* Fibaro Z-Wave FGK-101 Temperature & Door/Window Sensor Handler [v0.9.7.2, 9 July 2017]
* Copyright 2014 Jean-Jacques GUILLEMAUD
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
/* IMPORTANT : This custom Handler works both for Z-Wave+ (aka ZW5) versions of the FGK-101 Fibaro sensor,
/* as well as for pre-ZW5 versions of the FGK-101 hardware.
/* It takes about 1mn for the FGK-101 to fully configure itself after the first (manual or otherwise) wakeup.
* Fibaro Z-Wave FGK-101 Marketing Description is at :
* http://www.fibaro.com/en/the-fibaro-system/door-window-sensor
* Fibaro FGK-10x Operating Manuals and Z-Wave Alliance Certificates can be downloaded at :
* Z-Wave / Firmware <= 2.5 : http://www.fibaro.com/files/instrukcje/eng/DoorWindowSensor%20FGK-101-107%20ENG_v21-v23.pdf
* : http://products.z-wavealliance.org/products/1077
* Z-Wave+ / ZW5 / Firmware >= 3.2 : http://manuals.fibaro.com/content/manuals/en/FGK-10x/FGK-10x-EN-T-v2.0.pdf
* : http://products.z-wavealliance.org/products/1620
* The current version of this Handler is parameterized to force Device's wakeup :
* - on any open<->closed state change
* - in case of Tampering Alarm triggering
* - every 60mn (wakeUpIntervalSet(seconds:60*60), hard coded)
* - whenever Temperature delta change since last report is greater than 0.3°C (Parameter#12 or #51, hard coded)
* - every 4h when Temperature does not change
* also :
* - Temperature is natively reported by sensor in Celsius (SensorMultilevelReport[scale:0]);
* convertion is needed for Fahrenheit display
* A few specificities of this device that are relevant to better understand some parts of this Handler :
* - it is a battery operated device, so Commands can only be sent to it whenever it wakes up
* - it is a multi-channel Device (pre-ZW5), and the multi-level temperature sensor reports only from EndPoint#2
* - specific configurable parameters are documented in the above Operating Manuals
* - some of those parameters must be modified to activate the anti-Tampering Alarm
* - some of the "scaffolding" has been left in place as comments, since it may help other people to understand/modify this Handler
* - BEWARE : the optional DS18B20 temperature sensor must be connected BEFORE the Device is activated (otherwise, reset the Device)
* - IMPORTANT : for debugging purpose, it is much better to change the wake-up period from the default 60mn to 1mn or so;
* but unless you force the early wake up of the sensor (forcing open/closed for instance), you will have to
* wait up to 60mn for the new value to become effective.
* Z-Wave Device Class: GENERIC_TYPE_SENSOR_BINARY / SPECIFIC_TYPE_ROUTING_SENSOR_BINARY
* FGK-101 Raw Description [EndPoint:0] : "0 0 0x2001 0 0 0 c 0x30 0x9C 0x60 0x85 0x72 0x70 0x86 0x80 0x84 0x7A 0xEF 0x2B"
* Command Classes supported according to Z-Wave Certificate ZC08-14070004 for FGK-101\US :
* Used in Handler (pre-ZW5 and ZW5) :
* 0x20 - 32 : BASIC V1
* 0x30 - 48 : SENSOR_BINARY V2
* 0x31 - 49 : SENSOR_MULTILEVEL V5
* 0x56 - 86 : CRC_16_ENCAP V1
* 0x70 - 112 : CONFIGURATION V2
* 0x80 - 128 : BATTERY V1
* 0x84 - 132 : WAKE_UP V2
* 0x85 - 133 : ASSOCIATION V2
* 0x86 - 134 : VERSION V1
* 0x9C - 156 : SENSOR_ALARM V1
* Used in Handler (pre-ZW5 only) :
* 0x60 - 96 : MULTI_CHANNEL V3
* Used in Handler (ZW5 only) :
* 0x71 - 113 : NOTIFICATION V3
* 0x98 - 152 : SECURITY V1
* List of Known Bugs / Oddities / Missing Features :
* - valueTitle does not show displayNames on mobile Dashboard/Things page;
* attempted workaround using : valueTile(){unit:'${displayName}') failed
* - valueTile behaves differently on mobile Dashboard (interpolated colors) from Simulator (step-wise colors)
* - using Preferences values instead of hard-coded values for some parameters would be nicer
* - ZW5 : Sensor Multilevel Report() received in answer to Sensor Multilevel Get() is buggy (+/- 1°C random error)
metadata {
definition (name: "JJ's Fibaro FGK-10x ZW5 Handler", namespace: "JJG2014", author: "Jean-Jacques GUILLEMAUD") {
capability "Contact Sensor"
capability "Battery"
capability "Configuration"
capability "Temperature Measurement"
capability "Sensor"
//capability "Alarm"
//capability "Tamper Alert"
command "reportNext", ["string"]
// Use Device Custom Attributes whenever state.xxx Attributes are too vulnerable to race conditions
attribute "reportASAP", "number"
attribute "forcedWakeUp", "number"
attribute "ZW5set", "number"
attribute "ZW5", "number"
attribute "Configured", "number"
// FGK-101 Raw Description [EndPoint:0] : "0 0 0x2001 0 0 0 c 0x30 0x9C 0x60 0x85 0x72 0x70 0x86 0x80 0x84 0x7A 0xEF 0x2B"
fingerprint deviceId: "0x2001", inClusters: "0x85, 0x20, 0x80, 0x70, 0x56, 0x72, 0x9C, 0x30, 0x31, 0x86, 0x84, 0x7A, 0x2B" // fingerprint as intersection of ZW6 & non-ZW5 fingerprints
// fingerprint deviceId: "0x0701", inClusters: "0x5E, 0x85, 0x59, 0x22, 0x20, 0x80, 0x70, 0x56, 0x5A, 0x7A, 0x72, 0x8E, 0x71, 0x73, 0x98, 0x2B, 0x9C, 0x30, 0x31, 0x86, 0x84", outClusters: ""//actual NIF
simulator {
status "open": "command: 2001, payload: FF"
status "closed": "command: 2001, payload: 00"
def T_values=[10,14,14.9,15,17,17.9,18,19,19.9,20,22,22.9,23,24,44,44.9,45,46,100]
def float Ti
for (int i = 0; i <= T_values.size()-1; i += 1) {
Ti=T_values.get(i)
def theSensorValue = [(short)0, (short)0, (short)(Ti*100)/256, (short)(Ti*100)%256]
status "temperature ${Ti}°C": zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:2, destinationEndPoint:2).encapsulate(zwave.sensorMultilevelV5.sensorMultilevelReport(scaledSensorValue: i, precision: 2, scale: 0, sensorType: 1, sensorValue: theSensorValue, size:4)).incomingMessage()
tiles {
valueTile("temperature", "device.temperature", inactiveLabel: false, width: 2, height: 2, canChangeIcon: true, canChangeBackground: true) {
// label:'${name}', label:'${currentValue}', unit:"XXX" work, but NOT label:'${device.name}', label:'${displayName}', unit:'${unit}', ...
state "temperature", label:'${currentValue}°', unit:"C", icon: "st.alarm.temperature.normal",
// redondant lines added to avoid color interpolation on Dashboard (a feature or a bug ?!)
backgroundColors:[ // ***on IDE Simulator*** // ***on iPad App***
[value: 14, color: "#0033ff"], // °C <=14 : dark blue // °C <=14 : dark blue
//[value: 14.1, color: "#00ccff"], <- decimal value IGNORED by the Tile !!!
[value: 14.5], // 15< °C <=19 : light blue // 14< °C <15 : interpolated dark blue<-> light blue
[value: 15, color: "#00ccff"], // 16< °C <=19 : light blue // 15<=°C <=19 : light blue
[value: 17, color: "#00ccff"], // 16< °C <=19 : light blue // 15<=°C <=19 : light blue
[value: 17.5], // 15< °C <=19 : light blue // 14< °C <15 : interpolated light blue<->blue-green
[value: 18, color: "#ccffcc"], // 15< °C <=19 : light blue // 18<=°C <=19 : blue-green
[value: 19, color: "#ccffcc"], // 15< °C <=19 : light blue // 19°C : blue-green
[value: 19.5], // 19< °C <=21 : blue-green // 19< °C <20 : interpolated blue-green<->green
[value: 20, color: "#ccff00"], // 19< °C <=21 : blue-green // 20<=°C <=21 : green
[value: 22, color: "#ccff00"], // 21< °C <=23 : green // 22°C : green
[value: 22.5], // 23< °C <=45 : orange // 22< °C <23 : interpolated green<-> orange
[value: 23, color: "#ffcc33"], // 23< °C <=45 : orange // 23<=°C <=44 : orange
[value: 43, color: "#ffcc33"], // 23< °C <=45 : orange // 44°C : orange
[value: 43.5], // 45< °C : red // 44< °C <45 : interpolated orange <-> red
[value: 44, color: "#ff3300"] // 45< °C : red // 45<=°C : red
valueTile("temperatureF", "device.temperature", inactiveLabel: false, width: 2, height: 2, canChangeIcon: true, canChangeBackground: true) {
state "temperature", label:'${currentValue}°', unit:"F", icon: "st.alarm.temperature.normal",
[value: 57, color: "#0033ff"], // °C <=14 : dark blue // °C <=14 : dark blue
//[value: 14.5], // 15< °C <=19 : light blue // 14< °C <15 : interpolated dark blue<-> light blue
[value: 59, color: "#00ccff"], // 16< °C <=19 : light blue // 15<=°C <=19 : light blue
[value: 63, color: "#00ccff"], // 16< °C <=19 : light blue // 15<=°C <=19 : light blue
//[value: 17.5], // 15< °C <=19 : light blue // 14< °C <15 : interpolated light blue<->blue-green
[value: 64, color: "#ccffcc"], // 15< °C <=19 : light blue // 18<=°C <=19 : blue-green
[value: 66, color: "#ccffcc"], // 15< °C <=19 : light blue // 19°C : blue-green
//[value: 19.5], // 19< °C <=21 : blue-green // 19< °C <20 : interpolated blue-green<->green
[value: 68, color: "#ccff00"], // 19< °C <=21 : blue-green // 20<=°C <=21 : green
[value: 72, color: "#ccff00"], // 21< °C <=23 : green // 22°C : green
//[value: 22.5], // 23< °C <=45 : orange // 22< °C <23 : interpolated green<-> orange
[value: 73, color: "#ffcc33"], // 23< °C <=45 : orange // 23<=°C <=44 : orange
[value: 109, color: "#ffcc33"], // 23< °C <=45 : orange // 44°C : orange
//[value: 43.5], // 45< °C : red // 44< °C <45 : interpolated orange <-> red
[value: 111, color: "#ff3300"] // 45< °C : red // 45<=°C : red
standardTile("contact", "device.contact") {
state "open", label: 'open'/* in English :'${name}' */, icon: "st.contact.contact.open", backgroundColor: "#ffa81e"
state "closed", label: 'closed'/* in English :'${linkText}' */, icon: "st.contact.contact.closed", backgroundColor: "#79b821"
valueTile("battery", "device.battery", inactiveLabel: false, decoration: "flat") {
state "battery", label:'batt ${currentValue}%' /*battery*/, unit:""
//Select temperatureF if Location temperature Scale is °F
main(["temperature"])
details(["temperature", "contact", "battery"])
//main(["temperatureF"])
//details(["temperatureF", "contact", "battery"])
// parse events into attributes
//state.parseCount=state.parseCount+1
//state.debugLevel = 2 // set to 1 or 2 when experimenting
if (state.debugLevel>=1) {log.debug "--------------------------Parsing... ; state.parseCount: ${state.parseCount}--------------------------"}
if (state.debugLevel>=2) {log.debug "Parsing... '${description}'"}
def result = null
def cmd = zwave.parse(description, [0x20:1, 0x30:2, 0x31:5, 0x56:1, 0x60:3, 0x70:2, 0x72:2, 0x80:1, 0x84:2, 0x85:2, 0x9C:1])
if (cmd) {
result = zwaveEvent(cmd)
if (state.debugLevel>=1) {log.debug "Parsed ${cmd} to ${result.inspect()}"}
} else {
log.debug "Non-parsed event: ${description}"
return result
//SmartThings v2 Hub forces some CRC16-encoded replies from FGK-101 Device (v1 Hub did not)
def zwaveEvent(hubitat.zwave.commands.crc16encapv1.Crc16Encap cmd) {
log.debug "CRC16.......... cmd : ${cmd}"
def versions = [0x20:1, 0x30: 2, 0x31: 5, 0x60: 3, 0x70: 2, 0x72: 2, 0x80: 1, 0x84: 2, 0x86: 1, 0x9C: 1]
// def encapsulatedCommand = cmd.encapsulatedCommand(versions)
def version = versions[cmd.commandClass as Integer]
log.debug "commandClass : ${cmd.commandClass}"
log.debug "version : ${version}"
def ccObj = version ? zwave.commandClass(cmd.commandClass, version) : zwave.commandClass(cmd.commandClass)
log.debug "ccObj : ${ccObj}"
log.debug "cmd.command : ${cmd.command}"
log.debug "cmd.data : ${cmd.data}"
def encapsulatedCommand = ccObj?.command(cmd.command)?.parse(cmd.data)
if (!encapsulatedCommand) {
log.debug "Could not extract command from ${cmd}"
} else {
zwaveEvent(encapsulatedCommand)
// ZW5 Devices that support the Security command class can send messages in an
// encrypted form; they arrive wrapped within a SecurityMessageEncapsulation
// command and must be unencapsulated
def zwaveEvent(hubitat.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
log.debug "cmd : ${cmd}"
def encapsulatedCommand = cmd.encapsulatedCommand([0x20: 1, 0x30: 2, 0x70: 2, 0x71: 3, 0x84: 2, 0x85: 2, 0x98: 1, 0x9C: 1])
// can specify command class versions here like in zwave.parse
if (encapsulatedCommand) {
log.debug "ZW5 encapsulatedCommand : ${encapsulatedCommand}"
return zwaveEvent(encapsulatedCommand)
} else {
log.warn "ZW5 Unable to extract encapsulated cmd from $cmd"
createEvent(descriptionText: cmd.toString())
def temperatureScaleFC(tempvalue) {
//FGK-101 is natively °C; convert to °F if selected in Location settings
def float tempFC = tempvalue
if (location.temperatureScale == "F") {
tempFC = tempvalue * 1.8 + 32
return tempFC
def wakeUpResponse(cmdBlock0) {
def cmdBlock = []
cmdBlock += cmdBlock0
//Initialization... (executed only once, when the Handler has been updated)
//All untouched parameters are supposed to be DEFAULT (as factory-set)
if (state.debugLevel>=2) {log.debug "device.Configured : ${device.currentValue('Configured')}"}
if (!(device.currentValue('Configured'))) {
cmdBlock += configureDev()
log.debug "++++++++returned cmdBlock : ${cmdBlock}"
//Regular ZW5 & non-ZW5 Commands...
def long nowTime = new Date().getTime()
log.debug "state.lastReportBattery : ${state.lastReportBattery}"
if (state.batteryInterval) {
if (nowTime-state.lastReportBattery > state.batteryInterval) {
// batteryGet() should definitely NOT be CRC16 encoded ! [buggy ZW5 Fibaro handler !!]
cmdBlock << zwave.batteryV1.batteryGet().format()
cmdBlock << "delay ${state.shortDelay}"
//ZW5 : "wakeUpIntervalReport doesn’t work uint24FromBytes missing from response" : https://community.smartthings.com/t/wakeupintervalget-doesnt-work-uint24frombytes-missing-from-response/10577
//cmdBlock << encap(zwave.wakeUpV2.wakeUpIntervalGet()) // NB : may have to wait 60mn for that value to be refreshed !
//cmdBlock << "delay ${state.longDelay}"
if (device.currentValue('ZW5set')) {
// DS18B20 temperature measurement at 12bits accuracy takes more than 750ms...
if (device.currentValue('ZW5')) {
// sensorMultilevelGet() should be +++PROPERLY+++ CRC16-encoded ! buggy ZW5 Fibaro handler w/ checksum = 0x0000 !!!
// sensorMultilevelReport() synchronous answer to sensorMultilevelGet() is buggy for whatever reason (+/-1°C) => disable sensorMultilevelGet()
//cmdBlock << crc16Encode(zwave.sensorMultilevelV5.sensorMultilevelGet(sensorType: 1, scale: 0))
} else {
cmdBlock << zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint: 2, destinationEndPoint: 2, commandClass:0x31, command:4).format() //sensorMultiLevel.get()
cmdBlock << zwave.wakeUpV2.wakeUpNoMoreInformation().format()
log.debug "wakeUpNoMoreInformation()"
log.debug "cmdBlock : ${cmdBlock}"
return cmdBlock
def zwaveEvent(hubitat.zwave.commands.wakeupv2.WakeUpNotification cmd) {
log.debug "wakeupv2.WakeUpNotification $cmd"
def event = createEvent(descriptionText: "${device.displayName} woke up", isStateChange: true, displayed: false)
def cmdBlock = []
cmdBlock = wakeUpResponse([])
return [event, response(cmdBlock)]
def zwaveEvent(hubitat.zwave.commands.sensormultilevelv5.SensorMultilevelReport cmd) {
log.debug "SensorMultilevelReport.precision : ${cmd.precision}"
log.debug "SensorMultilevelReport.scale : ${cmd.scale}"
log.debug "SensorMultilevelReport.scaledSensorValue : ${cmd.scaledSensorValue}"
log.debug "SensorMultilevelReport.sensorType : ${cmd.sensorType}"
log.debug "SensorMultilevelReport.sensorValue : ${cmd.sensorValue}"
log.debug "SensorMultilevelReport.size : ${cmd.size}"
def float scaledSensorValue = cmd.scaledSensorValue
// Adjust measured temperature based on previous manual calibration; FGK-101 is natively °C
switch (device.name) {
case 'T005' : //JJG
scaledSensorValue = scaledSensorValue + 0.0554
log.debug "Temp Adjust for : ${device.name}"
break;
case 'T006' : //MLE
scaledSensorValue = scaledSensorValue + 0.0297
break;
case 'T003' : //MPT
scaledSensorValue = scaledSensorValue - 0.0603
break;
case 'T002' : //NBN
scaledSensorValue = scaledSensorValue - 0.0758
break;
case 'T004' : //SCU
scaledSensorValue = scaledSensorValue + 0.0011
break;
case 'T007' : //FSU
scaledSensorValue = scaledSensorValue + 0.0025
break;
case 'T008' :
scaledSensorValue = scaledSensorValue - 0.0146
break;
case 'T009' :
scaledSensorValue = scaledSensorValue + 0.0383
break;
case 'T010' :
break;
case 'T011' :
scaledSensorValue = scaledSensorValue - 0.0889
break;
case 'T012' :
scaledSensorValue = scaledSensorValue - 0.0532
break;
case 'T013' :
break;
case 'T014' : //*ext*//
scaledSensorValue = scaledSensorValue - 0.0160
break;
//Round to nearest 1 decimal temperature value; convert to °F if needed
def float ftempSign = temperatureScaleFC(scaledSensorValue) < 0 ? -1 : +1
def float ftemp = ftempSign * ((((int) (temperatureScaleFC(scaledSensorValue).abs()*100+5)/10)*1.0)/10)
log.debug "ftempSign : ${ftempSign}"
log.debug "ftemp : ${ftemp}"
log.debug "cmd.scaledSensorValue : ${cmd.scaledSensorValue}"
log.debug "correction : ${scaledSensorValue-cmd.scaledSensorValue}"
log.debug "device.displayName : ${device.displayName}"
log.debug "'Date().getTime()' : ${new Date().getTime()}"
log.debug "state.maxEventInterval : ${state.maxEventInterval}"
log.debug "state.lastReportTime : ${state.lastReportTime}"
log.debug "nowTime : ${nowTime}"
log.debug "device.forcedWakeUp : ${device.currentValue('forcedWakeUp')}"
log.debug "(nowTime-state.lastReportTime > state.maxEventInterval) : ${(nowTime-state.lastReportTime > state.maxEventInterval)}"
log.debug "state.lastReportedTemp: ${state.lastReportedTemp}"
// Adjust temperature report sensitivity for outside thermometers whose displayName starts with "*"
def float tempQuantum
if (device.displayName.substring(0,1).equals("*")) {
tempQuantum = temperatureScaleFC(0.9999)-temperatureScaleFC(0)
} else {
tempQuantum = temperatureScaleFC(0.0999)-temperatureScaleFC(0)
//log.debug "((ftemp-state.lastReportedTemp).abs()>${tempQuantum}): ${(ftemp-state.lastReportedTemp).abs()>tempQuantum}"
// Spurious faulty Temperature Reports cropped when temparture gradient is unbelievable (?)
//if ((((ftemp-state.lastReportedTemp).abs())/(nowTime-state.lastReportTime)) < (0.5/1000)) { // ignore temperature report when slope > 0.5°C/s
//if (((ftemp-state.lastReportedTemp).abs()>tempQuantum) || ((nowTime-state.lastReportTime) > state.maxEventInterval) || device.currentValue('forcedWakeUp')) {
def map = [ displayed: true, value: ftemp.toString(), isStateChange:true, linkText:"${device.displayName}" ]
if (cmd.sensorType == 1) {
map.name = "temperature"
map.unit = cmd.scale == 1 ? "F" : "C"
//ignores Device's native temperature scale, ftemp already converted to °F if settings as such
map.unit = location.temperatureScale
log.debug "map.value : ${map.value}"
log.debug "map.unit : ${map.unit}"
log.debug "temperature Command : ${map.inspect()}"
state.lastReportedTemp = ftemp
state.lastReportTime = nowTime
sendEvent(name: "forcedWakeUp", value: 0, displayed: false)
// For Test purpose; redondant with reportNext() => device.forcedWakeUp=1
if (device.currentValue('reportASAP')==1) {sendEvent(name: "reportASAP", value: 0, isStateChange: true)}
return createEvent(map)
// } else {
log.debug "+++++++++discarded temperature report : rate change : ${(((ftemp-state.lastReportedTemp).abs())/(nowTime-state.lastReportTime))*1000}°C/s"
def sensorValueEvent(value) {
if (value) {
createEvent(name: "contact", value: "open", descriptionText: "$device.displayName is open [sensorValueEvent]")
} else {
createEvent(name: "contact", value: "closed", descriptionText: "$device.displayName is closed [sensorValueEvent]")
// BasicReport should never occur since all status change notifications are asynchronous via BasicSet
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicReport cmd) {
sensorValueEvent(cmd.value)
if (state.debugLevel>=2) {log.debug "basicv1.BasicReport $cmd.value"}
def openClosed(cmd, cmdValue) {
def theState = cmdValue == 0 ? "closed" : "open"
if (state.debugLevel>=2) {log.debug "openClosed $cmd"}
// Use closed/open sensor notification to trigger push of updated Temperature value and immediate setting of updated device parameters
// Sometimes, Temperature forced refresh stops working : SensorMultilevelGet(sensorType: 1, scale: 0) Commands are stacked but not executed immediately;
// will restart after some time, and stacked Commands will be executed !
def event = createEvent(name:"contact", value:"${theState}", descriptionText:"${device.displayName} is ${theState}", isStateChange:true, displayed:true, linkText:"${device.displayName}")
sendEvent(name: "forcedWakeUp", value: 1, displayed: false)
return [event, response(wakeUpResponse([]))]
// pre-ZW5 : BasicSet alarm does not seem to wait for any Commands answers, going back to sleep immediately;
// thus it cannot perform proper initial Configuration => use the Tamper switch and SensorAlarmReport instead
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicSet cmd) {
log.debug "basicv1.BasicSet $cmd"
if ((device.currentValue('ZW5set')) && (!(device.currentValue('ZW5')))) {
def cmdValue = cmd.value
return openClosed(cmd, cmdValue)
// For pre-ZW5, SensorBinaryReport should never occur since all status change notifications are asynchronous via BasicSet...
// ...but ZW5 uses it in addition to BasicSet and Notification
def zwaveEvent(hubitat.zwave.commands.sensorbinaryv2.SensorBinaryReport cmd) {
log.debug "sensorbinaryv2.SensorBinaryReport $cmd"
def cmdValue = cmd.sensorValue
// ZW5 : it is assumed that default notification events are used
// (parameter 20 was not changed before device's re-inclusion)
def zwaveEvent(hubitat.zwave.commands.notificationv3.NotificationReport cmd) {
def map = [:]
if (cmd.notificationType == 6) {
switch (cmd.event) {
case 22:
map.name = "contact"
map.value = "open"
map.descriptionText = "${device.displayName} is open"
break
case 23:
map.value = "closed"
map.descriptionText = "${device.displayName} is closed"
break
// Contrary to pre-ZW5 Devices, the Tamper Notification does not occur for only a brief
// push>release of the Tamper button. But it DOES occur when the Tamper button is released
// 1mn or so after being pushed.
} else if (cmd.notificationType == 7) {
case 0:
map.name = "tamper"
map.value = "inactive"
map.descriptionText = "${device.displayName} tamper detection enabled"
break
case 3:
map.name = "tamper"
map.value = "active"
map.descriptionText = "${device.displayName} is tampered with !"
break
def event = createEvent(map)
// SensorAlarmReport DOES wait for optional Commands answers, contrary to BasicSet
def zwaveEvent(hubitat.zwave.commands.sensoralarmv1.SensorAlarmReport cmd) {
if (state.debugLevel>=2) {log.debug "sensoralarmv1.SensorAlarmReport $cmd.sensorState"}
if (!(device.currentValue('ZW5'))) {
def event = createEvent(name:"alarm", descriptionText:"${device.displayName} is tampered with !", isStateChange:true, displayed:true, linkText:"${device.displayName}")
def cmdBlock = []
cmdBlock=wakeUpResponse(cmdBlock)
def zwaveEvent(hubitat.zwave.commands.batteryv1.BatteryReport cmd) {
log.debug "batteryv1.BatteryReport ${cmd.batteryLevel}"
log.debug "state.batteryInterval : ${state.batteryInterval}"
if ((nowTime-state.lastReportBattery > state.batteryInterval) || device.currentValue('forcedWakeUp')) {
def map = [ name: "battery", displayed: true, isStateChange:true, unit: "%" ]
if (cmd.batteryLevel == 0xFF) {
map.value = 1
map.descriptionText = "${device.displayName} has a low battery"
map.isStateChange = true
} else {
map.value = cmd.batteryLevel
state.lastReportBattery = nowTime
log.debug "battery map : ${map}"
return [createEvent(map)]
def zwaveEvent(hubitat.zwave.commands.configurationv2.ConfigurationReport cmd) {
if (state.debugLevel>=2) {log.debug "ConfigurationReport - Parameter#${cmd.parameterNumber}: ${cmd.configurationValue}"}
// Last configuration command execution; check UNIQUE(<>default) value is set
// A bit of an overkill : checking the cmd.parameterNumber (12 or 51) should be enough...
def byte tempQuantumSixteenth
tempQuantumSixteenth = 16 /* 16/16=1°C = 1.8°F */
} else {
tempQuantumSixteenth = 4 /* 5/16=0.31°C = 0.56°F */
if (device.currentValue('ZW5set') && !(device.currentValue('ZW5')) && (cmd.parameterNumber == 12) && (cmd.configurationValue == [tempQuantumSixteenth])) {
sendEvent(name: "Configured", value: 1, isStateChange: true)
log.debug ("++++++Non-ZW5 Device Configured++++++")
def byte tempQuantumTenth
tempQuantumTenth = 10 /* 10/10=1°C = 1.8°F */
} else {
tempQuantumTenth = 2 /* 3/10=0.3°C = 0.56°F */
if (device.currentValue('ZW5set') && device.currentValue('ZW5') && (cmd.parameterNumber == 51) && (cmd.configurationValue == [0,tempQuantumTenth])) {
log.debug ("++++++ZW5 Device Configured++++++")
def zwaveEvent(hubitat.zwave.commands.associationv2.AssociationReport cmd) {
def result = []
if (cmd.nodeId.any { it == zwaveHubNodeId }) {
result << createEvent(descriptionText: "$device.displayName is associated in group ${cmd.groupingIdentifier}")
} else if (cmd.groupingIdentifier == 1) {
// We're not associated properly to group 1, set association
result << createEvent(descriptionText: "Associating $device.displayName in group ${cmd.groupingIdentifier}")
result << response(zwave.associationV1.associationSet(groupingIdentifier:cmd.groupingIdentifier, nodeId:zwaveHubNodeId))
result
def zwaveEvent(hubitat.zwave.commands.multichannelv3.MultiChannelEndPointReport cmd) {
if (state.debugLevel>=2) {log.debug "multichannelv3.MultiChannelCapabilityReport: ${cmd}"}
def zwaveEvent(hubitat.zwave.commands.multichannelv3.MultiChannelCapabilityReport cmd) {
// ZW5 added : discriminate between ZW5 and pre-ZW5 Devices
// ZW5 : ${cmd.applicationVersion}.${cmd.applicationSubVersion}>=3.2 ; pre-ZW5 : <= 2.5
def zwaveEvent(hubitat.zwave.commands.versionv1.VersionReport cmd) {
//updateDataValue("version", "${cmd.applicationVersion}.${cmd.applicationSubVersion}")
log.debug "versionv1.VersionReport: ${cmd}"
log.debug "applicationVersion: ${cmd.applicationVersion}"
log.debug "applicationSubVersion: ${cmd.applicationSubVersion}"
def deviceFirmwareVersion = (java.lang.Short) cmd.applicationVersion*1000 + cmd.applicationSubVersion
log.debug "deviceFirmwareVersion: ${deviceFirmwareVersion}"
if (deviceFirmwareVersion >= 3002) {
sendEvent(name: "ZW5", value: 1, isStateChange: true)
} else {
sendEvent(name: "ZW5", value: 0, isStateChange: true)
sendEvent(name: "ZW5set", value: 1)
log.debug "device.ZW5set: ${device.currentValue('ZW5set')}"
log.debug "device.ZW5: ${device.currentValue('ZW5')}"
return [response(wakeUpResponse([]))]
// MultiChannelCmdEncap and MultiInstanceCmdEncap are ways that devices can indicate that a message
// is coming from one of multiple subdevices or "endpoints" that would otherwise be indistinguishable
def zwaveEvent(hubitat.zwave.commands.multichannelv3.MultiChannelCmdEncap cmd) {
def encapsulatedCommand = cmd.encapsulatedCommand([0x30: 2, 0x31: 5]) // can specify command class versions here like in zwave.parse
if (state.debugLevel>=2) {log.debug ("Command from endpoint ${cmd.sourceEndPoint}: ${encapsulatedCommand}")}
// Catch All command Handler in case of unexpected message
def zwaveEvent(hubitat.zwave.Command cmd) {
createEvent(descriptionText: "!!! $device.displayName: ${cmd}", displayed: false)
// When a Temperature Event got lost in transit, the Watchdog requests a forced report at next wake up
// The "reportNext()" alarm command is used to signal back from the Watchdog SmartApp to the sleepy device
def reportNext(commandMsg) {
log.debug "reportNext !"
log.debug "commandMsg : ${commandMsg}"
sendEvent(name: "forcedWakeUp", value: 1)
return []
// Initial Device Configuration and Handler Update
// Executed each time the Handler is updated
def updated() {
log.debug "Updated !"
def bytesToCRC = [0x56, 0x01, 0x31, 0x05, 0x01, 0x42, 0x09, 0x79]
//log.debug "checksum 0BD3/3027 : zwaveCrc16([0x56, 0x01, 0x31, 0x05, 0x01, 0x42,0x09, 0x79]) : ${zwaveCrc16(bytesToCRC as byte[])}"
sendEvent(name: "ZW5set", value: 0)
sendEvent(name: "ZW5", value: 0)
sendEvent(name: "Configured", value: 0) // set to true by the LAST Command Response from configureDev()
// All state.xxx attributes are Device-local, NOT Location-wide
// BEWARE : state.xxx attributes are vulnerable to race conditions; when not mostly read-only, use device.xxx instead
state.lastReportedTemp = (float) -1000
state.lastReportTime = (long) 0
state.lastReportBattery = (long) 0
state.longDelay = 1200
state.shortDelay = 1200
// Real-time clock of sensors (ceramic resonator) is up to 3% inaccurate
state.batteryInterval = (long) (24*60-45)*60*1000 // 83 700 000 : at least 1 Battery Report event every 23:15 hours
state.maxEventInterval = (long) (2*60-20)*60*1000 // 13 200 000 : at least 1 Temperature Report event every 3:40 hours (4 hours at most)
state.parseCount=(int) 0
if (!(state.deviceID)) {state.deviceID = device.name}
log.debug "state.deviceID: ${state.deviceID}"
sendEvent(name: "reportASAP", value: 1)
log.debug "device.currentValue('reportASAP') : ${device.currentValue('reportASAP')}"
// configureDev() // will be defered till first wakeup (forced or periodic)
infos()
// If you add the Configuration capability to your device type, this command will be called right
// after the device joins to set device-specific configuration commands.
def configure() {
return configureDev()
def configureDev() {
def cmdBlock = []
log.debug "device.Configured: ${device.currentValue('Configured')}"
/////////////// Common configuration
if (!(device.currentValue('ZW5set'))) {
log.debug "Configuring - Common Part............................................."
log.debug "cmdBlock: ${cmdBlock}"
cmdBlock << zwave.versionV1.versionGet().format()
log.debug "++++++Last Common Configuration Command SENT++++++"
return cmdBlock
/////////////// Non-ZW5 specific configuration
if (!(device.currentValue('Configured')) && device.currentValue('ZW5set') && !(device.currentValue('ZW5'))) {
log.debug "Configuring - NON ZW5............................................."
// Make sure sleepy battery-powered sensors send their WakeUpNotifications to the hub
cmdBlock << zwave.wakeUpV2.wakeUpIntervalSet(seconds:60*60, nodeid:zwaveHubNodeId).format()
} else {
tempQuantumSixteenth = 2 /* 5/16=0.31°C = 0.56°F */
log.debug "tempQuantumSixteenth : ${tempQuantumSixteenth}"
// NOTE : any asynchronous temperature query thru SensorMultilevelGet(sensorType: 1, scale: 0) does NOT reset the delta-Temp base value (managed by DS18B20 hardware)
cmdBlock << zwave.configurationV2.configurationSet(parameterNumber: 12/*for FGK101*/, size: 1, configurationValue: [tempQuantumSixteenth]).format()
// inclusion of Device in Association#3 is needed to get delta-Temperature notification messages [cf Parameter#12 above]
cmdBlock << zwave.associationV2.associationSet(groupingIdentifier:3, nodeId:[zwaveHubNodeId]).format()
// inclusion of Device in Association#2 is needed to enable SensorAlarmReport() Command [anti-Tampering protection]
cmdBlock << zwave.associationV2.associationSet(groupingIdentifier:2, nodeId:[zwaveHubNodeId]).format()
// Should be last for proper checking of complete initialization (through configurationReport)
cmdBlock << zwave.configurationV2.configurationGet(parameterNumber: 12/*for FGK101*/).format()
//cmdBlock << zwave.wakeUpV2.wakeUpNoMoreInformation().format()
log.debug "++++++Last non-ZW5 Configuration Command SENT++++++"
/////////////// ZW5 specific configuration
if (!(device.currentValue('Configured')) && device.currentValue('ZW5set') && device.currentValue('ZW5')) {
log.debug "Configuring - ZW5............................................."
//cmdBlock << "delay ${state.shortDelay}"
cmdBlock << encap(zwave.wakeUpV2.wakeUpIntervalSet(seconds:60*60, nodeid:zwaveHubNodeId))
def short tempQuantumTenth
log.debug "device.displayName.substring(0,1) : ${device.displayName.substring(0,1)}"
} else {
tempQuantumTenth = 1 /* 3/10=0.3°C = 0.56°F */
// sensorMultilevelGet() should be +++PROPERLY+++ CRC16 encoded ! buggy ZW5 Fibaro handler w/ checksum = 0x0000 !!
// ZW5 : completely buggy synchronous sensorMultilevelReport() : +/- 1°C vs unsolicited asynchronous reports : ???
cmdBlock << encap(zwave.configurationV2.configurationSet(parameterNumber: 3/*for FGK101*/, size: 1, configurationValue: [5])) // LED blinks on Tampering & Open/Close
// measuring temperature every 5mn drains the battery in a few months... but every hour creates a prejudiciable latency...
cmdBlock << encap(zwave.configurationV2.configurationSet(parameterNumber: 50/*for FGK101*/, size: 2, configurationValue: [0x03,0x84])) // measure temperature every 15mn = 900s = 0x384
cmdBlock << encap(zwave.configurationV2.configurationSet(parameterNumber: 51/*for FGK101*/, size: 2, configurationValue: [0,tempQuantumTenth])) // less than 256...
// ??? : parameter#52 seems to translate "1 second" into "1.92 second", based on actual measurements
// => downrate 14 400 to 7 510 to compensate
//cmdBlock << encap(zwave.configurationV2.configurationSet(parameterNumber: 52/*for FGK101*/, size: 2, configurationValue: [0x38,0x40])) // 0x3840 = 14400 = 4*3600 = 4 hours
cmdBlock << encap(zwave.configurationV2.configurationSet(parameterNumber: 52/*for FGK101*/, size: 2, configurationValue: [0x1D,0x56])) // 0x1D56 = 7510
// 1st Association Group : "Lifeline" reports the device status and allows for assigning single device only (main controller by default)
cmdBlock << encap(zwave.associationV2.associationSet(groupingIdentifier:1, nodeId: [zwaveHubNodeId]))
// 2nd Association Group : "Control" is assigned to the device status - reed sensor and IN input (sends alarm command frames).
cmdBlock << encap(zwave.associationV2.associationSet(groupingIdentifier:2, nodeId: [zwaveHubNodeId]))
cmdBlock << encap(zwave.configurationV2.configurationGet(parameterNumber: 51/*for FGK101*/))
log.debug "++++++Last ZW5 Configuration Command SENT++++++"
//log.debug "device.Configured: ${device.currentValue('Configured')}"
return cmdBlock // Fully configured only after 2 Configure() calls
def infos() {
if (!state.devices) { state.devices = [:] }
log.debug "zwaveHubNodeId: ${zwaveHubNodeId}" // -> "1"
log.debug "device.displayName: ${device.displayName}" // -> "JJG"
log.debug "device.id: ${device.id}" // -> "d93f6450-4c9b-4892-bfcb-d61353f4c793"
log.debug "location.id: ${location.id}" // -> "99e95fb7-726f-4c64-a4f5-7b2151cf166a" [Le Puits Jamet]
log.debug "device.name: ${device.name}" // -> "T005"
log.debug "device.label: ${device.label}" // -> "JJG"
log.debug "device.data: ${device.data}" // -> "[MSR: 010F-0700-2000, endpointId: 0, version: 2.1]"
log.debug "device.rawDescription: ${device.rawDescription}" // -> non-ZW5 : "0 0 0x2001 0 0 0 c 0x30 0x9C 0x60 0x85 0x72 0x70 0x86 0x80 0x84 0x7A 0xEF 0x2B"
// -> ZW5 : "zw:Ss type:0701 mfr:010F prod:0701 model:2001 cc:5E,59,22,80,56,7A,72,73,98,31,86 sec:85,20,70,5A,8E,71,2B,9C,30,84"
* Calculates the 16-bit CRC (CRC-CCITT) for a byte array.
* Uses initial crc of 0x1D0F, and poly of 0x1021, as per Z-wave specification.
* Reference: http://z-wave.sigmadesigns.com/wp-content/uploads/2016/08/SDS12652-13-Z-Wave-Command-Class-Specification-N-Z.pdf
* Thanks to CODERSAUR : https://community.smartthings.com/t/handling-crc-16-encapsulation-commands-crc16encap/76931/4
private zwaveCrc16(byte[] bytes) {
short crc = 0x1D0F // It's important this is a short (16-bit)
short poly = 0x1021
bytes.each { workData ->
//for (bitMask = 0x80; bitMask != 0; bitMask >>= 1) {
// Need to use a different way to iterate, as rightshift operator '>>' and unsigned rightshift '>>>' do not appear to work in SmartThings.
[0b10000000,0b01000000,0b00100000,0b00010000,0b00001000,0b00000100,0b00000010,0b00000001].each { bitMask ->
def newBit = ((workData & bitMask) != 0) ^ ((crc & 0x8000) != 0);
crc <<= 1;
if (newBit) { crc ^= poly; }
return crc
// CRC16 Encoding for Hub's +++OUTGOING+++ Commands
private crc16Encode(hubitat.zwave.Command cmd) {
log.debug "cmd: ${cmd}"
def bytesToCRC = [0x56, 0x01, cmd.commandClassId, cmd.commandId]
bytesToCRC += cmd.payload
log.debug "bytesToCRC: ${bytesToCRC}"
def short checksum = zwaveCrc16(bytesToCRC as byte[])
log.debug "5601${cmd.format()}${Integer.toHexString(checksum & 0xFFFF).toUpperCase()}"
return "5601${cmd.format()}${Integer.toHexString(checksum & 0xFFFF).toUpperCase()}"
//ZW5 added
private secure(hubitat.zwave.Command cmd) {
zwave.securityV1.securityMessageEncapsulation().encapsulate(cmd).format()
//ZW5 added
private encap(hubitat.zwave.Command cmd) {
def secureClasses = [0x20, 0x2B, 0x30, 0x5A, 0x70, 0x71, 0x84, 0x85, 0x8E, 0x9C]
//todo: check if secure inclusion was successful
//if not do not send security-encapsulated command
if ((device.currentValue('ZW5set')) && (device.currentValue('ZW5'))) {
if (secureClasses.find{ it == cmd.commandClassId }) {
secure(cmd)
} else {
// ??? : very dubious all UNsecure outgoing ZW5 commands have to be CRC16 encoded;
// sensorMultiLevelGet() MUST be, but for sure
// batteryGet() and versionGet() need NOT be ! (but could be ?)
crc16Encode(cmd) // crc16() Fibaro code w/ checksum = 0x0000 was buggy
} else {
return cmd.format()
