Hi everyone (1st post),
I'm remaking construction and im going to make electrical floor heating.
i went trough the "List of Compatible Devices" and the "Community Device Drivers" but somehow i couldn't find a floor heating thermostat which is compatible with Hubitat & Zigbee or LAN or Z-Wave (EU).
Do you guys know of any electrical floor heating thermostat that work with HE ?
I have it connected up to HE and while it's not yet connected to the floor to do its real job,, the device seems to be working talking fine to HE. It's Z-Wave+ using the Generic Thermostat Driver.
Heating is a gas boiler and rads. House has had rads since built 40 years or so ago. I have eTRV's on the rads - Z-Wave Danfoss LC-13's - I have the house zoned, with remote Z-Wave Horstrmann/IQE/Secure SRT321's (they are all the same device under different names). A Secure SSR302 dual Z-Wave switch is on the boiler (controlling 2 physical zones). A Secure SSR303 Z-Wave switch on the boiler controls the hot water. The hot water tank also has an immersion as a backup and it has a Secure SIR302 Z-Wave switch.
Today I'm playing with a zigbee Drayton Wiser eTRV trying to get it to work - a HE driver is an issue, I'm trying to get a SmartThings one to work. I find sometimes some of my Danfoss ones lose control of the valve and need to get re-calibrated onto the valve. If I can get better battery life that would be a plus.
Yep - I live in Ireland and USA - a few weeks here then a few weeks there, then a few weeks here...... They all go to 4 degrees when I go to USA, but frequently when I come back at random some have let loose and are no longer controlling the valve (but talking away happily to HE)....
Hi Anthony, maybe that thermostat could do that you are looking for ?
I bought that same thermostat some weeks ago but I haven't tested it yet with my electrical floor heating, but I have their other zigbee thermostats (TH1123ZB & TH1124ZB), and they work very well either with Hubitat and with their own platform (Neviweb). I don't know if they are compatible with your EU installation but it should. Feel free to contact the company in french, that company is in my home town and they are all french speakers
I have it all connected up - but that bathroom is not yet ready for use - I hope during November that we will move to our new bedroom and then that bathroom will be in action.
Good luck with your renovations, can you share your experiences once you really use it? As you may know there is not much offer of such thermostats to connect to the HE on the EU market
I'm just finishing an integration with the Heatmiser Neostat range of thermostats. I have everything working now, just want to drive up the reliability with custom commands.
This might be a good option for thermostats in the EU which I think are quite smart looking.
It's a ZigBee based communication protocol, but it's not documented for integration at the ZigBee level. They provide a hub which talks their ZigBee protocol and allows communication through standard IP network (WiFi/Ethernet), which is how my integration hooks up to all the stats on the house.
Yes, all the thermostats (regular stat, electric underfloor, wireless/battery stat, hot water) link back to the Neohub. It probably makes less sense if you only have a single thermostat, but if you have multiple then its a more useful integration. On the plus side it is still all local.
