Has anyone got this to work hubitat? I love this little button device with my smartthings setup. Any stock handlers that could be used to expose all the pushes on this thing.?
So I paired this up with hubitat. It has minimal function currently through the exposed switches.
I can see button events for 1-6 on the events page. Webcore and the button controller app see the buttons. Just no reponse when I push them. Here is the code. Any thoughts on getting this to work properly?
* Fibaro KeyFob
* Copyright 2017 Artur Draga
* Special thanks to Eric "erocm123" Maycock for help with the code.
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
metadata {
definition (name: "Fibaro KeyFob", namespace: "ClassicGOD", author: "Artur Draga") {
capability "Actuator"
capability "Battery"
capability "PushableButton"
capability "HoldableButton"
capability "Switch"
capability "Configuration"
(1..30).each{ n ->
if (n in (1..6)) {
attribute "switch$n", "string"
attribute "buttonPressed$n", "string"
attribute "buttonHeld$n", "string"
attribute "buttonRelease$n", "string"
attribute "numberOfButtons", "string"
command "on$n"
command "off$n"
command "button$n"
attribute "syncStatus", "string"
attribute "batteryStatus", "string"
command "forceSync"
command "menuButton"
fingerprint deviceId: "0x1801" , inClusters: "0x5E,0x59,0x80,0x56,0x7A,0x73,0x98,0x22,0x85,0x5B,0x70,0x5A,0x72,0x8E,0x86,0x84,0x75"
fingerprint deviceId: "0x1801" , inClusters: "0x5E,0x85,0x59,0x80,0x5B,0x70,0x56,0x5A,0x7A,0x72,0x8E,0x73,0x86,0x84,0x75,0x22"
preferences {
input (
type: "paragraph",
element: "paragraph",
title: "Lock Mode:",
description: "The KeyFob can be protected with a sequence of 2 to 5 button clicks. It can be locked by being inactive for time set or pressing and holding selected button"
input name: "protection", title: "Protection State", type: "enum", options: [0: "Unprotected", 1: "Protection by sequence"], required: false
input name: "unlockSeq", type: "number", title: "Unlocking Sequence:", required: false
input name: "lockTim", type: "number", title: "Time To Lock", required: false
input name: "lockBtn", type: "number", title: "Locking Button", required: false
input (
type: "paragraph",
title: "Sequences:",
description: "User can create sequences of two to five button to expand numberof possible actions. \n\nSet button sequence using button numbers 1 to 6 (for example: 1234)"
parameterMap().findAll( {it.key.contains('seq')} ).each {
input (
title: it.descr,
type: "number",
required: false
input (
type: "paragraph",
title: "Button Modes:",
description: "Select button modes.\nActivating a double click will introduce delay to a single click reaction and activating a triple click will introduce delay to a double click reaction."
parameterMap().findAll( {it.key.contains('btn')} ).each {
log.debug "${it.key} line 80"
input (
title: it.descr,
type: "enum",
options: [
1: "1 Click",
2: "2 Clicks",
3: "1 & 2 Clicks",
4: "3 Clicks",
5: "1 & 3 Clicks",
6: "2 & 3 Clicks",
7: "1, 2 & 3 Clicks",
8: "Hold and Release",
9: "1 Click & Hold (Default)",
10: "2 Clicks & Hold",
11: "1, 2 Clicks & Hold",
12: "3 Clicks & Hold",
13: "1, 3 Clicks & Hold",
14: "2, 3 Clicks & Hold",
15: "1, 2, 3 Clicks & Hold"
required: false
input name: "menuButton", type: "number", title: "Button number to be activated from main menu:", required: false
input name: "logging", title: "Logging", type: "boolean", required: false
def installed() {
initialize()
def initialize() {
sendEvent(name: "numberOfButtons", value: 29)
state.lastUpdated = now()
parameterMap().each {
log.debug "${it.key} line 120"
state."$it.key" = [value: null, state: "synced"]
log.debug "${state.it.key} line 120"
state.protection = [value: null, state: "synced"]
def zwaveEvent(hubitat.zwave.commands.wakeupv2.WakeUpNotification cmd) {
log.info "$device.displayName woke up"
def cmdsSet = []
def cmdsGet = []
def cmds = []
def Integer cmdCount = 0
def results = [createEvent(descriptionText: "$device.displayName woke up", isStateChange: true)]
cmdsGet << zwave.batteryV1.batteryGet()
log.debug "${it.key} line 137"
if (device.currentValue("syncStatus") != "synced") {
log.debug "${device.currentValue("syncStatus")} line 173"
if (device.currentValue("syncStatus") == "force") { state."$it.key".state = "notSynced" }
if (state."$it.key".value != null && state."$it.key".state == "notSynced") {
cmdsSet << zwave.configurationV2.configurationSet(configurationValue: intToParam(state."$it.key".value, it.size), parameterNumber: it.num , size: it.size)
cmdsGet << zwave.configurationV2.configurationGet(parameterNumber: it.num)
cmdCount = cmdCount + 1
if (device.currentValue("syncStatus") == "force") { state.protection.state = "notSynced" }
if ( state.protection.value != null && state.protection.state == "notSynced") {
cmdsSet << zwave.protectionV2.protectionSet(localProtectionState: state.protection.value )
cmdsGet << zwave.protectionV2.protectionGet()
sendEvent(name: "syncStatus", value: "inProgress")
runIn((5+cmdCount*1.5), syncCheck)
if (cmdsSet) {
cmds = encapSequence(cmdsSet,500)
cmds << "delay 500"
cmds = cmds + encapSequence(cmdsGet,1000)
cmds << "delay "+(5000+cmdCount*1500)
cmds << encap(zwave.wakeUpV1.wakeUpNoMoreInformation())
results = results + response(cmds)
//sendHubCommand(response(cmds))
return results
def zwaveEvent(hubitat.zwave.commands.configurationv2.ConfigurationReport cmd) {
def paramKey
paramKey = parameterMap().find( {it.num == cmd.parameterNumber } ).key
if (state."$paramKey".value == cmd.scaledConfigurationValue) {
state."$paramKey".state = "synced"
def zwaveEvent(hubitat.zwave.commands.protectionv2.ProtectionReport cmd) {
if (state.protection.value == cmd.localProtectionState) {
state.protection.state = "synced"
def zwaveEvent(hubitat.zwave.commands.batteryv1.BatteryReport cmd) {
log.info "$device.displayName battery is $cmd.batteryLevel ($cmd)"
def timeDate = new Date().format("yyyy MMM dd EEE HH:mm:ss", location.timeZone)
sendEvent(name: "batteryStatus", value: "Battery: $cmd.batteryLevel%\n($timeDate)")
sendEvent(name: "battery", value: cmd.batteryLevel)
def zwaveEvent(hubitat.zwave.commands.applicationstatusv1.ApplicationRejectedRequest cmd) {
log.warn "KeyFob rejected onfiguration!"
sendEvent(name: "syncStatus", value:"failed")
def zwaveEvent(hubitat.zwave.commands.protectionv2.ProtectionSupportedReport cmd) {
log.debug cmd
def zwaveEvent(hubitat.zwave.commands.centralscenev1.CentralSceneNotification cmd) {
def realButton = cmd.sceneNumber as Integer //1-6 physical, 7-12 sequences
def keyAttribute = cmd.keyAttributes as Integer
def Integer mappedButton
def String action
/* buttons:
1-6 Single Presses
7-12 Double Presses
13-18 Tripple Presses
19-24 Held Buttons
25-30 Sequences
if (keyAttribute in [1,2]) {
mappedButton = 18 + realButton
if (keyAttribute == 1) {
action = "off"
} else {
action = "on"
} else {
if (keyAttribute == 0) {
if (realButton > 6) {
} else {
mappedButton = realButton
} else {
mappedButton = 6*(keyAttribute-2)+realButton
action = "pushed"
buttonEvent( mappedButton, action )
def updated() {
if ( state.lastUpdated && (now() - state.lastUpdated) < 500 ) return
sendEvent(name: "numberOfButtons", value: 30)
def Integer tempValue
def Integer syncRequired = 0
if(settings."$it.key" != null || it.key == "lockBtnTim" ) {
switch (it.type) {
case "buttonTime": tempValue = btnTimToValue(); break
case "sequence": tempValue = seqToValue(settings."$it.key"); break
case "mode": tempValue = settings."$it.key" as Integer; break
case "number": tempValue = settings."$it.key"; break
if (state."$it.key" == null) { state."$it.key" = [value: null, state: "synced"] }
if (state."$it.key".value != tempValue) {
syncRequired = 1
state."$it.key".value = tempValue
if (state.protection == null) { state.protection = [value: null, state: "synced"] }
if(state.protection != null) {
tempValue = settings.protection as Integer
if (state.protection.value != tempValue) {
syncRequired = 1
state.protection.value = tempValue
if ( syncRequired !=0 ) { sendEvent(name: "syncStatus", value: "pending") }
def on1() { buttonEvent(19,"on") }
def on2() { buttonEvent(20,"on") }
def on3() { buttonEvent(21,"on") }
def on4() { buttonEvent(22,"on") }
def on5() { buttonEvent(23,"on") }
def on6() { buttonEvent(24,"on") }
def off1() { buttonEvent(19,"off") }
def off2() { buttonEvent(20,"off") }
def off3() { buttonEvent(21,"off") }
def off4() { buttonEvent(22,"off") }
def off5() { buttonEvent(23,"off") }
def off6() { buttonEvent(24,"off") }
def button1() { buttonEvent(1,"pushed") }
def button2() { buttonEvent(2,"pushed") }
def button3() { buttonEvent(3,"pushed") }
def button4() { buttonEvent(4,"pushed") }
def button5() { buttonEvent(5,"pushed") }
def button6() { buttonEvent(6,"pushed") }
def button7() { buttonEvent(7,"pushed") }
def button8() { buttonEvent(8,"pushed") }
def button9() { buttonEvent(9,"pushed") }
def button10() { buttonEvent(10,"pushed") }
def button11() { buttonEvent(11,"pushed") }
def button12() { buttonEvent(12,"pushed") }
def button13() { buttonEvent(13,"pushed") }
def button14() { buttonEvent(14,"pushed") }
def button15() { buttonEvent(15,"pushed") }
def button16() { buttonEvent(16,"pushed") }
def button17() { buttonEvent(17,"pushed") }
def button18() { buttonEvent(18,"pushed") }
def button25() { buttonEvent(25,"pushed") }
def button26() { buttonEvent(26,"pushed") }
def button27() { buttonEvent(27,"pushed") }
def button28() { buttonEvent(28,"pushed") }
def button29() { buttonEvent(29,"pushed") }
def button30() { buttonEvent(30,"pushed") }
def menuButton() {
if (settings.menuButton == null ) {
} else {
buttonEvent(settings.menuButton as Integer,"pushed")
def buttonEvent(button, action) {
button = button as Integer
def switchNr = button - 18 as Integer
if (action == "pushed") {
sendEvent(name: "button", value: "pushed", data: [buttonNumber: button], descriptionText: "$device.displayName button $button was pushed", isStateChange: true)
} else if (action == "on"){
sendEvent(name: "switch$switchNr", value: "on", data: [switchNumber: switchNr], descriptionText: "$device.displayName switch $switchNr was turned on", isStateChange: true)
} else if (action == "off") {
sendEvent(name: "switch$switchNr", value: "off", data: [switchNumber: switchNr], descriptionText: "$device.displayName switch $switchNr was turned off", isStateChange: true)
def syncCheck() {
def Integer count = 0
if (state."$it.key".state == "notSynced" ) {
count = count + 1
if (state.protection.state != "synced") { count = count + 1 }
if (count == 0) {
sendEvent(name: "syncStatus", value: "synced")
} else {
if (device.currentValue("syncStatus") != "failed") {
sendEvent(name: "syncStatus", value: "incomplete")
def forceSync() {
if (device.currentValue("syncStatus") != "force") {
state.prevSyncState = device.currentValue("syncStatus")
sendEvent(name: "syncStatus", value: "force")
} else {
if (state.prevSyncState != null) {
sendEvent(name: "syncStatus", value: state.prevSyncState)
} else {
def seqToValue(sequence) {
sequence = sequence as String
def Integer size = sequence.length()
def Integer result = 0
if (size > 5) { size = 5; log.info "Sequence too long, will be trimmed." }
(0..size-1).each{ n ->
result = result + ((sequence[n] as Integer) * (8**n))
return result
def modeToValue(mode) {
def Integer result
switch (mode) {
case "1 Click": result = 1; break;
case "2 Clicks": result = 2; break;
case "1 & 2 Clicks": result = 3; break;
case "3 Clicks": result = 4; break;
case "1 & 3 Clicks": result = 5; break;
case "3 & 2 Clicks": result = 6; break;
case "1, 2 & 3 Clicks": result = 7; break;
case "Hold and Release": result = 8; break;
case "1 Click & Hold": result = 9; break;
case "2 Clicks & Hold": result = 10; break;
case "1, 2 Clicks & Hold": result = 11; break;
case "3 Clicks & Hold": result = 12; break;
case "1, 3 Clicks & Hold": result = 13; break;
case "2, 3 Clicks & Hold": result = 14; break;
case "1, 2, 3 Clicks & Hold": result = 15; break;
return result
def btnTimToValue () {
def Integer buttonVal
def Integer timeVal
if (lockBtn) { buttonVal = (lockBtn as Integer)*256 } else { buttonVal = 0 }
if (lockTim) { timeVal = lockTim } else { timeVal = 0 }
if (timeVal > 255) { timeVal = 255 }
if (timeVal < 5 && timeVal != 0) { timeVal = 5 }
if (buttonVal > 1536) { buttonVal = 1536 }
return buttonVal+timeVal
## Z-Wave Toolkit ##
def result = []
logging("${device.displayName} - Parsing: ${description}")
if (description.startsWith("Err 106")) {
result = createEvent(
descriptionText: "Failed to complete the network security key exchange. If you are unable to receive data from it, you must remove it from your network and add it again.",
eventType: "ALERT",
value: "failed",
displayed: true
} else if (description == "updated") {
return null
} else {
def cmd = zwave.parse(description, cmdVersions())
if (cmd) {
logging("${device.displayName} - Parsed: ${cmd}")
zwaveEvent(cmd)
def zwaveEvent(hubitat.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
def encapsulatedCommand = cmd.encapsulatedCommand(cmdVersions())
if (encapsulatedCommand) {
logging("${device.displayName} - Parsed SecurityMessageEncapsulation into: ${encapsulatedCommand}")
zwaveEvent(encapsulatedCommand)
} else {
log.warn "Unable to extract secure cmd from $cmd"
def zwaveEvent(hubitat.zwave.commands.crc16encapv1.Crc16Encap cmd) {
def version = cmdVersions()[cmd.commandClass as Integer]
def ccObj = version ? zwave.commandClass(cmd.commandClass, version) : zwave.commandClass(cmd.commandClass)
def encapsulatedCommand = ccObj?.command(cmd.command)?.parse(cmd.data)
logging("${device.displayName} - Parsed Crc16Encap into: ${encapsulatedCommand}")
} else {
log.warn "Could not extract crc16 command from $cmd"
def zwaveEvent(hubitat.zwave.commands.multichannelv3.MultiChannelCmdEncap cmd) {
logging("${device.displayName} - Parsed MultiChannelCmdEncap ${encapsulatedCommand}")
zwaveEvent(encapsulatedCommand, cmd.sourceEndPoint as Integer)
} else {
log.warn "Could not extract multi channel command from $cmd"
private logging(text, type = "debug") {
if (settings.logging == "true") {
log."$type" text
private secEncap(hubitat.zwave.Command cmd) {
logging("${device.displayName} - encapsulating command using Secure Encapsulation, command: $cmd","info")
zwave.securityV1.securityMessageEncapsulation().encapsulate(cmd).format()
private crcEncap(hubitat.zwave.Command cmd) {
logging("${device.displayName} - encapsulating command using CRC16 Encapsulation, command: $cmd","info")
zwave.crc16EncapV1.crc16Encap().encapsulate(cmd).format() // doesn't work righ now because SmartThings...
//"5601${cmd.format()}0000"
private encap(hubitat.zwave.Command cmd) {
if (zwaveInfo.zw.contains("s") && zwaveInfo.sec.contains(Integer.toHexString(cmd.commandClassId).toUpperCase())) {
// if device is included securly and the command is on list of commands dupported with secure encapsulation
secEncap(cmd)
} else if (zwaveInfo.cc.contains("56")){
// if device supports crc16
crcEncap(cmd)
} else { // if all else fails send plain command
logging("${device.displayName} - no encapsulation supported for command: $cmd","info")
cmd.format()
private encapSequence(cmds, delay=250) {
delayBetween(cmds.collect{ encap(it) }, delay)
private List intToParam(Long value, Integer size = 1) {
def result = []
size.times {
result = result.plus(0, (value & 0xFF) as Short)
value = (value >> 8)
return result
## Device Configuration ##
private Map cmdVersions() {
[0x5E: 2, 0x59: 1, 0x80: 1, 0x56: 1, 0x7A: 3, 0x73: 1, 0x98: 1, 0x22: 1, 0x85: 2, 0x5B: 1, 0x70: 2, 0x8E: 2, 0x86: 2, 0x84: 2, 0x75: 2, 0x72: 2] //Fibaro KeyFob
//[0x5E: 1, 0x86: 1, 0x72: 2, 0x59: 1, 0x80: 1, 0x73: 1, 0x56: 1, 0x22: 1, 0x31: 5, 0x98: 1, 0x7A: 3, 0x20: 1, 0x5A: 1, 0x85: 2, 0x84: 2, 0x71: 3, 0x8E: 1, 0x70: 2, 0x30: 1, 0x9C: 1] //Fibaro Motion Sensor ZW5
//[0x5E: 1, 0x86: 1, 0x72: 1, 0x59: 1, 0x73: 1, 0x22: 1, 0x56: 1, 0x32: 3, 0x71: 1, 0x98: 1, 0x7A: 1, 0x25: 1, 0x5A: 1, 0x85: 2, 0x70: 2, 0x8E: 1, 0x60: 3, 0x75: 1, 0x5B: 1] //Fibaro Double Switch 2 (FGS-223) & FIBARO Single Switch 2 (FGS-213)
def push(value) {
sendEvent(name: "pushed", value: value, descriptionText: "$device.displayName button $value was pushed", isStateChange: true)
def parameterMap() { return [
[key: "unlockSeq", num: 1, size: 2, descr: "Unlocking Sequence", type: "sequence"],
[key: "lockBtnTim", num: 2, size: 2, descr: "Lock Time and Button", type: "buttonTime"],
[key: "seq1", num: 3, size: 2, descr: "First Sequence", type: "sequence"],
[key: "seq2", num: 4, size: 2, descr: "Second Sequence", type: "sequence"],
[key: "seq3", num: 5, size: 2, descr: "Third Sequence", type: "sequence"],
[key: "seq4", num: 6, size: 2, descr: "Fourth Sequence", type: "sequence"],
[key: "seq5", num: 7, size: 2, descr: "Fifth Sequence", type: "sequence"],
[key: "seq6", num: 8, size: 2, descr: "Sixth Sequence", type: "sequence"],
[key: "seqTim", num: 9, size: 1, descr: "Sequence Timeout", type: "number"],
[key: "btn1mode", num: 21, size: 1, descr: "Square (1) Button Mode", type: "mode"],
[key: "btn2mode", num: 22, size: 1, descr: "Circle (2) Button Mode", type: "mode"],
[key: "btn3mode", num: 23, size: 1, descr: "Saltire (3) Button Mode", type: "mode"],
[key: "btn4mode", num: 24, size: 1, descr: "Triangle (4) Button Mode", type: "mode"],
[key: "btn5mode", num: 25, size: 1, descr: "Minus (5) Button Mode", type: "mode"],
[key: "btn6mode", num: 26, size: 1, descr: "Plus (6) Button Mode", type: "mode"]
I have been dipping in and out of ClassicGOD's code for the keyfob trying to get it to work with HE.
So far I have 12 buttons reporting
1-6 click - report as buttons 1-6
1-6 hold - report as buttons 7-12
My next attack will be to see why syncing always returns as 'Incomplete'
Just don't have much time at the moment.
Hopefully someone who knows what they're doing will post a fully working DH at some point.
In the mean time here's a link to my modified classicGod code, it may help you move forward.
Thank you for taking the time to post. Much appreciated.
Hopes of me figuring out how to get it to parse everything correctly are slim.
From reading the other forums though I believe @Robin has one of these devices. Maybe he could guide us in the right direction if he is feeling helpful
My tenants have my key fob...
I have made some progress with this and have it pretty much working.
If you feel like trying it that would be great and if it works OK i'll tidy up the code (lots of debug logging) and post it in the Code Share thread.
I had to work around a couple of issues:-
I had to force it to use securityMessagingEncapsulation.
Checking the preference - Protection State ('Unprotected' or 'Protection by sequence') during the sync check was returning notSynced if set to Unprotected. So now the code just checks that it has been set.
Hey this is fantastic news. Besides my nest cameras this is the last device needing integration. I doubt any integration with nest cams will be very useful.
I killed they battery on on my fob in my previous testing. As soon as another arrives I will gladly give this driver a run. I really like this little thing - although like many reviews Ive seen I shredded the back plate getting the battery out. Wish it were a little tougher.
Thanks for taking the time to do this.
I just gave it a shot.
Still getting this error.
:errorCannot get property 'value' on null object on line 165.
Can you describe your settings and sequence for pairing?
That error is strange. Not had that here.
My best guess is that the parameter map has not been set up correctly.
It is set up by the initialize() method on first install.
Try the following it may work.
Try uncommenting line 46 of the code
//command "installed"
and save.
Refresh the keyfob's device page and a new button should appear named installed.
Click it and maybe that will rerun the initialize() method.
Worth a try.
If it works re comment line 46
If that doesn't work you may have to exclude the keyfob from hubitat. Factory reset the fob then add the fob back as a new device.
Sorry for the false alarm.
Stayed up another hour and got it working. Seems it had to do with 1. Not having empty fields. and 2. Having values that the fob wouldnt reject during the sync process. Took a few tries but everything paired up and worked.
thank you for all your help on this!!!
Just wanted to confirm this driver supports this device. If so how are all the buttons mapped? Does this driver support all 30 "buttons" of this device. Or is is setup for push, held and released?
Pushed held and released on all 6 buttons
I just got my fibaro keyfob. Is still only working for push, held and release? I understand that the device itself supports 30 actions (4 for each button) but with the push, held and release would only be 18 actions.
Yes, those are the only actions supported
The code @Inpier posted above worked for me for a long time to support the full capability of this fob. Which is far greater than what is exposed in the hubitat driver.
I dont think @mike.maxwell will do anything with all the the other capabilities as they dont mesh well with the hubitat button implementation. Just my thoughts.
hey @cwwilson08 great, looks like with this driver the fibaro keyfob will offer multiple options but I am not sure I understand them all or how to use them. Is there anywhere that they are explained?? do I need an specific app to use it ??
I just got mine too, in 3 weeks the battery lost 23%. I read other comments about poor battery life. I think I'm going to return mine and get another 4 button Iris fob, which has much much better battery life and almost as many buttons, or at least all the buttons I need.
The fibaro is very sleek & sexy looking, but don't like the random button icons, nor the crappy battery life, back it went. 40 bucks! sheesh
@bcopeland or @mike.maxwell is there any chance the built in driver for this device can be revisited? This device is capable of a lot more.
Can you give me a summary of what it’s missing?
