Groups and Scenes
Now that's funny. I knew if I didn't put this feature in it would be an almost immediate request that somebody would make.
We don't have a way to hide devices.
There is no harm in removing the capture device. But, it will be created every time you hit Done though. I can make the adding of a capture device an option, instead of automatic.
Yes, the "aquarium scene night on" is the rogue scene that doesn't exist. It even lets me select but obviously throws errors if I execute the rule.
OK, then there's a bug somewhere with the delete scene logic. I'll look for it... Thanks for reporting it.
Yep. Just found that out for myself. Would like that hide feature please.
I'm also in a bit of a situation here from experimenting. I just tried a scene where I took five Hue lights individually and tried the scene. That gave me a popcorn effect, so I left two of the bulbs individually set and then changed the three bulb fixture to include the Hue group for those lights and then manually adjusted the scene so that group is set to ON. In the apps list for that group, it shows (Not Set).
I toggled the group on and the Hue group turned on steady but one of the individually defined lights that are part of that group are currently flickering on an off very rapidly. The log is recording the rapid ON/OFF, but only for one of those two affected lights.
I clicked on info in one of the affected lights and it stopped. Weird.
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:49.039 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:48.710 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:48.623 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:48.573 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:48.297 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:48.178 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:47.986 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:47.904 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:47.768 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:47.687 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:47.417 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:47.360 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:47.276 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:47.135 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:46.985 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:46.889 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:46.825 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:46.655 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:46.460 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:46.226 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:46.182 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:46.086 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:45.699 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:45.692 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:45.680 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:45.540 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:45.380 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:44.371 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:44.328 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:44.310 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:44.184 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:43.821 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:43.644 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:43.634 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:43.615 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:43.327 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:42.841 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:42.676 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:42.674 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:42.548 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:42.097 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:41.993 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:41.938 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:41.931 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:41.852 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:41.445 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:41.376 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:41.358 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:1648](http://192.168.0.113/logs#dev1648)2018-11-29 12:01:41.166 pm [warn](http://192.168.0.113/device/edit/1648)No connection!
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:41.125 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:40.729 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:40.595 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:40.590 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:40.545 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:40.451 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:40.117 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:40.049 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:40.026 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:39.974 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:39.645 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:39.505 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:39.489 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:39.431 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:39.381 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:39.234 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:39.079 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:39.002 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:38.902 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:38.625 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:38.612 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:38.497 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:38.378 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:38.181 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:38.033 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:37.992 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:37.767 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:37.644 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:37.594 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:37.478 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:37.324 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:37.270 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:37.090 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:37.033 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:36.909 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:36.667 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:36.540 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:36.522 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:36.468 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:36.453 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:36.083 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:35.985 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:35.903 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:35.886 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:35.633 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:35.607 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:35.442 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:35.430 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:35.291 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:34.996 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:34.866 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:34.858 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:34.788 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:34.468 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:34.355 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:34.238 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:34.206 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:34.131 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:33.748 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:33.746 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:33.640 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:33.632 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:33.306 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:33.269 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:33.205 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:33.076 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:33.007 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:32.590 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:32.539 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:32.518 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:32.500 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:32.221 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:32.128 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:32.072 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:32.018 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:31.974 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:31.566 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:31.437 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:31.424 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:31.415 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:31.149 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:30.931 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:30.821 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:30.810 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:30.682 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:30.427 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:30.338 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:30.309 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:30.140 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:29.885 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:29.756 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:29.747 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:29.718 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:29.509 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:29.016 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:28.910 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:28.844 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:28.747 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:28.314 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:28.313 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:28.246 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:28.237 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:28.235 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:27.823 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:27.608 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:27.587 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:27.547 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:27.269 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:27.170 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:27.114 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:26.897 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:26.814 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:26.679 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:26.538 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:26.433 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:26.168 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:26.050 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:26.040 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:26.015 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:25.887 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:25.695 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:25.513 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:25.477 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:25.307 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:25.055 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:24.945 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:24.922 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:24.774 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:24.764 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:24.459 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:24.391 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:24.327 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:24.297 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:23.964 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:23.880 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:23.761 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:23.759 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:23.696 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:23.260 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:23.245 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:23.152 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:23.134 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:22.759 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:22.654 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:22.508 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:22.387 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:22.254 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:22.085 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:22.056 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:21.700 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:21.693 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:21.408 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:21.292 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:21.241 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:21.130 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:21.114 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:20.910 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:20.603 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:20.598 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:20.474 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:20.452 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:20.040 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:19.958 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:19.818 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:19.810 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:19.732 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:19.151 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:19.057 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:19.042 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:19.019 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:18.613 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:18.569 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:18.404 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:18.319 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:18.178 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:17.763 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:17.566 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:17.558 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:17.519 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:17.047 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:17.002 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:16.992 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:16.892 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:16.884 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:16.417 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:16.307 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:16.224 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:16.086 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:16.069 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:16.063 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:15.598 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:15.399 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:15.383 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:15.348 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:15.271 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:15.243 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:14.955 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:14.756 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:14.751 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:14.581 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:14.551 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:14.526 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:14.122 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:13.951 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:13.923 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:13.742 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:13.708 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:13.534 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:13.501 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:13.254 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:13.082 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:13.064 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:13.042 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:12.808 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:12.224 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:11.836 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:11.772 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:11.651 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:11.493 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:11.320 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:11.019 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:11.001 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:10.856 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:10.782 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:10.670 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:10.514 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:10.196 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:10.090 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:09.951 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:09.635 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:09.548 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:09.512 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:09.276 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:09.256 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:09.074 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:08.864 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:08.653 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:08.571 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:08.497 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:08.352 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:08.315 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:08.178 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:08.030 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:08.026 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:07.929 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:07.717 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:07.596 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:07.551 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:07.470 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:07.273 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:07.121 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:07.084 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:06.947 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:06.859 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:06.503 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:06.384 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:06.364 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:06.266 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:06.220 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:06.089 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:05.810 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:05.714 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:05.524 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:05.425 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:05.304 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:05.097 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:04.869 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:04.859 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:04.839 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:04.694 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:04.641 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:04.296 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:04.065 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:04.009 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:04.006 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:03.925 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:03.874 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:03.408 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:03.348 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:03.330 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:03.220 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:03.076 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:03.045 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:02.924 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:02.693 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:311](http://192.168.0.113/logs#dev311)2018-11-29 12:01:02.642 pm [info](http://192.168.0.113/device/edit/311)Closet lamp 1 was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:02.521 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:02.304 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned on
[dev:2325](http://192.168.0.113/logs#dev2325)2018-11-29 12:01:02.297 pm [info](http://192.168.0.113/device/edit/2325)Bedroom was turned off
I am seeing the same thing.
Do me a favor, and show me the app status for the parent app, Groups and Scenes.
My phantom scene still shows up as "ON" in my groups/scenes parent app.
Thanks. That's what I needed to see. Will chase this down. When you remove a Scene, it's supposed to be removed from that list. That list is what drives the UI in other apps.
Wow, this is a persistent little bugger. I just deleted Group and Scenes app and re-installed. After rebuilding my groups and scenes I confirmed that the "rogue" scenes are no longer listed in the app details page, but they're still showing up in RM under activate scene.
That's interesting. Thanks. Deeper problem.
Please look at that state again in the App Status for the parent.
It's now blank, which is correct since I don't have any scenes installed at this point. But the old ones are still showing within the RM rules.
Oh, well then create a Scene. I think once you do the old one will go bye-bye. Let me know.
The feature to make the capture device optional will be in the upcoming hot fix release.
Yes, I just created a "test" scene and it did make the other scenes disappear. Of course, now I'm stuck with this "test" scene until the bug is squashed :wink: but that's fine, just glad I can help pinpoint it.
If I have a group of lights (bulbs and lutron dimmers connected to recessed lights) I can group them together and then create a virtual switch to turn them on and off - is the the general idea?
If I have a group of lights (bulbs and lutron dimmers connected to recessed lights) I can create a scene with them. Then create a virtual button to activate the scenes?
Sorry I know this is all simple stuff - but for some reason I'm not grasping it or making it too complicated.
I think I just want to deal with Scenes because I'm all about perfect lighting control/color/levels etc ... so I usually have about 4 different scenes setup per room Day, Night, Relax and one other based on room. I want to call those scenes.
Is there any reason or use case for using groups over scenes or can they even be used together?
The apps Group and Scene create these virtual devices for you. In each case, the device has the same name as the Group or Scene.
In the case of Group, it's called a Group Bulb Dimmer. This devices supports the full range of attributes of an RGBW bulb, of which Color Temperature bulb, dimmer, and switch are all subsets. So the virtual device can represent and control any light device or switch.
In the case of Scene, it's called a Scene Activator. This device is both a button and a switch. Turning on the switch activates the Scene, as does pushing the button. Turning off the switch turns off all of the lights and switches in the Scene, but this can be disabled. The switch also reflects in its on/off state whether the Scene is fully activated or not.
As to whether you want Scenes or Groups: In a Group, all of the devices change to exactly the same setting -- whatever the master Group Bulb Dimmer is set to. In a Scene, each device has its own setting (which may vary) that is captured, and activating the Scene makes the devices go to that captured setting.
Ok - I see - so in my case I think scenes are the way to go since I want different bulbs, recessed lights set differently.
Only problem I am seeing is popcorn effect going on - 1 between bulbs and dimmers (expected) but bulbs are also popcorning. I will have to investigate if fixable at all.
Thank you!!
If you have Hue lighting, select the Hue Rooms under "Select Bulbs for Group". This is the same place you would select bulbs directly connected to the HE hub.
If you're dealing with directly connected bulbs, you may be able to eliminate the popcorn effect by first adding the bulbs to a Group and then turn on the Zigbee Group Messaging option. If your bulbs support Zigbee Multicasting, this may help eliminate the issue. Then add the Hubitat Group to your Hubitat Scene under "Select Bulbs for Scene".
NOTE: The Zigbee group messaging option is only for directly connected bulbs, not hue bulbs, since the Hue Bridge already supports that when you create Rooms in the Hue app. Some bulbs simply don't support Zigbee multicasting and this option may have no effect.
I'm not 100% positive, but it might be an issue if you combine the Zigbee group messaging option with Hue Rooms, so in that case I would make a separate group for any directly connected bulbs with that option enabled and combine Hubitat Groups and Hue Rooms together in your Hubitat Scene.
However, I could be wrong about that and it many not be an issue to have Zigbee Group Messaging enabled when Hue Rooms are also selected. @bravenel can you weigh in please with the correct answer?
