I just got an mMwave Presence Sensor from Moes and using Tuya Zigbee 4 in 1 Sensor driver as indicated here:
I got the Moes Sensor here
https://www.aliexpress.com/item/1005004147995775.html
- endpointId: 01
- application: 44
- manufacturer: _TZE200_holel4dk
- model: TS0601
So I've set it this way
Q1:
I wanted to try to limit detection to 1m distance only and upon testing it it seems to be a hit or miss. Sometimes I'd be dancing near the sensor and motion isn't detected, or at least it takes a long way to trigger it - and SOMETIMES i was able to trigger it around 2.0m away! - which raises some reliability concerns. (I thought these mmwave sensors are super accurate)
Perhaps I've got it on wrong settings? Have I set it correctly?
Q2:
I'm not really sure what each setting means but are my following assumptions correct?
- Maximum Detection Distance = any movement beyond this setting wont trigger motion
- Minimum Detection Distance = any movement closer than this setting wont trigger motion
- Detection delay , seconds = movement must occur as long, or longer, than this setting
- Fading Time,Seconds = no movements must be detected within or longer than this setting to consider inactive (eg. no more motion)
- Radar Sensitivity = im not sure what this is really.
Q3
The problem I have is the lack of PET IMMUNE motion sensors for zigbee/zwave. (Motion sensors that get triggered only by large movements)
The analog 433mhz Alarm Systems have plenty of options for Pet Immune Motion sensors, but I've yet to find one for Zigbee.
I assumed that this cool mmwave motion sensor does the trick - and if so, how? What settings should I use?
Q4:
I thought we're able to narrow down the field of detection of these sensors - where do I set this?
Q5:
What is SetPar options for?
