@mike.maxwell Here is the "ported" code for these devices that I have currently working with hubitat. Thought you might want to take a look to see if there is something specific you would need to do to make it work with the "generic" z-wave driver or if you would like I could mail (I have several I'm not using at this time) one of these to you if you wanted to make a "system" driver using a real sample.
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* GE Portable Smart Motion Sensor adapted from Generic Z-Wave Motion Sensor
* Credit to smartthings jwillaz for the original smartthings adaption.
metadata {
definition (name: "GE Portable Smart Motion Sensor", namespace: "hubitat", author: "halfrican.ak", ocfDeviceType: "x.com.st.d.sensor.motion") {
capability "Motion Sensor"
capability "Sensor"
capability "Battery"
capability "Health Check"
capability "Configuration"
fingerprint deviceId: "3133", inClusters: "0x5E,0x86,0x72,0x59,0x85,0x73,0x71,0x80,0x30,0x70,0x7A,0x5A", outClusters:"", mfr: "0063", prod: "4953", deviceJoinName: "GE Portable Smart Motion Sensor USB"
fingerprint deviceId: "3133", inClusters: "0x5E,0x86,0x72,0x59,0x85,0x73,0x71,0x84,0x80,0x30,0x70,0x7A,0x5A", outClusters:"", mfr: "0063", prod: "4953", deviceJoinName: "GE Portable Smart Motion Sensor Battery"
preferences {
input "parameterSix", "number", title: "Enable/Disable PIR Sensor: default=1, 0=Disabled, 1=Enabled", defaultValue: 1, range: "0..1", required: false, displayDuringSetup: true
input "parameterThirteen", "number", title: "PIR Sensitivity: default=3, 1=Low Sensitivity, 2=Medium Sensitivity, 3=High Sensitivity", defaultValue: 3, range: "1..3", required: false, displayDuringSetup: true
input "parameterEighteen", "number", title: "PIR Timeout Duration (minutes): default=1, 1-60", defaultValue: 1, range: "1..60", required: false, displayDuringSetup: true
input "parameterTwenty", "number", title: "Basic Set, Notification and Basic Report: default=1, 1=Notification, 2=Basic Set, 3=Basic Report", defaultValue: 1, range: "1..3", required: false, displayDuringSetup: true
input "parameterTwentyEight", "number", title: "Enable/Disable LED Flash Indicator: default=1, 0=Disable, 1=Enable", defaultValue: 1, range: "0..1", required: false, displayDuringSetup: true
def installed() {
// Device wakes up every 4 hours, this interval allows us to miss one wakeup notification before marking offline
sendEvent(name: "checkInterval", value: 8 * 60 * 60 + 2 * 60, displayed: false, data: [protocol: "zwave", hubHardwareId: device.hub.hardwareID])
def updated() {
response(configure())
private getCommandClassVersions() {
[0x20: 1, 0x30: 1, 0x31: 5, 0x80: 1, 0x84: 1, 0x71: 3, 0x9C: 1]
def result = null
if (description.startsWith("Err")) {
result = createEvent(descriptionText:description)
} else {
def cmd = zwave.parse(description, commandClassVersions)
if (cmd) {
result = zwaveEvent(cmd)
} else {
result = createEvent(value: description, descriptionText: description, isStateChange: false)
return result
def sensorValueEvent(value) {
if (value) {
createEvent(name: "motion", value: "active", descriptionText: "$device.displayName detected motion")
} else {
createEvent(name: "motion", value: "inactive", descriptionText: "$device.displayName motion has stopped")
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicReport cmd)
sensorValueEvent(cmd.value)
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicSet cmd)
def zwaveEvent(hubitat.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd)
def zwaveEvent(hubitat.zwave.commands.sensorbinaryv1.SensorBinaryReport cmd)
sensorValueEvent(cmd.sensorValue)
def zwaveEvent(hubitat.zwave.commands.sensoralarmv1.SensorAlarmReport cmd)
sensorValueEvent(cmd.sensorState)
def zwaveEvent(hubitat.zwave.commands.notificationv3.NotificationReport cmd)
def result = []
if (cmd.notificationType == 0x07) {
if (cmd.v1AlarmType == 0x07) { // special case for nonstandard messages from Monoprice ensors
result << sensorValueEvent(cmd.v1AlarmLevel)
} else if (cmd.event == 0x01 || cmd.event == 0x02 || cmd.event == 0x07 || cmd.event == 0x08) {
result << sensorValueEvent(1)
} else if (cmd.event == 0x00) {
result << sensorValueEvent(0)
} else if (cmd.event == 0x03) {
result << createEvent(name: "tamper", value: "detected", descriptionText: "$device.displayName covering was removed", isStateChange: true)
result << response(zwave.batteryV1.batteryGet())
} else if (cmd.event == 0x05 || cmd.event == 0x06) {
result << createEvent(descriptionText: "$device.displayName detected glass breakage", isStateChange: true)
} else if (cmd.notificationType) {
def text = "Notification $cmd.notificationType: event ${([cmd.event] + cmd.eventParameter).join(", ")}"
result << createEvent(name: "notification$cmd.notificationType", value: "$cmd.event", descriptionText: text, isStateChange: true, displayed: false)
} else {
def value = cmd.v1AlarmLevel == 255 ? "active" : cmd.v1AlarmLevel ?: "inactive"
result << createEvent(name: "alarm $cmd.v1AlarmType", value: value, isStateChange: true, displayed: false)
result
def zwaveEvent(hubitat.zwave.commands.wakeupv1.WakeUpNotification cmd)
def result = [createEvent(descriptionText: "${device.displayName} woke up", isStateChange: false)]
if (state.MSR == "011A-0601-0901" && device.currentState('motion') == null) { // Enerwave motion doesn't always get the associationSet that the hub sends on join
result << response(zwave.associationV1.associationSet(groupingIdentifier:1, nodeId:zwaveHubNodeId))
if (!state.lastbat || (new Date().time) - state.lastbat > 53*60*60*1000) {
} else {
result << response(zwave.wakeUpV1.wakeUpNoMoreInformation())
result
def zwaveEvent(hubitat.zwave.commands.batteryv1.BatteryReport cmd) {
def map = [ name: "battery", unit: "%" ]
if (cmd.batteryLevel == 0xFF) {
map.value = 1
map.descriptionText = "${device.displayName} has a low battery"
map.isStateChange = true
} else {
map.value = cmd.batteryLevel
state.lastbat = new Date().time
[createEvent(map), response(zwave.wakeUpV1.wakeUpNoMoreInformation())]
def zwaveEvent(hubitat.zwave.commands.sensormultilevelv5.SensorMultilevelReport cmd)
def map = [ displayed: true, value: cmd.scaledSensorValue.toString() ]
switch (cmd.sensorType) {
case 1:
map.name = "temperature"
map.unit = cmd.scale == 1 ? "F" : "C"
break;
case 3:
map.name = "illuminance"
map.value = cmd.scaledSensorValue.toInteger().toString()
map.unit = "lux"
break;
case 5:
map.name = "humidity"
map.unit = cmd.scale == 0 ? "%" : ""
break;
case 0x1E:
map.name = "loudness"
map.unit = cmd.scale == 1 ? "dBA" : "dB"
break;
createEvent(map)
def zwaveEvent(hubitat.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
def encapsulatedCommand = cmd.encapsulatedCommand(commandClassVersions)
// log.debug "encapsulated: $encapsulatedCommand"
if (encapsulatedCommand) {
state.sec = 1
zwaveEvent(encapsulatedCommand)
def zwaveEvent(hubitat.zwave.commands.crc16encapv1.Crc16Encap cmd)
// def encapsulatedCommand = cmd.encapsulatedCommand(commandClassVersions)
def version = commandClassVersions[cmd.commandClass as Integer]
def ccObj = version ? zwave.commandClass(cmd.commandClass, version) : zwave.commandClass(cmd.commandClass)
def encapsulatedCommand = ccObj?.command(cmd.command)?.parse(cmd.data)
return zwaveEvent(encapsulatedCommand)
def zwaveEvent(hubitat.zwave.commands.multichannelv3.MultiChannelCmdEncap cmd) {
def result = null
log.debug "Command from endpoint ${cmd.sourceEndPoint}: ${encapsulatedCommand}"
result = zwaveEvent(encapsulatedCommand)
result
def zwaveEvent(hubitat.zwave.commands.multicmdv1.MultiCmdEncap cmd) {
log.debug "MultiCmd with $numberOfCommands inner commands"
cmd.encapsulatedCommands(commandClassVersions).collect { encapsulatedCommand ->
}.flatten()
def zwaveEvent(hubitat.zwave.Command cmd) {
createEvent(descriptionText: "$device.displayName: $cmd", displayed: false)
def zwaveEvent(hubitat.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
def result = []
def msr = String.format("%04X-%04X-%04X", cmd.manufacturerId, cmd.productTypeId, cmd.productId)
log.debug "msr: $msr"
updateDataValue("MSR", msr)
result << createEvent(descriptionText: "$device.displayName MSR: $msr", isStateChange: false)
result
def configure() {
log.debug("Adjusting parameters...")
return delayBetween([
zwave.configurationV1.configurationSet(scaledConfigurationValue: parameterSix, parameterNumber: 6, size: 1).format(),
zwave.configurationV1.configurationSet(scaledConfigurationValue: parameterThirteen, parameterNumber: 13, size: 1).format(),
zwave.configurationV1.configurationSet(scaledConfigurationValue: parameterEighteen, parameterNumber: 18, size: 1).format(),
zwave.configurationV1.configurationSet(scaledConfigurationValue: parameterTwenty, parameterNumber: 20, size: 1).format(),
zwave.configurationV1.configurationSet(scaledConfigurationValue: parameterTwentyEight, parameterNumber: 28, size: 1).format()
], 500)
