danabw
August 27, 2023, 6:47pm
14
As long as you're looking at your GE dimmers, I prefer @JasonJoel 's drivers, more options and settings, zero issues. (Unrelated to pre-staging, which I don't use, but wanted to mention in general.)
GE/Jasco Z-Wave Plus Dimmer Driver
I got tired of the generic built-in driver missing features that are on the GE/Jasco dimmers. This was derived from the ST device handler, but mostly re-written at this point as there were a number of problems with the one I started with.
NOTE 1: This is for the toggle/paddle GE/Jasco Z-Wave Plus Dimmers only. It will not work with the non Z-Wave Plus models (12xxx), it will not work with any non-dimmer model, and it will not work with the Motion Dimmer (2693…
GE Enbrighten Z-Wave Plus Dimmer Driver
The new GE Enbrighten devices are just different enough from the old that I wanted to make a new driver that supported the features correctly.
NOTE: This is for the toggle/paddle GE Enbrighten Z-Wave Plus Dimmers only (ZW3010 / 46203 / 46564). It will not work with any non Z-Wave Plus GE models (12xxx), it will not work correctly with any other Z-Wave Plus GE models (14xxx).
Features:
ON/OFF/Level
Can set default ON %, both by a parameter setting and …
GE/Jasco Z-Wave Plus Motion Dimmer Driver
This is a driver for the GE Motion Dimmer device. It differs from the in-box driver in that it exposes all of the device parameters, and uses a parent/child structure to put the dimmer and motion sensors in their own child devices.
It has been tested with a GE 26933 motion dimmer.
Example:
[image]
Features:
ON/OFF
Configuration of button inversion variable.
Configuration of motion and light parameters.
Light Off Time, Motion sensor on/off, Mo…
GE/Jasco Z-Wave Plus Motion Dimmer Combo Driver
This is a driver for the GE Motion Dimmer device (26933). It differs from the in-box driver in that it exposes all of the device parameters, and can optionally create child devices for the dimmer and motion sensor.
Features:
All device parameters exposed
Light Off Time, Motion sensor on/off, Motion sens…
