I've tried that, but my system doesn't have that diagnostic Tool location.
When you're navigating to [your hub IP address]:8081, you are navigating to the diagnostic tool. Go there and post what version yours is at please.
Ahh. Ok. It doesn't have a version number anywhere on screen and I checked the source code, no hidden version number included.
Copyright 2018 if that helps.
Did you try browsing to http://[Your Hub IP]/hub/cloud/updateDiagnosticTool as the documentation page mentions?
Yeah, I've done that several times. It gives me the same connection refused message.
Really, just port 8081 connects. Nothing else seems to connect.
@tim.w.newsom Since you have a new C-4, your issue may be related to the link below. Not saying there's a fix here, but it's a likely explanation. If I remember correctly, support may need to do something on their end, but the hub should ultimately work. I'm almost positive there was another post somewhere saying how to handle this if the hub was never registered, but I can't find it now.
Great! That helps at least understand it, maybe. Lol
So, in Chrome dev tools, I can modify the web page that has the updater versions. If I knew the right code to put there, I could hack a submit that might perform the update.
But, that's pointless if the hub can't connect to cloud services in order to download the update.
I could host the update on my internal network update my internal dns so that it points to it... but I don't have the update file to host. Lol
Probably will need to have support help me resolve it.
Lol. There’s no reason to hack anything. Someone will reach out soon and get you on your way.
Sorry for this dumb question, but you did substitute your actual IP address for the brackets and where it says your IP, correct?
E.g. http://[Your Hub IP]/hub/cloud/updateDiagnosticTool
If your hub IP address was, for example 192.168.1.2, then the URL for you would be...
Hahaha. Yes. Love it.
Thanks for confirming
No worries. I spent the first part of my life in tech support for sound blaster.... so I totally understand where your question is coming from.
In that case, I guess I won't recommend the universal solution of rebooting.
Hahaha
Isn't it true that this won't work unless the platform is running already? Right now, AFAICT from @tim.w.newsom's description, there is nothing listening on TCP port 80.
If it cannot be done already, I think it would be great if there was a way to run the updateDiagnosticTool script from the Diagnostic Tool on port 8081.
The URL in the doc will update the tool, but IIRC there was a cut off where it doesn’t work if it’s too old. This is an edge case, so creating a documented procedure might not make sense.
Blue light on the C4 doesn’t indicate there’s no platform running. Not sure what the issue is. Going to need @bobbyD or @gopher.ny to assist.
Let's try a few of things here... replace hubs.ip.address.here with actual IP.
Run this in command prompt or terminal: curl -s -X POST http://hubs.ip.address.here:8081/api/getLatest
This might get the latest version of hub software. I'm saying might because we don't know what the diagnostics tool version is. -
There may be a reset screen at http://hubs.ip.address.here:8081/resetHub, see if that works. If there is a screen, it should give some options, please PM me a screenshot.
There also is a "last resort" URL at CENSORED ...
