thats why that tie should be how long it actually takes for your garage door to close.. time it and adjust it.
It takes about 15 secs. Which is what I set in the app. But the icon changes to closed much quicker than that. Maybe I don't understand the sequence in the app? This is what I thought happened:
- Request close
- Wait run-in time (2 secs)
- Issue close command
- Change icon to closing.
5a, If door contact closes change icon to closed, or,
5b. If door contact not closed after timeout interval (15 secs) display error message?
what kind of contact senser you using if a tilt sensor it will change immeidatley when it senses the change in the contact.. i use a door sensor on the top of the garage door. .so it will not read closed until actually closed.
I use the microswitch the door opener uses to sense closed and turn off the drive. Connected via Konnected! So it also will not close until the door is closed.
I got a Samsung Zigbee multi sensor to show acceleration to the hub so it knows the door is still moving.
The Hubitat driver even has settings for using it with garage doors, minus the contact sensor part.
i just slightly updated the driver i have the runin set to 6 and it works fine.. says closing for 6 secs then changes..
this is the correct virtual garage door device handler that goes along with the app
and this is the app
the other garage door device in my github was to add switch capability to a stock driver so i could control it in alexa..
OK, first I didn't notice that there are 2 run-in values in the driver, one for opening and one for closing.
Now the problems this:
When I open the door the icon changes to opening immediately and stays that way for the run-in time. Then the icon changes to open and the command to open the door gets issued!
Similarly when I try to close the door, I get the closing icon for the run-in time. After that the icon changes to closed and the command to close the door gets issued.
In both cases I need the command to the physical door opener to be issued immediately.
(Maybe some people would like a delay but that should be a separate parameter )
Hope this makes sense.
mine is not working that way are you using my smartapp and my device handler..
mine starts opening immediately and changes to opening the open once the runin time times out.
what are you settings in the app
You can see from the logs (one open cycle, followed by a closed cycle):
Open initiated at 4:17:54 (from Virt GDO events)
"opening real gd" at 4:18:04
Close initiated at 4:19:06
"closing real gd" at 4:19:16
Why is there a "contact is in closed state" at 4:19:16? (in the logs)
The log for "Garage Main" (the door sensor) is not closed until 4:19:29
In both cases we see 10sec delay, matching the run in value in the driver.
"Garage Main" is the contact on the door
"Virt GDO" is the virtual device
"Gdo driver" is the momentary switch that activates the door
Hi I have just installed this App and Driver to control as a test to control 1 of my garage doors. I am using a Shelly WiFi relay as my control for the door.
I have hit a problem the app and the driver seem to be working okay apart from they will not switch on the Shelly device.
The garage door reports it's open in both Alex and HomeKit but the door doesn't physically move.
Any ideas?
Thanks.
Does the door open when you trigger the device manually. If so post a screen shot of the configuration. The driver is not for the device. There should be 4 things installed an actually Shelly/switch device handler, an actual handfler for a garage door sensor . Both should be working before installing my app. Then the APp and Its accompanying virtual garage door device make up the last two.
Yes everything is working independently the door control was working with this app
https://community.hubitat.com/t/release-garage-opener-app-beta/37444
But it wasn't updating Alexa, HE or Homekit if the button was pressed manually your app does this but doesn't physically tell the Shelly to switch on (it is set to turn off after 1 second)
here is a screen shot of my app config:
your configuration is wrong it should be configured as follows the last two devices need to be the same
the open needs to be the physical shelly switch the sensor needs to be the physical sensor.
the last two BOTH need to be the virtual garage door device .. it says so right in the app..
ie
it also may not work with a mutli channel relay device as those were not even around when it was written.. actually it does because i am using a zen16 multi channel and it works fine.. hopefully setting up the settings right will fix it for you
Hi, That fixed it thanks both garage doors working correctly thanks to you App. Although it has highlighted anther issue with my setup....poor WiFi coverage in the garage door.
Thanks for your help.
Can we have a door movement duration option, please? This function actually delays opening or closing my door for the set duration which is not desirable for me.
I'd like an option to set how long the door should show opening/closing after the door has been triggered to open/close. eg 10 seconds
PS, Im running my garage door with a Fibaro Smart Implant and wired security contact sensor for open/close status. I also have a acceleration sensor on the door but am not using it with your app atm.
@kahn-hubitat one other item that would be a nice addition is to be able to specify a dedicated but optional acceleration sensor.
The other abandoned app/driver combo supports a mandatory acceleration sensor, however, the annoying thing about its implementation is there is no ability to specify door open close duration.
So despite having a dedicated open/close sensor, it doesn't show the opening/closing has completed until the acceleration sensor goes "inactive" which can take about 5 seconds longer than the door open/close does.
The door close time is exactly that. how long to wait before checking the sensor to see if the door is closed.. The issue with the runin time is due to the virtual garage device which really is not part of the app. Any virtual garage door device can be used. i just modified the existing smartthings one for convenience.. That is why i recommend just changing the runin time to whatever you like as you said it delays the actual execution.. i am not sure how a acceleration sensor would be used other than to let you know that the door is not working and alert you that it has not started moving.. What were you thinking?
do you mean the Timeout before checking if the door opened or closed correctly?
setting? Despite having it set to 10 seconds it shows open/closed almost immediately after the door starts moving.
It's useful to know that the door is actually moving. Most folk I suspect will only have an open/close contact sensor that reports closed and by inference as soon as the door moves away from the contact sensor it reports open even when the door is still moving.
It's not a big deal but just something I liked about the other app/driver ... aside from the sensor taking an extra 5 seconds to report the door is no longer moving.
