GoControl GD00Z-8
The screaming is normal when Z-WaveJS does the re-interview the first time. Btw, when you unplug and replug, you need to manually cycle the door using the button on the wall. This is required by UL.
FWIW, if you want a driver that gives you a bit more info (like sensor battery alerts and UL lockout), I have a driver you can read about here:
