Fibaro FGK-10x driver w/temp
I’m pretty sure now that the LED flashing for approx. 7 seconds is trying to indicate the battery is flat !
I just swapped out a known good battery, from a known good sensor, for a suspect one and the known good sensor is misbehaving and just flashing the LED.
Good battery in the unknown sensor = now able to reset the sensor and then include it into HE.
Under load (resetting or including ) the suspect battery was dropping WAY to low. Down to 2.8volts.
Well, after sending my Fibaro sensors on a little holiday to @njanda's house in Sydney, he did some fault-finding and indeed, as he pointed out, it's battery related. I've now managed to pair them with my HE and they are reporting fine. Big kudos and much thanks to @njanda for helping out. It saved the Fibaros from the trash can.
One thing I can't figure out is what device type to set for the tile on the dashboard. I can't seem to get the tile to report anything. I've also added the temp IC to the Fibaro, so would like to report that too. What are you all using as your device type for tiles?
So long as the device is assigned to the dashboard in Apps, You should then be able to go to your dashboard, then click the “+” to add a tile and select the device your adding and select contact sensor’ as the Template.
How can I get to work with FGK-10X? I've try built in driver for Windows/Door 2 but it doesn't work. I found that some one is using this driver but I really don't know how because door 1 and door 2 have different parameters?
@waynespringer79 - which firmware version do you have in FGK?
I just want to use it as temp sensor :frowning:
yes, I did exchange battery.
I have been using a FGK-101 with the external temperature probe. I am using the the Native Fibaro Door/Window Sensor 2 driver. I can add this to the discussion.
1] The probe must be installed before including the device.
2] The instructions for a factory rest differ from what I have read here.
The key here is both TMP buttons.
I leave it to you to figure out how to press 2 buttons and insert the battery at the same time. :confounded:
I used this reference:
My biggest complaint with it is it uses ER14250 ½ AA 3.6v battery.
Can't find any brand named replacement battery that ship in factory packaging. I am leery of batteries that come in a plastic zip bag. For this reason I will not buy any device that requires one of those batteries.
Had the same problems - most such batteries I tried purchasing from Amazon were not good. My best attempt so far was buying them from Tenergy via Ebay - still delivered in a bag, but with some kind of factory-looking label sealing it. These at least were not DOA.
I have two FGK-10x sensors, which were both working on my Vera. I can only get one of them to work properly with Hubitat - I begin to suspect the other sensor has much older firmware and is not compatible. I do see references to firmware 3.2 being "Z-Wave+ compatible" and older versions not. The working sensor pairs with my C7 with S0 security, the non-working one with "None".
I've tried to add the ST driver to hubitat and it did not work.
Then i found this guide on how to port a driver from ST to HE.
All i had to do is to replace " physicalgraph" with "hubitat" and then i could save the driver.
And after trying both the native Fibaro Door/Window Sensor 2 driver and JJ's Fibaro FGK driver with no results, this one works.
It reports Battery level, and contact state.
The sensor in use is FGK-101 v2.5 EU (SHS-FIB2801001)
door sensor
Oh wow! That worked for me too. The only thing missing is the temperature reporting. At least the contact state seems to be working fine. Thanks for explanation on how to port the driver over.
Did you uncomment line #38 ??
I dunno about the "tile" stuff....
No, I hadn't! Nice pickup, Nic. Sadly, still can't get it to report.
Have you still got your Fibaros? I can at least resurrect mine now as regular contacts although I'm kinda flush with contacts with the recent JB ST sale.
Yes I have 3 in service but I bought a 10 pack of Zigbee Ecolink door/window contacts AS WELL as dipping into the JB sale so let’s just say I have a few “spare”. He he he
It's a curse. I feel you. I have a giant box of 'spare' IoT stuff itching to find a place to put it. I admit, I have a problem and I may well need therapy, if I could find a support group. Hanging out here is like a drunk hanging out with a bunch of other drunks - it's not doing anything to cure my habit. :thinking:
We still NEED properly ported drivers for 1st gen Fibaro sensors. These are still around and when you find them at ~ 15$ they are a bargain.
The native Device Handlers from ST work pretty good (on ST). As well as the Z-Wave Tweaker from ST, but the Basic Z-Wave tool should work as well on HE. I've manage to change some parameters with it.
@bigrizz: if you have an ST hub and you also have Motion Sensors that do not work on HE, here is a temporary solution for integrating them into HE.
I also have loads of these, 9 I think. Most worked on ST.
I have found that FGK-10X fw 3.2 (i have 3) work with Fibaro Door/Window Sensor 2 & report temperature.
I have 1 that did work on JJ's ported ST driver. Now does not work.
I have 5 that I can not even include. Probably older 2.5 fw.
I'm referring to v2.5 - v2.7. I know v3.2 works fine with the native driver.
ok. I get back to problem.
The main problem with non ZW5 is with association (group 3 should be set to 1). I've change it and boom - I've got temp report but two problems - one with JJ's driver
java.lang.NullPointerException: Cannot invoke method multiply() on null object on line 597 (parse)
def zwaveEvent(hubitat.zwave.commands.versionv1.VersionReport cmd) {
    //updateDataValue("version", "${cmd.applicationVersion}.${cmd.applicationSubVersion}")
    log.debug "versionv1.VersionReport: ${cmd}"
    log.debug "applicationVersion:      ${cmd.applicationVersion}"
    log.debug "applicationSubVersion:   ${cmd.applicationSubVersion}"
    **LINE 597 -->** def deviceFirmwareVersion = (short) cmd.applicationVersion*1000 + cmd.applicationSubVersion*
    log.debug "deviceFirmwareVersion: ${deviceFirmwareVersion}"
    if (deviceFirmwareVersion >= 3002) {
        sendEvent(name: "ZW5", value: 1, isStateChange: true)
    } else {
        sendEvent(name: "ZW5", value: 0, isStateChange: true)
    sendEvent(name: "ZW5set", value: 1)
    log.debug "device.ZW5set: ${device.currentValue('ZW5set')}"
    log.debug "device.ZW5: ${device.currentValue('ZW5')}"
    return [response(wakeUpResponse([]))]
second - it reports temp changes only when I forced to wake up -> it is working now properly
Would you mind posting the full driver code that is working?
but when I hit configure I get some errors
     *  Fibaro Z-Wave FGK-101 Temperature & Door/Window Sensor Handler [v0.9.7.2, 9 July 2017]
     *  Copyright 2014 Jean-Jacques GUILLEMAUD
     *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
     *  in compliance with the License. You may obtain a copy of the License at:
     *      http://www.apache.org/licenses/LICENSE-2.0
     *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
     *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
     *  for the specific language governing permissions and limitations under the License.
    /* IMPORTANT : This custom Handler works both for Z-Wave+ (aka ZW5) versions of the FGK-101 Fibaro sensor,
    /*             as well as for pre-ZW5 versions of the FGK-101 hardware.
    /*             It takes about 1mn for the FGK-101 to fully configure itself after the first (manual or otherwise) wakeup.
 *	Fibaro Z-Wave FGK-101 Marketing Description is at :
 *		http://www.fibaro.com/en/the-fibaro-system/door-window-sensor
 *  Fibaro FGK-10x Operating Manuals and Z-Wave Alliance Certificates can be downloaded at :
 *		Z-Wave / Firmware <= 2.5 		: http://www.fibaro.com/files/instrukcje/eng/DoorWindowSensor%20FGK-101-107%20ENG_v21-v23.pdf
 *										: http://products.z-wavealliance.org/products/1077
 *		Z-Wave+ / ZW5 / Firmware >= 3.2 : http://manuals.fibaro.com/content/manuals/en/FGK-10x/FGK-10x-EN-T-v2.0.pdf
 *										: http://products.z-wavealliance.org/products/1620
 *	The current version of this Handler is parameterized to force Device's wakeup :
 *		- on any open<->closed state change
 *		- in case of Tampering Alarm triggering
 *		- every 60mn (wakeUpIntervalSet(seconds:60*60), hard coded)
 *		- whenever Temperature delta change since last report is greater than 0.3°C (Parameter#12 or #51, hard coded)
 *		- every 4h when Temperature does not change
 *		also :
 *		- Temperature is natively reported by sensor in Celsius (SensorMultilevelReport[scale:0]);
 *		  convertion is needed for Fahrenheit display
 *  A few specificities of this device that are relevant to better understand some parts of this Handler :
 *		- it is a battery operated device, so Commands can only be sent to it whenever it wakes up
 *		- it is a multi-channel Device (pre-ZW5), and the multi-level temperature sensor reports only from EndPoint#2
 *		- specific configurable parameters are documented in the above Operating Manuals
 *		- some of those parameters must be modified to activate the anti-Tampering Alarm
 *		- some of the "scaffolding" has been left in place as comments, since it may help other people to understand/modify this Handler
 *		- BEWARE : the optional DS18B20 temperature sensor must be connected BEFORE the Device is activated (otherwise, reset the Device)
 *		- IMPORTANT : for debugging purpose, it is much better to change the wake-up period from the default 60mn to 1mn or so;
 *					but unless you force the early wake up of the sensor (forcing open/closed for instance), you will have to
 *					wait up to 60mn for the new value to become effective.
 * Z-Wave Device Class: GENERIC_TYPE_SENSOR_BINARY / SPECIFIC_TYPE_ROUTING_SENSOR_BINARY
 * FGK-101 Raw Description [EndPoint:0] : "0 0 0x2001 0 0 0 c 0x30 0x9C 0x60 0x85 0x72 0x70 0x86 0x80 0x84 0x7A 0xEF 0x2B"
 * Command Classes supported according to Z-Wave Certificate ZC08-14070004 for FGK-101\US :
 * 	 Used in Handler (pre-ZW5 and ZW5) :
 *		0x20 - 32  : BASIC					V1
 *		0x30 - 48  : SENSOR_BINARY			V2
 *		0x31 - 49  : SENSOR_MULTILEVEL		V5
 *		0x56 - 86  : CRC_16_ENCAP			V1
 *		0x70 - 112 : CONFIGURATION			V2
 *		0x80 - 128 : BATTERY				V1
 *		0x84 - 132 : WAKE_UP				V2
 *		0x85 - 133 : ASSOCIATION			V2
 *		0x86 - 134 : VERSION				V1
 *		0x9C - 156 : SENSOR_ALARM			V1
 * 	 Used in Handler (pre-ZW5 only) :
 *		0x60 - 96  : MULTI_CHANNEL			V3
 * 	 Used in Handler (ZW5 only) :
 *		0x71 - 113 : NOTIFICATION			V3
 *		0x98 - 152 : SECURITY				V1
 *	List of Known Bugs / Oddities / Missing Features :
 *		- valueTitle does not show displayNames on mobile Dashboard/Things page;
 *		  attempted workaround using : valueTile(){unit:'${displayName}') failed
 *		- valueTile behaves differently on mobile Dashboard (interpolated colors) from Simulator (step-wise colors)
 *		- using Preferences values instead of hard-coded values for some parameters would be nicer
 *		- ZW5 : Sensor Multilevel Report() received in answer to Sensor Multilevel Get() is buggy (+/- 1°C random error)
metadata {
	definition (name: "JJ's Fibaro FGK-10x ZW5 Handler", namespace: "JJG2014", author: "Jean-Jacques GUILLEMAUD") {
		capability "Contact Sensor"
		capability "Battery"
		capability "Configuration"
		capability "Temperature Measurement"
		capability "Sensor"
		//capability "Alarm"
        //capability "Tamper Alert"
        command "reportNext", ["string"]
        // Use Device Custom Attributes whenever state.xxx Attributes are too vulnerable to race conditions
        attribute "reportASAP", "number"
        attribute "forcedWakeUp", "number"
        attribute "ZW5set", "number"
        attribute "ZW5", "number"
        attribute "Configured", "number"
        // FGK-101 Raw Description [EndPoint:0] : "0 0 0x2001 0 0 0 c 0x30 0x9C 0x60 0x85 0x72 0x70 0x86 0x80 0x84 0x7A 0xEF 0x2B"
		fingerprint deviceId: "0x2001", inClusters: "0x85, 0x20, 0x80, 0x70, 0x56, 0x72, 0x9C, 0x30, 0x31, 0x86, 0x84, 0x7A, 0x2B"  // fingerprint as intersection of ZW6 & non-ZW5 fingerprints
        // fingerprint deviceId: "0x0701", inClusters: "0x5E, 0x85, 0x59, 0x22, 0x20, 0x80, 0x70, 0x56, 0x5A, 0x7A, 0x72, 0x8E, 0x71, 0x73, 0x98, 0x2B, 0x9C, 0x30, 0x31, 0x86, 0x84", outClusters: ""//actual NIF
	simulator {
		status "open":  "command: 2001, payload: FF"
		status "closed": "command: 2001, payload: 00"
        def T_values=[10,14,14.9,15,17,17.9,18,19,19.9,20,22,22.9,23,24,44,44.9,45,46,100]
        def float Ti
        for (int i = 0; i <= T_values.size()-1; i += 1) {
            Ti=T_values.get(i)
        	def theSensorValue = [(short)0, (short)0, (short)(Ti*100)/256, (short)(Ti*100)%256]
			status "temperature ${Ti}°C":  zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:2, destinationEndPoint:2).encapsulate(zwave.sensorMultilevelV5.sensorMultilevelReport(scaledSensorValue: i, precision: 2, scale: 0, sensorType: 1, sensorValue: theSensorValue, size:4)).incomingMessage()
	tiles {
    	valueTile("temperature", "device.temperature", inactiveLabel: false, width: 2, height: 2, canChangeIcon: true, canChangeBackground: true) {
        	// label:'${name}', label:'${currentValue}', unit:"XXX" work, but NOT label:'${device.name}', label:'${displayName}', unit:'${unit}', ...
			state "temperature", label:'${currentValue}°', unit:"C", icon: "st.alarm.temperature.normal",
			// redondant lines added to avoid color interpolation on Dashboard (a feature or a bug ?!)
            backgroundColors:[							// ***on IDE Simulator***		// ***on iPad App***
                [value: 14, color: "#0033ff"],			//     °C <=14 : dark blue		//     °C <=14	: dark blue
				    //[value: 14.1, color: "#00ccff"],	<- decimal value IGNORED by the Tile !!!
					[value: 14.5],					// 15< °C <=19 : light blue		// 14< °C <15	: interpolated dark blue<-> light blue
                    [value: 15, color: "#00ccff"],		// 16< °C <=19 : light blue		// 15<=°C <=19	: light blue
                [value: 17, color: "#00ccff"],			// 16< °C <=19 : light blue		// 15<=°C <=19	: light blue
					[value: 17.5],					// 15< °C <=19 : light blue		// 14< °C <15	: interpolated light blue<->blue-green
                	[value: 18, color: "#ccffcc"],		// 15< °C <=19 : light blue		// 18<=°C <=19	: blue-green
				[value: 19, color: "#ccffcc"],			// 15< °C <=19 : light blue		// 19°C			: blue-green
                    [value: 19.5],					// 19< °C <=21 : blue-green		// 19< °C <20	: interpolated blue-green<->green
                	[value: 20, color: "#ccff00"],		// 19< °C <=21 : blue-green		// 20<=°C <=21	: green
				[value: 22, color: "#ccff00"],			// 21< °C <=23 : green			// 22°C			: green
					[value: 22.5],					// 23< °C <=45 : orange			// 22< °C <23	: interpolated green<-> orange
					[value: 23, color: "#ffcc33"],		// 23< °C <=45 : orange  		// 23<=°C <=44	: orange
				[value: 43, color: "#ffcc33"],			// 23< °C <=45 : orange  		// 44°C			: orange
					[value: 43.5],					// 45< °C      : red			// 44< °C <45	: interpolated orange <-> red
               		[value: 44, color: "#ff3300"]		// 45< °C      : red  			// 45<=°C		: red
        valueTile("temperatureF", "device.temperature", inactiveLabel: false, width: 2, height: 2, canChangeIcon: true, canChangeBackground: true) {
			state "temperature", label:'${currentValue}°', unit:"F", icon: "st.alarm.temperature.normal",
				[value: 57, color: "#0033ff"],			//     °C <=14 : dark blue		//     °C <=14	: dark blue
					//[value: 14.5],					// 15< °C <=19 : light blue		// 14< °C <15	: interpolated dark blue<-> light blue
                    [value: 59, color: "#00ccff"],		// 16< °C <=19 : light blue		// 15<=°C <=19	: light blue
                [value: 63, color: "#00ccff"],			// 16< °C <=19 : light blue		// 15<=°C <=19	: light blue
					//[value: 17.5],					// 15< °C <=19 : light blue		// 14< °C <15	: interpolated light blue<->blue-green
                	[value: 64, color: "#ccffcc"],		// 15< °C <=19 : light blue		// 18<=°C <=19	: blue-green
				[value: 66, color: "#ccffcc"],			// 15< °C <=19 : light blue		// 19°C			: blue-green
                    //[value: 19.5],					// 19< °C <=21 : blue-green		// 19< °C <20	: interpolated blue-green<->green
                	[value: 68, color: "#ccff00"],		// 19< °C <=21 : blue-green		// 20<=°C <=21	: green
				[value: 72, color: "#ccff00"],			// 21< °C <=23 : green			// 22°C			: green
					//[value: 22.5],					// 23< °C <=45 : orange			// 22< °C <23	: interpolated green<-> orange
					[value: 73, color: "#ffcc33"],		// 23< °C <=45 : orange  		// 23<=°C <=44	: orange
				[value: 109, color: "#ffcc33"],			// 23< °C <=45 : orange  		// 44°C			: orange
					//[value: 43.5],					// 45< °C      : red			// 44< °C <45	: interpolated orange <-> red
               		[value: 111, color: "#ff3300"]		// 45< °C      : red  			// 45<=°C		: red
        standardTile("contact", "device.contact") {
			state "open", label: 'open'/* in English :'${name}' */, icon: "st.contact.contact.open", backgroundColor: "#ffa81e"
			state "closed", label: 'closed'/* in English :'${linkText}' */, icon: "st.contact.contact.closed", backgroundColor: "#79b821"
        valueTile("battery", "device.battery", inactiveLabel: false, decoration: "flat") {
			state "battery", label:'batt ${currentValue}%' /*battery*/, unit:""
        //Select temperatureF if Location temperature Scale is °F
        main(["temperature"])
		details(["temperature", "contact", "battery"])
        //main(["temperatureF"])
		//details(["temperatureF", "contact", "battery"])
// parse events into attributes
		//state.parseCount=state.parseCount+1
		//state.debugLevel = 2		// set to 1 or 2 when experimenting
		if (state.debugLevel>=1) {log.debug "--------------------------Parsing... ; state.parseCount: ${state.parseCount}--------------------------"}
		if (state.debugLevel>=2) {log.debug "Parsing... '${description}'"}
        def result = null
        def cmd = zwave.parse(description, [0x20:1, 0x30:2, 0x31:5, 0x56:1, 0x60:3, 0x70:2, 0x72:2, 0x80:1, 0x84:2, 0x85:2, 0x9C:1])
        if (cmd) {
                result = zwaveEvent(cmd)
                if (state.debugLevel>=1) {log.debug "Parsed ${cmd} to ${result.inspect()}"}
        } else {
                log.debug "Non-parsed event: ${description}"
        return result
//SmartThings v2 Hub forces some CRC16-encoded replies from FGK-101 Device (v1 Hub did not)
def zwaveEvent(hubitat.zwave.commands.crc16encapv1.Crc16Encap cmd) {
	log.debug "CRC16.......... cmd : ${cmd}"
    def versions = [0x20:1, 0x30: 2, 0x31: 5, 0x60: 3, 0x70: 2, 0x72: 2, 0x80: 1, 0x84: 2, 0x86: 1, 0x9C: 1]
	// def encapsulatedCommand = cmd.encapsulatedCommand(versions)
	def version = versions[cmd.commandClass as Integer]
    log.debug "commandClass : ${cmd.commandClass}"
    log.debug "version : ${version}"
	def ccObj = version ? zwave.commandClass(cmd.commandClass, version) : zwave.commandClass(cmd.commandClass)
    log.debug "ccObj : ${ccObj}"
    log.debug "cmd.command : ${cmd.command}"
    log.debug "cmd.data : ${cmd.data}"
	def encapsulatedCommand = ccObj?.command(cmd.command)?.parse(cmd.data)
	if (!encapsulatedCommand) {
		log.debug "Could not extract command from ${cmd}"
	} else {
		zwaveEvent(encapsulatedCommand)
// ZW5 Devices that support the Security command class can send messages in an
// encrypted form; they arrive wrapped within a SecurityMessageEncapsulation
// command and must be unencapsulated
def zwaveEvent(hubitat.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
		log.debug "cmd : ${cmd}"
        def encapsulatedCommand = cmd.encapsulatedCommand([0x20: 1, 0x30: 2, 0x70: 2, 0x71: 3, 0x84: 2, 0x85: 2, 0x98: 1, 0x9C: 1])
        // can specify command class versions here like in zwave.parse
        if (encapsulatedCommand) {
    			log.debug "ZW5 encapsulatedCommand : ${encapsulatedCommand}"
                return zwaveEvent(encapsulatedCommand)
        } else {
			log.warn "ZW5 Unable to extract encapsulated cmd from $cmd"
			createEvent(descriptionText: cmd.toString())
def temperatureScaleFC(tempvalue) {
	//FGK-101 is natively °C; convert to °F if selected in Location settings
	def float tempFC = tempvalue
	if (location.temperatureScale == "F") {
		tempFC = tempvalue * 1.8 + 32
	return tempFC
def wakeUpResponse(cmdBlock0) {
	def cmdBlock = []
	cmdBlock += cmdBlock0
	//Initialization... (executed only once, when the Handler has been updated)
    //All untouched parameters are supposed to be DEFAULT (as factory-set)
    if (state.debugLevel>=2) {log.debug "device.Configured : ${device.currentValue('Configured')}"}
    if (!(device.currentValue('Configured'))) {
		cmdBlock += configureDev()
		log.debug "++++++++returned cmdBlock : ${cmdBlock}"
	//Regular ZW5 & non-ZW5 Commands...
    def long nowTime = new Date().getTime()
    log.debug "state.lastReportBattery : ${state.lastReportBattery}"
    if (state.batteryInterval) {
    	if (nowTime-state.lastReportBattery > state.batteryInterval) {
        	// batteryGet() should definitely NOT be CRC16 encoded ! [buggy ZW5 Fibaro handler !!]
			cmdBlock << zwave.batteryV1.batteryGet().format()
        	cmdBlock << "delay ${state.shortDelay}"
    	//ZW5 : "wakeUpIntervalReport doesn’t work uint24FromBytes missing from response" : https://community.smartthings.com/t/wakeupintervalget-doesnt-work-uint24frombytes-missing-from-response/10577
    	//cmdBlock << encap(zwave.wakeUpV2.wakeUpIntervalGet()) // NB : may have to wait 60mn for that value to be refreshed !
    	//cmdBlock << "delay ${state.longDelay}"
    if (device.currentValue('ZW5set')) {
    	// DS18B20 temperature measurement at 12bits accuracy takes more than 750ms...
    	if (device.currentValue('ZW5')) {
        	// sensorMultilevelGet() should be +++PROPERLY+++ CRC16-encoded ! buggy ZW5 Fibaro handler w/ checksum = 0x0000 !!!
            // sensorMultilevelReport() synchronous answer to sensorMultilevelGet() is buggy for whatever reason (+/-1°C) => disable sensorMultilevelGet()
            //cmdBlock << crc16Encode(zwave.sensorMultilevelV5.sensorMultilevelGet(sensorType: 1, scale: 0))
    	} else {
    		cmdBlock << zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint: 2, destinationEndPoint: 2, commandClass:0x31, command:4).format()  //sensorMultiLevel.get()
	cmdBlock << zwave.wakeUpV2.wakeUpNoMoreInformation().format()
        log.debug "wakeUpNoMoreInformation()"
        log.debug "cmdBlock : ${cmdBlock}"
    return cmdBlock
def zwaveEvent(hubitat.zwave.commands.wakeupv2.WakeUpNotification cmd) {
    	log.debug "wakeupv2.WakeUpNotification $cmd"
        def event = createEvent(descriptionText: "${device.displayName} woke up", isStateChange: true, displayed: false)
        def cmdBlock = []
        cmdBlock = wakeUpResponse([])
        return [event, response(cmdBlock)]
def zwaveEvent(hubitat.zwave.commands.sensormultilevelv5.SensorMultilevelReport cmd) {
        	log.debug "SensorMultilevelReport.precision : ${cmd.precision}"
            log.debug "SensorMultilevelReport.scale : ${cmd.scale}"
            log.debug "SensorMultilevelReport.scaledSensorValue : ${cmd.scaledSensorValue}"
            log.debug "SensorMultilevelReport.sensorType : ${cmd.sensorType}"
            log.debug "SensorMultilevelReport.sensorValue : ${cmd.sensorValue}"
            log.debug "SensorMultilevelReport.size : ${cmd.size}"
        def float scaledSensorValue = cmd.scaledSensorValue
        // Adjust measured temperature based on previous manual calibration; FGK-101 is natively °C
        switch (device.name) {
            case 'T005' :										//JJG
            	scaledSensorValue = scaledSensorValue + 0.0554
    			log.debug "Temp Adjust for : ${device.name}"
                break;
            case 'T006' :										//MLE
            	scaledSensorValue = scaledSensorValue + 0.0297
                break;
            case 'T003' :										//MPT
            	scaledSensorValue = scaledSensorValue - 0.0603
                break;
            case 'T002' :										//NBN
            	scaledSensorValue = scaledSensorValue - 0.0758
                break;
            case 'T004' :										//SCU
            	scaledSensorValue = scaledSensorValue + 0.0011
                break;
            case 'T007' :										//FSU
            	scaledSensorValue = scaledSensorValue + 0.0025
                break;
            case 'T008' :
            	scaledSensorValue = scaledSensorValue - 0.0146
                break;
            case 'T009' :
            	scaledSensorValue = scaledSensorValue + 0.0383
                break;
            case 'T010' :
                break;
            case 'T011' :
            	scaledSensorValue = scaledSensorValue - 0.0889
                break;
            case 'T012' :
            	scaledSensorValue = scaledSensorValue - 0.0532
                break;
            case 'T013' :
                break;
            case 'T014' :										//*ext*//
            	scaledSensorValue = scaledSensorValue - 0.0160
                break;
        //Round to nearest 1 decimal temperature value; convert to °F if needed
        def float ftempSign = temperatureScaleFC(scaledSensorValue) < 0 ? -1 : +1
		def float ftemp = ftempSign * ((((int) (temperatureScaleFC(scaledSensorValue).abs()*100+5)/10)*1.0)/10)
        	log.debug "ftempSign : ${ftempSign}"
        	log.debug "ftemp : ${ftemp}"
        	log.debug "cmd.scaledSensorValue : ${cmd.scaledSensorValue}"
        	log.debug "correction : ${scaledSensorValue-cmd.scaledSensorValue}"
    		log.debug "device.displayName : ${device.displayName}"
    		log.debug "'Date().getTime()' : ${new Date().getTime()}"
            log.debug "state.maxEventInterval : ${state.maxEventInterval}"
    		log.debug "state.lastReportTime : ${state.lastReportTime}"
    		log.debug "nowTime : ${nowTime}"
            log.debug "device.forcedWakeUp : ${device.currentValue('forcedWakeUp')}"
    		log.debug "(nowTime-state.lastReportTime > state.maxEventInterval) : ${(nowTime-state.lastReportTime > state.maxEventInterval)}"
            log.debug "state.lastReportedTemp: ${state.lastReportedTemp}"
        // Adjust temperature report sensitivity for outside thermometers whose displayName starts with "*"
        def float tempQuantum
    	if (device.displayName.substring(0,1).equals("*")) {
        	tempQuantum = temperatureScaleFC(0.9999)-temperatureScaleFC(0)
        } else {
        	tempQuantum = temperatureScaleFC(0.0999)-temperatureScaleFC(0)
        //log.debug "((ftemp-state.lastReportedTemp).abs()>${tempQuantum}): ${(ftemp-state.lastReportedTemp).abs()>tempQuantum}"
        // Spurious faulty Temperature Reports cropped when temparture gradient is unbelievable (?)
        //if ((((ftemp-state.lastReportedTemp).abs())/(nowTime-state.lastReportTime)) < (0.5/1000)) { // ignore temperature report when slope > 0.5°C/s
        //if (((ftemp-state.lastReportedTemp).abs()>tempQuantum) || ((nowTime-state.lastReportTime) > state.maxEventInterval) || device.currentValue('forcedWakeUp')) {
        	def map = [ displayed: true, value: ftemp.toString(), isStateChange:true, linkText:"${device.displayName}" ]
        	if (cmd.sensorType == 1) {
                        map.name = "temperature"
                        map.unit = cmd.scale == 1 ? "F" : "C"
                        //ignores Device's native temperature scale, ftemp already converted to °F if settings as such
                        map.unit = location.temperatureScale
                        log.debug "map.value : ${map.value}"
                        log.debug "map.unit : ${map.unit}"
        		log.debug "temperature Command : ${map.inspect()}"
        	state.lastReportedTemp = ftemp
            state.lastReportTime = nowTime
            sendEvent(name: "forcedWakeUp", value: 0, displayed: false)
            // For Test purpose; redondant with reportNext() => device.forcedWakeUp=1
            if (device.currentValue('reportASAP')==1) {sendEvent(name: "reportASAP", value: 0, isStateChange: true)}
        	return createEvent(map)
      //  } else {
        log.debug "+++++++++discarded temperature report : rate change : ${(((ftemp-state.lastReportedTemp).abs())/(nowTime-state.lastReportTime))*1000}°C/s"
def sensorValueEvent(value) {
	if (value) {
		createEvent(name: "contact", value: "open", descriptionText: "$device.displayName is open  [sensorValueEvent]")
	} else {
		createEvent(name: "contact", value: "closed", descriptionText: "$device.displayName is closed  [sensorValueEvent]")
// BasicReport should never occur since all status change notifications are asynchronous via BasicSet
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicReport cmd) {
	sensorValueEvent(cmd.value)
    if (state.debugLevel>=2) {log.debug "basicv1.BasicReport $cmd.value"}
def openClosed(cmd, cmdValue) {
    def theState = cmdValue == 0 ? "closed" : "open"
    if (state.debugLevel>=2) {log.debug "openClosed $cmd"}
    // Use closed/open sensor notification to trigger push of updated Temperature value and immediate setting of updated device parameters
    // Sometimes, Temperature forced refresh stops working : SensorMultilevelGet(sensorType: 1, scale: 0) Commands are stacked but not executed immediately;
    // will restart after some time, and stacked Commands will be executed !
    def event = createEvent(name:"contact", value:"${theState}", descriptionText:"${device.displayName} is ${theState}", isStateChange:true, displayed:true, linkText:"${device.displayName}")
    sendEvent(name: "forcedWakeUp", value: 1, displayed: false)
    return [event, response(wakeUpResponse([]))]
// pre-ZW5 : BasicSet alarm does not seem to wait for any Commands answers, going back to sleep immediately;
//           thus it cannot perform proper initial Configuration => use the Tamper switch and SensorAlarmReport instead
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicSet cmd) {
    log.debug "basicv1.BasicSet $cmd"
    if ((device.currentValue('ZW5set')) && (!(device.currentValue('ZW5')))) {
    	def cmdValue = cmd.value
		return openClosed(cmd, cmdValue)
// For pre-ZW5, SensorBinaryReport should never occur since all status change notifications are asynchronous via BasicSet...
// ...but ZW5 uses it in addition to BasicSet and Notification
def zwaveEvent(hubitat.zwave.commands.sensorbinaryv2.SensorBinaryReport cmd) {
    log.debug "sensorbinaryv2.SensorBinaryReport $cmd"
    	def cmdValue = cmd.sensorValue
// ZW5 : it is assumed that default notification events are used
// (parameter 20 was not changed before device's re-inclusion)
def zwaveEvent(hubitat.zwave.commands.notificationv3.NotificationReport cmd) {
    def map = [:]
    if (cmd.notificationType == 6) {
    	switch (cmd.event) {
        	case 22:
            	map.name = "contact"
                map.value = "open"
                map.descriptionText = "${device.displayName} is open"
            	break
            case 23:
                map.value = "closed"
                map.descriptionText = "${device.displayName} is closed"
            	break
    // Contrary to pre-ZW5 Devices, the Tamper Notification does not occur for only a brief
    // push>release of the Tamper button. But it DOES occur when the Tamper button is released
    // 1mn or so after being pushed.
    } else if (cmd.notificationType == 7) {
        	case 0:
            	map.name = "tamper"
                map.value = "inactive"
                map.descriptionText = "${device.displayName} tamper detection enabled"
				break
        	case 3:
            	map.name = "tamper"
                map.value = "active"
                map.descriptionText = "${device.displayName} is tampered with !"
            	break
    def event = createEvent(map)
// SensorAlarmReport DOES wait for optional Commands answers, contrary to BasicSet
def zwaveEvent(hubitat.zwave.commands.sensoralarmv1.SensorAlarmReport cmd) {
    if (state.debugLevel>=2) {log.debug "sensoralarmv1.SensorAlarmReport $cmd.sensorState"}
    if (!(device.currentValue('ZW5'))) {
    	def event = createEvent(name:"alarm", descriptionText:"${device.displayName} is tampered with !", isStateChange:true, displayed:true, linkText:"${device.displayName}")
    	def cmdBlock = []
    	cmdBlock=wakeUpResponse(cmdBlock)
def zwaveEvent(hubitat.zwave.commands.batteryv1.BatteryReport cmd) {
    	log.debug "batteryv1.BatteryReport ${cmd.batteryLevel}"
    	log.debug "state.batteryInterval : ${state.batteryInterval}"
    if ((nowTime-state.lastReportBattery > state.batteryInterval) || device.currentValue('forcedWakeUp')) {
		def map = [ name: "battery", displayed: true, isStateChange:true, unit: "%" ]
		if (cmd.batteryLevel == 0xFF) {
			map.value = 1
			map.descriptionText = "${device.displayName} has a low battery"
			map.isStateChange = true
		} else {
			map.value = cmd.batteryLevel
    	state.lastReportBattery = nowTime
        log.debug "battery map : ${map}"
    	return [createEvent(map)]
def zwaveEvent(hubitat.zwave.commands.configurationv2.ConfigurationReport cmd) {
    if (state.debugLevel>=2) {log.debug "ConfigurationReport - Parameter#${cmd.parameterNumber}: ${cmd.configurationValue}"}
	// Last configuration command execution; check UNIQUE(<>default) value is set
    // A bit of an overkill : checking the cmd.parameterNumber (12 or 51) should be enough...
	def byte tempQuantumSixteenth
		tempQuantumSixteenth = 16	/* 16/16=1°C = 1.8°F */
	} else {
		tempQuantumSixteenth = 4	/* 5/16=0.31°C = 0.56°F */
	if (device.currentValue('ZW5set') && !(device.currentValue('ZW5')) && (cmd.parameterNumber == 12) && (cmd.configurationValue == [tempQuantumSixteenth])) {
		sendEvent(name: "Configured", value: 1, isStateChange: true)
		log.debug ("++++++Non-ZW5 Device Configured++++++")
	def byte tempQuantumTenth
    	tempQuantumTenth = 10	/* 10/10=1°C = 1.8°F */
    } else {
    	tempQuantumTenth = 2	/* 3/10=0.3°C = 0.56°F */
	if (device.currentValue('ZW5set') && device.currentValue('ZW5') && (cmd.parameterNumber == 51) && (cmd.configurationValue == [0,tempQuantumTenth])) {
		log.debug ("++++++ZW5 Device Configured++++++")
def zwaveEvent(hubitat.zwave.commands.associationv2.AssociationReport cmd) {
	def result = []
	if (cmd.nodeId.any { it == zwaveHubNodeId }) {
		result << createEvent(descriptionText: "$device.displayName is associated in group ${cmd.groupingIdentifier}")
	} else if (cmd.groupingIdentifier == 1) {
		// We're not associated properly to group 1, set association
		result << createEvent(descriptionText: "Associating $device.displayName in group ${cmd.groupingIdentifier}")
		result << response(zwave.associationV1.associationSet(groupingIdentifier:cmd.groupingIdentifier, nodeId:zwaveHubNodeId))
	result
def zwaveEvent(hubitat.zwave.commands.multichannelv3.MultiChannelEndPointReport cmd) {
    if (state.debugLevel>=2) {log.debug "multichannelv3.MultiChannelCapabilityReport: ${cmd}"}
def zwaveEvent(hubitat.zwave.commands.multichannelv3.MultiChannelCapabilityReport cmd) {
// ZW5 added : discriminate between ZW5 and pre-ZW5 Devices
// ZW5 : ${cmd.applicationVersion}.${cmd.applicationSubVersion}>=3.2 ; pre-ZW5 : <= 2.5
    def deviceFirmwareVersion = (java.lang.Short) cmd.applicationVersion*1000 + cmd.applicationSubVersion
    } else {
// MultiChannelCmdEncap and MultiInstanceCmdEncap are ways that devices can indicate that a message
// is coming from one of multiple subdevices or "endpoints" that would otherwise be indistinguishable
def zwaveEvent(hubitat.zwave.commands.multichannelv3.MultiChannelCmdEncap cmd) {
	def encapsulatedCommand = cmd.encapsulatedCommand([0x30: 2, 0x31: 5]) // can specify command class versions here like in zwave.parse
	if (state.debugLevel>=2) {log.debug ("Command from endpoint ${cmd.sourceEndPoint}: ${encapsulatedCommand}")}
// Catch All command Handler in case of unexpected message
def zwaveEvent(hubitat.zwave.Command cmd) {
	createEvent(descriptionText: "!!! $device.displayName: ${cmd}", displayed: false)
// When a Temperature Event got lost in transit, the Watchdog requests a forced report at next wake up
// The "reportNext()" alarm command is used to signal back from the Watchdog SmartApp to the sleepy device
def reportNext(commandMsg) {
	log.debug "reportNext !"
    log.debug "commandMsg : ${commandMsg}"
    sendEvent(name: "forcedWakeUp", value: 1)
    return []
// Initial Device Configuration and Handler Update
// Executed each time the Handler is updated
def updated() {
	log.debug "Updated !"
    def bytesToCRC = [0x56, 0x01, 0x31, 0x05, 0x01, 0x42, 0x09, 0x79]
//log.debug "checksum 0BD3/3027 : zwaveCrc16([0x56, 0x01, 0x31, 0x05, 0x01, 0x42,0x09, 0x79]) : ${zwaveCrc16(bytesToCRC as byte[])}"
    sendEvent(name: "ZW5set", value: 0)
    sendEvent(name: "ZW5", value: 0)
    sendEvent(name: "Configured", value: 0)  // set to true by the LAST Command Response from configureDev()
    // All state.xxx attributes are Device-local, NOT Location-wide
    // BEWARE : state.xxx attributes are vulnerable to race conditions; when not mostly read-only, use device.xxx instead
    state.lastReportedTemp = (float) -1000
    state.lastReportTime = (long) 0
    state.lastReportBattery = (long) 0
    state.longDelay = 1200
state.shortDelay = 1200
	// Real-time clock of sensors (ceramic resonator) is up to 3% inaccurate
    state.batteryInterval = (long) (24*60-45)*60*1000  // 83 700 000 : at least 1 Battery Report event every 23:15 hours
    state.maxEventInterval = (long) (2*60-20)*60*1000  // 13 200 000 : at least 1 Temperature Report event every 3:40 hours (4 hours at most)
    state.parseCount=(int) 0
    if (!(state.deviceID)) {state.deviceID = device.name}
    log.debug "state.deviceID: ${state.deviceID}"
    sendEvent(name: "reportASAP", value: 1)
    log.debug "device.currentValue('reportASAP') : ${device.currentValue('reportASAP')}"
    // configureDev()		// will be defered till first wakeup (forced or periodic)
    infos()
// If you add the Configuration capability to your device type, this command will be called right
// after the device joins to set device-specific configuration commands.
def configure() {
    return configureDev()
def configureDev() {
	def cmdBlock = []
    log.debug "device.Configured: ${device.currentValue('Configured')}"
    /////////////// Common configuration
    if (!(device.currentValue('ZW5set')))  {
    	log.debug "Configuring - Common Part............................................."
    	log.debug "cmdBlock: ${cmdBlock}"
		cmdBlock << zwave.versionV1.versionGet().format()
		log.debug "++++++Last Common Configuration Command SENT++++++"
		return cmdBlock
    /////////////// Non-ZW5 specific configuration
    if (!(device.currentValue('Configured')) && device.currentValue('ZW5set') && !(device.currentValue('ZW5'))) {
		log.debug  "Configuring - NON ZW5............................................."
        // Make sure sleepy battery-powered sensors send their WakeUpNotifications to the hub
		cmdBlock << zwave.wakeUpV2.wakeUpIntervalSet(seconds:60*60, nodeid:zwaveHubNodeId).format()
		} else {
			tempQuantumSixteenth = 2	/* 5/16=0.31°C = 0.56°F */
		log.debug "tempQuantumSixteenth : ${tempQuantumSixteenth}"
		// NOTE : any asynchronous temperature query thru SensorMultilevelGet(sensorType: 1, scale: 0) does NOT reset the delta-Temp base value (managed by DS18B20 hardware)
		cmdBlock << zwave.configurationV2.configurationSet(parameterNumber: 12/*for FGK101*/, size: 1, configurationValue: [tempQuantumSixteenth]).format()
		// inclusion of Device in Association#3 is needed to get delta-Temperature notification messages [cf Parameter#12 above]
		cmdBlock << zwave.associationV2.associationSet(groupingIdentifier:3, nodeId:[zwaveHubNodeId]).format()
        // inclusion of Device in Association#2 is needed to enable SensorAlarmReport() Command [anti-Tampering protection]
        cmdBlock << zwave.associationV2.associationSet(groupingIdentifier:2, nodeId:[zwaveHubNodeId]).format()
        // Should be last for proper checking of complete initialization (through configurationReport)
		cmdBlock << zwave.configurationV2.configurationGet(parameterNumber: 12/*for FGK101*/).format()
		//cmdBlock << zwave.wakeUpV2.wakeUpNoMoreInformation().format()
        log.debug "++++++Last non-ZW5 Configuration Command SENT++++++"
    /////////////// ZW5 specific configuration
    if (!(device.currentValue('Configured')) && device.currentValue('ZW5set') && device.currentValue('ZW5')) {
    	log.debug "Configuring - ZW5............................................."
            //cmdBlock << "delay ${state.shortDelay}"
		cmdBlock << encap(zwave.wakeUpV2.wakeUpIntervalSet(seconds:60*60, nodeid:zwaveHubNodeId))
    	def short tempQuantumTenth
    	log.debug "device.displayName.substring(0,1) : ${device.displayName.substring(0,1)}"
    	} else {
    		tempQuantumTenth = 1	/* 3/10=0.3°C = 0.56°F */
    	// sensorMultilevelGet() should be +++PROPERLY+++ CRC16 encoded ! buggy ZW5 Fibaro handler w/ checksum = 0x0000 !!
        // ZW5 : completely buggy synchronous sensorMultilevelReport() : +/- 1°C vs unsolicited asynchronous reports : ???
        cmdBlock << encap(zwave.configurationV2.configurationSet(parameterNumber: 3/*for FGK101*/, size: 1, configurationValue: [5]))  // LED blinks on Tampering & Open/Close
        // measuring temperature every 5mn drains the battery in a few months... but every hour creates a prejudiciable latency...
		cmdBlock << encap(zwave.configurationV2.configurationSet(parameterNumber: 50/*for FGK101*/, size: 2, configurationValue: [0x03,0x84]))  // measure temperature every 15mn = 900s = 0x384
        cmdBlock << encap(zwave.configurationV2.configurationSet(parameterNumber: 51/*for FGK101*/, size: 2, configurationValue: [0,tempQuantumTenth]))  // less than 256...
        // ??? : parameter#52 seems to translate "1 second" into "1.92 second", based on actual measurements
        //       => downrate 14 400 to 7 510 to compensate
        //cmdBlock << encap(zwave.configurationV2.configurationSet(parameterNumber: 52/*for FGK101*/, size: 2, configurationValue: [0x38,0x40]))  // 0x3840 = 14400 = 4*3600 = 4 hours
        cmdBlock << encap(zwave.configurationV2.configurationSet(parameterNumber: 52/*for FGK101*/, size: 2, configurationValue: [0x1D,0x56]))  // 0x1D56 = 7510
        // 1st Association Group : "Lifeline" reports the device status and allows for assigning single device only (main controller by default)
        cmdBlock << encap(zwave.associationV2.associationSet(groupingIdentifier:1, nodeId: [zwaveHubNodeId]))
        // 2nd Association Group : "Control" is assigned to the device status - reed sensor and IN input (sends alarm command frames).
        cmdBlock << encap(zwave.associationV2.associationSet(groupingIdentifier:2, nodeId: [zwaveHubNodeId]))
		cmdBlock << encap(zwave.configurationV2.configurationGet(parameterNumber: 51/*for FGK101*/))
    	log.debug "++++++Last ZW5 Configuration Command SENT++++++"
    //log.debug "device.Configured: ${device.currentValue('Configured')}"
	return cmdBlock // Fully configured only after 2 Configure() calls
def infos() {
	if (!state.devices) { state.devices = [:] }
    log.debug "zwaveHubNodeId: ${zwaveHubNodeId}"				// -> "1"
    log.debug "device.displayName: ${device.displayName}"		// -> "JJG"
    log.debug "device.id: ${device.id}"							// -> "d93f6450-4c9b-4892-bfcb-d61353f4c793"
    log.debug "location.id: ${location.id}"						// -> "99e95fb7-726f-4c64-a4f5-7b2151cf166a"  [Le Puits Jamet]
    log.debug "device.name: ${device.name}"						// -> "T005"
    log.debug "device.label: ${device.label}"					// -> "JJG"
    log.debug "device.data: ${device.data}"   					// -> "[MSR: 010F-0700-2000, endpointId: 0, version: 2.1]"
    log.debug "device.rawDescription: ${device.rawDescription}"	// -> non-ZW5 : "0 0 0x2001 0 0 0 c 0x30 0x9C 0x60 0x85 0x72 0x70 0x86 0x80 0x84 0x7A 0xEF 0x2B"
    // -> ZW5 : "zw:Ss type:0701 mfr:010F prod:0701 model:2001 cc:5E,59,22,80,56,7A,72,73,98,31,86 sec:85,20,70,5A,8E,71,2B,9C,30,84"
 *  Calculates the 16-bit CRC (CRC-CCITT) for a byte array.
 *  Uses initial crc of 0x1D0F, and poly of 0x1021, as per Z-wave specification.
 *  Reference: http://z-wave.sigmadesigns.com/wp-content/uploads/2016/08/SDS12652-13-Z-Wave-Command-Class-Specification-N-Z.pdf
 *  Thanks to CODERSAUR : https://community.smartthings.com/t/handling-crc-16-encapsulation-commands-crc16encap/76931/4
 private zwaveCrc16(byte[] bytes) {
    short crc = 0x1D0F // It's important this is a short (16-bit)
    short poly = 0x1021
    bytes.each { workData ->
        //for (bitMask = 0x80; bitMask != 0; bitMask >>= 1) {
        // Need to use a different way to iterate, as rightshift operator '>>' and unsigned rightshift '>>>' do not appear to work in SmartThings.
        [0b10000000,0b01000000,0b00100000,0b00010000,0b00001000,0b00000100,0b00000010,0b00000001].each { bitMask ->
            def newBit = ((workData & bitMask) != 0) ^ ((crc & 0x8000) != 0);
            crc <<= 1;
            if (newBit) { crc ^= poly; }
    return crc
// CRC16 Encoding for Hub's +++OUTGOING+++ Commands
private crc16Encode(hubitat.zwave.Command cmd) {
	log.debug "cmd: ${cmd}"
	def bytesToCRC = [0x56, 0x01, cmd.commandClassId, cmd.commandId]
    bytesToCRC += cmd.payload
	log.debug "bytesToCRC: ${bytesToCRC}"
	def short checksum = zwaveCrc16(bytesToCRC as byte[])
	log.debug  "5601${cmd.format()}${Integer.toHexString(checksum & 0xFFFF).toUpperCase()}"
	return "5601${cmd.format()}${Integer.toHexString(checksum & 0xFFFF).toUpperCase()}"
//ZW5 added
private secure(hubitat.zwave.Command cmd) {
	zwave.securityV1.securityMessageEncapsulation().encapsulate(cmd).format()
//ZW5 added
private encap(hubitat.zwave.Command cmd) {
    def secureClasses = [0x20, 0x2B, 0x30, 0x5A, 0x70, 0x71, 0x84, 0x85, 0x8E, 0x9C]
    //todo: check if secure inclusion was successful
    //if not do not send security-encapsulated command
    if ((device.currentValue('ZW5set')) && (device.currentValue('ZW5'))) {
		if (secureClasses.find{ it == cmd.commandClassId }) {
    		secure(cmd)
    	} else {
        	// ??? : very dubious all UNsecure outgoing ZW5 commands have to be CRC16 encoded;
            //		 sensorMultiLevelGet() MUST be, but for sure
            //       batteryGet() and versionGet() need NOT be ! (but could be ?)
    		crc16Encode(cmd)  // crc16() Fibaro code w/ checksum = 0x0000 was buggy
    } else {
    	return cmd.format()
I'm moving over from ST andmost of my issues have bee solved. Pretty happy with WebCore, DSC and most of the custom stuff I had.
Tackling the last few unknows, these sensors are one of them.
Removed from ST and paired just fine.
Tried the built in Fibaro driver, no luck. Tried JJ (converted from physicalgraph), which is what I was using in ST, no events.
I use these for my pool and brewing controller so a solution must be found :wink:
