Modified the code to include the fingerprint from above. Seems to be a Zigbee 3.0 version.
I put in an extra debug statement to display any Zone Status received in from the device, hope this will tell us what its sending when you hit the test button.
I removed the ping - I could never get the device to respond consistently (I'm guessing the device was asleep).
I added in a Battery Cell status message that @kuzenkohome was getting.
* Heiman (and maybe frient) Zigbee Smoke Detector
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Original DTH on SmartThings by cuboy29
* Converted to Hubitat and extensivly modified by Scruffy-SJB
* Code snippets copied from veeceeoh, Daniel Terryn and Marcus Liljergren - with thanks.
// Ver: 2.0 - Parsed another unhandled battery catch-all
// Ver: 1.9 - Added fingerprint for frient Intelligent Smoke Alarm
// Ver: 1.8 - Added fingerprint for model SmokeSensor-EF-3.0 Enhanced status message processing. New Current State - Date/Time last status recorded.
// Ver: 1.7 - Added fingerprint for model HS1CA-M HEIMAN Smart Carbon Monoxide Sensor
// Ver: 1.6 - Added fingerprint for model HS1SA-M
// Ver: 1.5 - Added ability to detect a device test and to trigger a last tested event
// Ver: 1.4 - Parsed another unhandled catch-all
// Ver: 1.3 - Updated to support Zigbee 3.0 version HS1SA-E
import hubitat.zigbee.clusters.iaszone.ZoneStatus
metadata {
definition (name: "Heiman Zigbee Smoke Detector", namespace: "scruffy-sjb", author: "scruffy-sjb and cuboy29") {
capability "Configuration"
capability "Smoke Detector"
capability "SmokeDetector"
capability "Sensor"
capability "Refresh"
capability "Battery"
command "resetToClear"
command "resetBatteryReplacedDate"
attribute "smoke", "string"
attribute "batteryLastReplaced", "string"
attribute "sensorLastTested", "string"
attribute "lastStatus", "string"
fingerprint profileID: "0104", deviceID: "0402", inClusters: "0000,0001,0003,0500,0502", outClusters: "0019", manufacturer: "HEIMAN", model: "SmokeSensor-EM", deviceJoinName: "HEIMAN Smoke Detector" //HEIMAN Smoke Sensor (HS1SA-E)
fingerprint profileID: "0104", deviceID: "0402", inClusters: "0000,0003,0500,0001,0009,0502", outClusters: "0019", manufacturer: "HEIMAN", model: "SMOK_V16", deviceJoinName: "HEIMAN Smoke Detector M" //HEIMAN Smoke Sensor (HS1SA-M)
fingerprint profileID: "0104", deviceID: "0402", inClusters: "0000,0003,0001,0500,0502,0B05", outClusters: "0019", manufacturer: "HEIMAN", model: "SmokeSensor-N-3.0", deviceJoinName: "HEIMAN Smoke Detector 3.0" //HEIMAN Smoke Sensor (HS1SA-E)
fingerprint profileID: "0104", deviceID: "0402", inClusters: "0000,0001,0003,0500", manufacturer: "HEIMAN", model: "COSensor-EM", deviceJoinName: "HEIMAN CO Sensor" //HEIMAN Smart Carbon Monoxide Sensor (HS1CA-E)
fingerprint profileID: "0104", deviceID: "0402", inClusters: "0000,0001,0003,0500,0502,0B05", outClusters: "0019", manufacturer: "HEIMAN", model: "SmokeSensor-EF-3.0", deviceJoinName: "HEIMAN Smoke Detector" //HEIMAN Smoke Sensor
fingerprint profileId: "0104", deviceId: "0402", inClusters: "0000,0001,0003,000F,0020,0500,0502", outClusters: "000A,0019", manufacturer: "frient A/S", model :"SMSZB-120", deviceJoinName: "frient Smoke Detector" // frient Intelligent Smoke Alarm
def SensorTestOptions = [:]
SensorTestOptions << ["1" : "Yes"] // 0x01
SensorTestOptions << ["0" : "No"] // 0x00
preferences {
input "SensorTest", "enum", title: "Enable Sensor Testing", options: SensorTestOptions, description: "Default: Yes", required: false, displayDuringSetup: true
def descMap = [:]
if (description?.startsWith('zone status')) {
descMap = parseIasMessage(description)
}else if (description?.startsWith('enroll request')) {
List cmds = zigbee.enrollResponse()
descMap = cmds?.collect { new hubitat.device.HubAction(it) }
}else if (description?.startsWith('catchall')) {
descMap = parseCatchAllMessage(description)
}else if (description?.startsWith('read attr')) {
descMap = zigbee.parseDescriptionAsMap(description)
if ((descMap?.cluster == "0500" && descMap.attrInt == 0x0001) && (descMap.value == '0028')){ //Zone Type
log.debug "Zone Type is Fire Sensor"
}else if ((descMap?.cluster == "0500" && descMap.attrInt == 0x0000) && (descMap.value == '01')){ //Zone State
log.debug "Zone State is enrolled"
}else if ((descMap?.cluster == "0500" && descMap.attrInt == 0x0002) && ((descMap.value == '20') || (descMap.value == '0020'))){ //Zone Status Clear
SmokeOrClear("clear")
}else if ((descMap?.cluster == "0500" && descMap.attrInt == 0x0002) && ((descMap.value == '30') || (descMap.value == '0030'))){ //Zone Status Clear
}else if ((descMap?.cluster == "0500" && descMap.attrInt == 0x0002) && ((descMap.value == '0031') || (descMap.value == '0021'))){ //Zone Status Smoke
SmokeOrClear("detected")
}else if ((descMap?.cluster == "0502" && descMap.attrInt == 0x0000)){ //Alarm Max Duration
def int alarmMinutes = Integer.parseInt(descMap.value,16)
log.debug "Max Alarm Duration is ${alarmMinutes} seconds"
}else if ((descMap?.cluster == "0000" && descMap.attrInt == 0x0007) && ((descMap.value == '03') )){ //PowerSource
log.debug "${device.displayName} is Battery Powered"
}else if ((descMap?.cluster == "0001" && descMap.attrInt == 0x0020)) { //Battery Voltage
def batteryVoltage = ConvertHexValue(descMap.value)
handleBatteryEvent(batteryVoltage)
}else if ((descMap?.cluster == "0001" && descMap.attrInt == 0x0033)) { //Battery Cells
def batteryCells = ConvertHexValue(descMap.value)
handleCellsEvent(batteryCells)
}else if ((descMap?.cluster == "0001" && descMap.attrInt == 0x0021)) { //Battery Percentage Remaining
// -- Ignore Attribute
}else if (descMap?.cluster == "0000" && descMap.attrInt == 0x0004){ //Manufacture
sendEvent(name: "manufacture", value: descMap.value)
log.debug "Manufacturer is ${descMap.value}"
}else if (descMap?.cluster == "0000" && descMap.attrInt == 0x0005){ //Model
sendEvent(name: "model", value: descMap.value)
log.debug "Model is ${descMap.value}"
}else {log.debug "Unknown --> Cluster-> ${descMap?.cluster} AttrInt-> ${descMap.attrInt} Value-> ${descMap.value}"
// log.debug "Cluster-> ${descMap?.cluster} AttrInt-> ${descMap.attrInt} Value-> ${descMap.value}"
}else {
log.debug "Unparsed -> $description"
// log.debug "$descMap"
return descMap
private parseCatchAllMessage(String description) {
Map resultMap = [:]
def descMap = zigbee.parse(description)
if (shouldProcessMessage(descMap)) {
log.debug descMap.inspect()
return resultMap
private boolean shouldProcessMessage(cluster) {
// 0x0B is default response indicating message got through
// 0x07 is bind message
// 0x04 - No Idea !!!!!
boolean ignoredMessage = cluster.profileId != 0x0104 ||
cluster.command == 0x0B ||
cluster.command == 0x07 ||
cluster.command == 0x04 ||
(cluster.data.size() > 0 && cluster.data.first() == 0x3e)
return !ignoredMessage
def refresh() {
log.debug "Refreshing..."
def refreshCmds = []
refreshCmds +=
zigbee.readAttribute(0x0500, 0x0001) + // IAS ZoneType
zigbee.readAttribute(0x0500, 0x0000) + // IAS ZoneState
zigbee.readAttribute(0x0500, 0x0002) + // IAS ZoneStatus
zigbee.readAttribute(0x0502, 0x0000) + // Alarm Max Duration
zigbee.readAttribute(0x0000, 0x0007) + // Power Source
zigbee.readAttribute(0x0001, 0x0020) + // Battery Voltage
zigbee.readAttribute(0x0001, 0x0033) + // Battery Cells
zigbee.readAttribute(0x0000, 0x0004) + // Manufacturer Name
zigbee.readAttribute(0x0000, 0x0005) + // Model Indentification
return refreshCmds
def configure() {
log.debug "Configuring..."
if (!device.currentState('batteryLastReplaced')?.value)
resetBatteryReplacedDate(true)
def cmds = [
// Bindings
"zdo bind 0x${device.deviceNetworkId} 1 1 0x0500 {${device.zigbeeId}} {}", "delay 200"
// cmds += zigbee.enrollResponse(1200)
cmds += zigbee.enrollResponse()
cmds += zigbee.configureReporting(0x0500, 0x0002, 0x19, 0, 3600, 0x00)
cmds += zigbee.configureReporting(0x0001, 0x0020, 0x20, 600, 7200, 0x01)
return cmds + refresh()
def resetBatteryReplacedDate(paired) {
def newlyPaired = paired ? " for newly paired sensor" : ""
sendEvent(name: "batteryLastReplaced", value: new Date())
log.debug "${device.displayName} Setting Battery Last Replaced to Current date${newlyPaired}"
def resetSensorTestedDate() {
def newlyTested=""
sendEvent(name: "sensorLastTested", value: new Date())
log.debug "${device.displayName} Setting Sensor Last Tested to Current date${newlyTested}"
def resetToClear() {
sendEvent(name:"smoke", value:"clear")
sendEvent(name: "lastStatus", value: new Date(), displayed: True)
log.debug "Resetting to Clear..."
didWeGetClear = 0
* Code borrowed (mixed and matched) from both Daniel Terryn and veeceeoh
* Create battery event from reported battery voltage.
private handleBatteryEvent(rawVolts) {
rawVolts = rawVolts / 10.0
def minVolts = voltsmin ? voltsmin : 2.5
def maxVolts = voltsmax ? voltsmax : 3.0
def pct = (rawVolts - minVolts) / (maxVolts - minVolts)
def roundedPct = Math.min(100, Math.round(pct * 100))
log.debug "Battery level is ${roundedPct}% (${rawVolts} Volts)"
sendEvent(name:"battery", value: roundedPct, unit: "%", isStateChange: true)
return
private handleCellsEvent(noCells) {
log.debug "Battery reports that it has (${noCells} Cells)"
return
def ConvertHexValue(value) {
if (value != null)
return Math.round(Integer.parseInt(value, 16))
def SmokeOrClear(value) {
if (value == "clear") {
sendEvent(name:"smoke", value:"clear", isStateChange: true)
log.info "${device.displayName} reports status is all clear"
} else {
sendEvent(name:"smoke", value:"detected", isStateChange: true)
log.info "${device.displayName} reports smoke is detected"
private Map parseIasMessage(String description) {
// log.debug "Zone Status Received--> ${description}"
ZoneStatus zs = zigbee.parseZoneStatus(description)
translateZoneStatus(zs)
private Map translateZoneStatus(ZoneStatus zs) {
// Some sensor models that use this DTH use alarm1 and some use alarm2 to signify motion
return getSmokeResult(zs.isAlarm1Set() || zs.isAlarm2Set())
private Map getSmokeResult(value) {
if (value) {
if (SensorTest == "") {
SensorTest = "1" // Default is Yes
if (SensorTest == "1") {
def descriptionText = "${device.displayName} status is pending"
log.debug descriptionText
runIn(3,EventOrTest)
return [
value : 'pending',
isStateChange: false,
descriptionText : descriptionText
} else {
def descriptionText = "${device.displayName} testing disabled - smoke detected !!!"
return [
value : 'detected',
isStateChange: true,
} else {
def descriptionText = "${device.displayName} all clear"
return [
value : 'clear',
def EventOrTest() {
if (device.currentValue("smoke") == "clear") {
log.debug "${device.displayName} was tested sucessfully"
} else {
log.debug "${device.displayName} This was not a test - smoke detected !!!"
sendEvent(name:"smoke", value:"detected")
