '0031') || (descMap.value == '0021'))){ //Zone Status Smoke
SmokeOrClear("detected")
// log.debug "${device.displayName} reports status is smoke"
}else if ((descMap?.cluster == "0502" && descMap.attrInt == 0x0000)){ //Alarm Max Duration
def int alarmMinutes = Integer.parseInt(descMap.value,16)
log.debug "Max Alarm Duration is ${alarmMinutes} seconds"
}else if ((descMap?.cluster == "0000" && descMap.attrInt == 0x0007) && ((descMap.value == '03') )){ //PowerSource
log.debug "${device.displayName} is Battery Powered"
}else if ((descMap?.cluster == "0001" && descMap.attrInt == 0x0020)) { //Battery Voltage
def batteryVoltage = ConvertHexValue(descMap.value)
handleBatteryEvent(batteryVoltage)
}else if ((descMap?.cluster == "0001" && descMap.attrInt == 0x0021)) { //Battery Cells
def batteryCells = ConvertHexValue(descMap.value)
handleCellsEvent(batteryCells)
}else if (descMap?.cluster == "0000" && descMap.attrInt == 0x0004){ //Manufacture
sendEvent(name: "manufacture", value: descMap.value)
log.debug "Manufacturer is ${descMap.value}"
}else if (descMap?.cluster == "0000" && descMap.attrInt == 0x0005){ //Model
sendEvent(name: "model", value: descMap.value)
log.debug "Model is ${descMap.value}"
}else {log.debug "Unknown --> Cluster-> ${descMap?.cluster} AttrInt-> ${descMap.attrInt} Value-> ${descMap.value}"
// log.debug "Cluster-> ${descMap?.cluster} AttrInt-> ${descMap.attrInt} Value-> ${descMap.value}"
return descMap
private parseCatchAllMessage(String description) {
Map resultMap = [:]
def descMap = zigbee.parse(description)
if (shouldProcessMessage(descMap)) {
log.debug descMap.inspect()
return resultMap
private boolean shouldProcessMessage(cluster) {
// 0x0B is default response indicating message got through
// 0x07 is bind message
// 0x04 - No Idea !!!!!
boolean ignoredMessage = cluster.profileId != 0x0104 ||
cluster.command == 0x0B ||
cluster.command == 0x07 ||
cluster.command == 0x04 ||
(cluster.data.size() > 0 && cluster.data.first() == 0x3e)
return !ignoredMessage
def refresh() {
log.debug "Refreshing..."
def refreshCmds = []
refreshCmds +=
zigbee.readAttribute(0x0500, 0x0001) + // IAS ZoneType
zigbee.readAttribute(0x0500, 0x0000) + // IAS ZoneState
zigbee.readAttribute(0x0500, 0x0002) + // IAS ZoneStatus
zigbee.readAttribute(0x0502, 0x0000) + // Alarm Max Duration
zigbee.readAttribute(0x0000, 0x0007) + // Power Source
zigbee.readAttribute(0x0001, 0x0020) + // Battery Voltage
zigbee.readAttribute(0x0001, 0x0033) + // Battery Cells
zigbee.readAttribute(0x0000, 0x0004) + // Manufacturer Name
zigbee.readAttribute(0x0000, 0x0005) + // Model Indentification
return refreshCmds
def configure() {
log.debug "Configuring..."
if (!device.currentState('batteryLastReplaced')?.value)
resetBatteryReplacedDate(true)
def cmds = [
//bindings
"zdo bind 0x${device.deviceNetworkId} 1 1 0x0500 {${device.zigbeeId}} {}", "delay 200",
] + zigbee.enrollResponse(1200) + zigbee.configureReporting(0x0500, 0x0002, 0x19, 60, 3600, 0x01) + "delay 200" +
zigbee.configureReporting(0x0001, 0x0020, 0x20, 600, 7200, 0x01) + refresh()
return cmds
def resetBatteryReplacedDate(paired) {
def newlyPaired = paired ? " for newly paired sensor" : ""
sendEvent(name: "batteryLastReplaced", value: new Date())
log.debug "${device.displayName} Setting Battery Last Replaced to Current date${newlyPaired}"
def resetSensorTestedDate() {
def newlyTested=""
sendEvent(name: "sensorLastTested", value: new Date())
log.debug "${device.displayName} Setting Sensor Last Tested to Current date${newlyTested}"
def resetToClear() {
sendEvent(name:"smoke", value:"clear")
log.debug "Resetting to Clear..."
didWeGetClear = 0
* Code borrowed (mixed and matched) from both Daniel Terryn and veeceeoh
* Create battery event from reported battery voltage.
private handleBatteryEvent(rawVolts) {
rawVolts = rawVolts / 10.0
def minVolts = voltsmin ? voltsmin : 2.5
def maxVolts = voltsmax ? voltsmax : 3.0
def pct = (rawVolts - minVolts) / (maxVolts - minVolts)
def roundedPct = Math.min(100, Math.round(pct * 100))
log.debug "Battery level is ${roundedPct}% (${rawVolts} Volts)"
sendEvent(name:"battery", value: roundedPct, unit: "%", isStateChange: true)
return
private handleCellsEvent(noCells) {
log.debug "Battery reports that it has (${noCells} Cells)"
return
def ConvertHexValue(value) {
if (value != null)
return Math.round(Integer.parseInt(value, 16))
def SmokeOrClear(value) {
private Map parseIasMessage(String description) {
// log.debug "Zone Status Received--> ${description}"
ZoneStatus zs = zigbee.parseZoneStatus(description)
translateZoneStatus(zs)
private Map translateZoneStatus(ZoneStatus zs) {
// Some sensor models that use this DTH use alarm1 and some use alarm2 to signify motion
return getSmokeResult(zs.isAlarm1Set() || zs.isAlarm2Set())
private Map getSmokeResult(value) {
if (value) {
if (SensorTest == "") {
SensorTest = "1" // Default is Yes
if (SensorTest == "1") {
def descriptionText = "${device.displayName} status is pending"
log.debug descriptionText
runIn(3,EventOrTest)
return [
value : 'pending',
isStateChange: false,
descriptionText : descriptionText
} else {
def descriptionText = "${device.displayName} testing disabled - smoke detected !!!"
return [
value : 'detected',
isStateChange: true,
} else {
def descriptionText = "${device.displayName} all clear"
return [
value : 'clear',
def EventOrTest() {
if (device.currentValue("smoke") == "clear") {
log.debug "${device.displayName} was tested sucessfully"
} else {
log.debug "${device.displayName} This was not a test - smoke detected !!!"
sendEvent(name:"smoke", value:"detected")
Wow, that was quick!!
I'll upgrade it now but I can't test until tomorrow as my husband has just gone to bed.. He won't be a happy bunny if he's woken up by the smoke alarm
Thank you
No, I don't get any raw messages in the log. Only when I press the button I get smoke and clear. Nothing else.
@simon Another Heiman Zigbee smoke detector model to add to the driver:
fingerprint profileID: "0104", deviceID: "0402", inClusters: "0000,0003,0500,0001,0009,0502", outClusters:"0019", model:"SMOK_V16", manufacturer:"Heiman", deviceJoinName: "HEIMAN Smoke Detector M" // HEIMAN Smoke Sensor (H1S1A-M)
Test button triggers testing event, not tried with actual smoke yet
Thanks - will add it.
I tried it today with real smoke and the detector beeped but the sensor on Hubitat did not work.
This is my device
INCOMPLETE - DO NOT SUBMIT THIS - TRY AGAIN: fingerprint model:"SmokeSensor-N-3.0", manufacturer:"HEIMAN", profileId:"0104", endpointId:"01", inClusters:"0000,0003,0001,0500,0502,0B05", outClusters:"0019", application:"14"
You should try re-pairing because Iām pretty sure that this is trying to tell you that the device is not paired correctly.
M
Can you double check your driver please. I do not recognize the INCOMPLETE... message.
The incomplete message was using the zigbee generic tool box, to show the information about the sensor.
I'm using your driver posted on message #51
I will try to unpair and pair it again
I'd like to update my status about my HS1SA-E model.
My wife burned some cheese in the oven and the smoke sensor instantly beeped. But on Hubitat I have no info about that.
But I reset that sensor and pair it again and it works. I get all events in the log. So after you change the driver from the code you need to pair the device once again.
