Great to hear! Something like this is badly needed for hubitat. Updating apps/drivers is really painful right now.
I just wanted to make sure that the format is complete so I don't have to keep re-making json files..
markus
May 7, 2020, 12:38am
89
That's what an automated build environment is for;)
Gnant
May 7, 2020, 3:33pm
90
bcopeland:
safe from the IRS
hahahahahahahhahahahahahahaha
@bcopeland Not sure if you would be interested or not. There is a thread about a outdoor 2 outlet plug (both outlets controllable) that I gave a link to the device on Amazon. It is a EVA Logic ZW97. The compatible list shows 2 other outlets but no ZW97. Might be a few people who could use a double controlled outdoor outlet.
@razorwing This will work:
* Inovelli 2-Channel Outdoor Smart Plug NZW97
* Author: Eric Maycock (erocm123)
* Date: 2020-04-03
* Copyright 2020 Eric Maycock / Inovelli
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* 2019-11-20: Fixed Association Group management.
* 2018-05-02: Added support for Z-Wave Association Tool SmartApp. Associations require firmware 1.02+.
* https://github.com/erocm123/SmartThingsPublic/tree/master/smartapps/erocm123/z-waveat
This file has been truncated. show original
It's the same white label manufacturer..
Fantastic, I will post the link. Thanks
If it doesn't work right .. let me know and I'll get one.. but it should since it is both the same device with different marketing
Updated to support Ring Range Extender Gen 2
** All of these exist as built-in drivers and the community versions are no longer maintained **
Standard Features
Device Data
Device Serial Number
Device Hardware Revision
Device Firmware Revision
Device protocol Version
Ring Alarm Range Extender - Gen1 and Gen2
[ringExtenderGen1-Gen2Capture]
Driver Capabilities
Battery
PowerSource
Configurable Options
Reporting Intervals
Ring Alarm Contact Sensor
[image]
Driver Capabilities
ContactSensor
Battery
TamperAlert
Thanks for the Shout Out @agnes.zooz
EAN
May 15, 2020, 12:02am
104
You getting ready to put your work on the package manager? looks at github
Most of it is.. I have a few new ones I need to add..
