Getting error when adding Shelly UNI driver
Am working on a project to automate my daughters "stair chair" (she's disabled, it's the chair that goes up/down the stairs to her apartment in the basement) -- the Shelly UNI looked perfect.
Use Case: Need to "press" an UP or DOWN button on the stair chair's remote control box -- bought a spare one to hack up -- originally was going to use a pair of Switchbots -- but the UNI looked so much cleaner
Reading through the community, it looked like adding the @tomw community driver would be quick and dirty. I think I'm doing it right.
Doing "Main Menu / Drivers Code / New Driver / Import " -- then using the GitHub link for the driver
( https://raw.githubusercontent.com/tomwpublic/shelly_experimental/main/packageManifest.json )
Code imports. Click "save"
That's when I get this message
What am I doing wrong?
The JSON you linked to is used for an app called Hubitat Package Manager and is not used to manually install the app.
You will probably be ok just using the built in "Shelly Wifi Switch"
Go to "Devices" -> Add Device -> Click on Virtual -> Fill out "Device Name" -> Select "Shelly Wifi Switch" from the "Type" dropdown -> Click Save
Well, I feel stupid (wrong file!) -- I use HPM all the time. NEVER knew there was an option "way down there" to install something using a "manifest" thingy.
That worked great!!!! I've got a Shelly UNI driver available now
I think I'll need the specific UNI driver as it has TWO "switches" on it.
Yes, that is meant for HPM usage. For anyone else, instructions and some other discussion are here: Vote for Shelly UNI - #16 by tomw
I'm glad you got it working! Let me know in the other thread if you have any questions or issues.
