Just recently, my log is getting filled with messages about attribute button with too many characters.
How do I figure out which dashboard and button tile is causing the issue?
I only have two dashboards, a master dashboard and a virtual keypad. This happened as soon as I tried integrating the virtual keypad into the main dash board. I removed it once I started getting these in the log, but the error messages have not stopped.
Something is trying to display more than 1024 on a tile on one of your dashboards. Normally I attribute it to @thebearmay Hub Information Driver, but the old one, not version 3.0.
This is very strange. I have no buttons that are not properly working or displaying a "?". I have no tiles with a lot of text on them either, except the Hub Info tile which is displaying just fine... Is there anyway to extract exactly which tile is making the dashboard angry?
I don't have a dashboard called "Mobile App Manager"..... I was assuming that was an internal app that somehow relates to the dashboard connection on the mobile phone app.
I've had a similar issue on my setup for a very long time. I thought it was one of the apps (tile master?) by bptworld but he blew me off in pretty short order and I haven't bothered to dig deeper.
app 3 is the Hubitat Dashboard app
I do have a few of thebearmay apps and drivers installed though not all in use, but can't identify anything that's not working.
So the clue is in the attribute name list1, and I can tell you without any hesitancy none of the apps/devices that you have in the images there use that attribute. A second clue is that apps don't have attributes, therefore you are looking for a device that contains an attribute named list1.
One way of finding would be to use the Device Data Item Display app ([Release] Device Data Item Display), select every device and then go down to the Select states to display section, only select list1, and then click Display Data - the only devices that will be displayed will be the ones that have that attribute.
I did just do a quick check and I was using the old hub information driver in a device. I changed that to the V3 driver and removed the older one. I will keep looking...
