Thanks for spotting this @snell , I had somehow missed it.
Looking at the version you are running @rob17 , it looks like you are running the final version of the Ecowitt driver that Mirco produced. I took over the drivers in August 2021:
There are some notes on the post below explaining how best to transition onto the current drivers from an existing installation. I would recommend upgrading. I'd have to check back through the changes I made to the code, but there was one in Dec '21 where I replaced the time attribute with a lastUpdate attribute, which may have been done in such as a way to address the error you are seeing, but I can't be 100% sure about that without some more investigation.
If you would prefer to keep using Mirco's version of the drivers, that's fine. I would expect you could just comment out the line where the time is being set, but again, I would need to look at the code to determine what the impact may be if you do that.
