Enphase Envoy - Solar Monitoring?
Just got my Enphase solar system installed today, and now exploring my options for connecting into my Hubitat setup to determine what information I can gather and report on and/or build automations against.
As far as I can tell, there is a an application in HPM (older) as well as a Driver ([RELEASE] New Enphase Envoy driver supports token based authentication - #51 by luke.sudkamp) that appears to be recently supported.
Just curious what in fact people are using, and if the driver referenced is the best available, or other integrations exist?
Thank you!
Hi,
I am using this Enphase Solar monitoring for local reading, but I have a first generation Envoy-R-EU gateway. Not sure if it works on the latest from Enphase. This will give actual production KW (15 min interval), todays KWh, last 7 days KWh, month to date KWh and lifetime KWh.
Cheers Rene
I wrote my own driver that works with enphase envoy. The token is too long to save as a hub variable so the driver has a method that allows me to re-load it after a hub re-boot. Not a fan of token based api access that needs to be periodically renewed at enphase for my own installation btw.
