No, and in looking at the logs, it senses the motion, it just doesn't turn on the light sometimes.
And just to be clear, I'm talking about some internal device function that turns the light on for motion, and turns it off after a period. Not an HE rule or function.
It might be related to the light levels. I expect the light only comes on when it is dark. How do you control the light? Do you set the level to 0 or do you turn off the switch? Using the switch might change the behavior.
Now you have me curious. I have a rule that turns the light on and off with motion. I have disabled that and will have to see how it behaves tonight. If thereās no way to turn off the auto light then that will put a hitch in my plans. I wanted to use it as a status light.
It would appear that you were right on the money. And, it would help if I would RTFM.
If I'm reading that correctly, it matches what I think I was seeing with regard to the 'local routine.' I didn't put it together until I read that, but I was confused the other night because the night light should have been 'off,' but the light-on-motion was working. I couldn't get the light-on-motion to work the next day, though. I was seeing the 12-hour window come into play.
I think you'll be fine. (ETA: I got it wrong twice three times.) Just disable the 'local routine' and your rule should run unencumbered and the light should never come on without a command.
I wonder if the 12 hour window after a command impacts the chatty behavior too? My sensor goes through periods of quiet alternating with periods of endless banter.
Would you please ask if the sensitivity can be set? I'm sitting about five feet in front of one and I have to wave my arms frantically to get it to trigger.
Most of the time I like the pet aware sensitivity of some sensors. In this case I am looking more for the sensitivity of an Iris V2. If it can't be configured then I don't mind that much but it would be good to have the manufacturer state what to expect. It seems to be a narrow detection cone with low sensitivity -- or did I just get a bad device?
I sent them a support request on Monday about my problem with the motion detection. I have not received any response from them. I am going to uninstall and return to Amazon when I get the time
I really want this to work, but I am quickly approaching this point. In addition to chattiness, I have observed a failure rate of about 20% in setting the appropriate light level. The device page reports as expected, so the physical light is intermittently failing to perform.
I was also getting alerts in the logs about the Location Events logs forāspammyDevicesā saying itās producing hundreds of events.
Iāve updated the firmware and that has sorta stopped for a few days.
But I had another oddity start up right after. The device would turn on the light from motion without a rule or anything.
Hitting āConfigureā seemed to have made that stop for the mean time.
Only thing I donāt like now is that from the Device Page you can only adjust the light properties, not motion or Lux.
Check several posts up in this thread. Sending commands to the light will disable the auto on/off for 12 hours. Seems to be a feature. Note the bolded text.
Was this firmware update issue ever solved (obviously, not solved, but maybe a workaround)? I just got one of these. It's on the version shown. There's an update to 48, but it won't work as shown below.... just keeps "starting"
I don't know if it was ever resolved. I never ended up using the device as planned. It just didn't have the coverage I was looking for and I never got a response on how the detection cone was setup (like the motion sensors show).
I have been thinking about using the nightlight functionality for another project but haven't moved it to the new hub yet.
Thanks for the suggestion. Tried this and a few other things. No luck yet. I've posted in Third Reality support forum to see if I can find any answers there.
I have the device on a C8p and clicking on Update does nothing. I can see regular events in the logs but if I try to update the firmware from the device page nothing is logged. I don't even get the "unable to update device" message.
What hub and firmware are you running? I'm on a C8p with 2.3.9.150.
I'm on C8p on 2.3.9.150 as well. This also happens to me on some attempts. I think I only get the multiple attempts after a re-pair of the night light or a power cycle of the hub.
No additional help yet from Third Reality support site. Here's the link if anyone wants to add on to see if we can get more attention on it (thanks @wiegout):
Worth a try. It seems like such a cool device if it worked... Other Third Reality devices are really good. And I updated the firmware on a Zigbee Smart Plug of theirs just yesterday and it went smooth as can be. This night light though...
Yeah, typically have a good experience with their products as well. The fact that the device settings don't allow you to prevent the light from turning on automatically for motion at night is a huge miss... a bit of a dumb smart device.
