De old and the new driver were installes simultaniously. I removed the device and remove the old and new dimmer driver. Then reinstalled the new driver. Installed the device and now it displays te correct driver. In live logs only this appears:
Summary
dev:2182023-04-10 13:30:26.707infoDimmer (CH01) set level 0 %
dev:2182023-04-10 13:30:26.705debugonSwitchLevel: Value=1 level=0 (value=1)
dev:2182023-04-10 13:30:26.702debugraw value:1 reScaled=0
dev:2182023-04-10 13:30:26.700tracemult=2.55, minValue255=0, maxValue255=255
dev:2182023-04-10 13:30:26.633infoDimmer (CH01) set level 1 %
dev:2182023-04-10 13:30:26.630debugonSwitchLevel: Value=2 level=1 (value=2)
dev:2182023-04-10 13:30:26.628debugraw value:2 reScaled=1
dev:2182023-04-10 13:30:26.625tracemult=2.55, minValue255=0, maxValue255=255
dev:2182023-04-10 13:30:26.388infoDimmer (CH01) set level 2 %
dev:2182023-04-10 13:30:26.385debugonSwitchLevel: Value=6 level=2 (value=6)
dev:2182023-04-10 13:30:26.383debugraw value:6 reScaled=2
dev:2182023-04-10 13:30:26.380tracemult=2.55, minValue255=0, maxValue255=255
dev:2182023-04-10 13:30:26.143infoDimmer (CH01) set level 4 %
dev:2182023-04-10 13:30:26.141debugonSwitchLevel: Value=10 level=4 (value=10)
dev:2182023-04-10 13:30:26.139debugraw value:10 reScaled=4
dev:2182023-04-10 13:30:26.136tracemult=2.55, minValue255=0, maxValue255=255
dev:2182023-04-10 13:30:25.899infoDimmer (CH01) set level 5 %
dev:2182023-04-10 13:30:25.896debugonSwitchLevel: Value=14 level=5 (value=14)
dev:2182023-04-10 13:30:25.894debugraw value:14 reScaled=5
dev:2182023-04-10 13:30:25.891tracemult=2.55, minValue255=0, maxValue255=255
dev:2182023-04-10 13:30:25.656infoDimmer (CH01) set level 7 %
dev:2182023-04-10 13:30:25.654debugonSwitchLevel: Value=18 level=7 (value=18)
dev:2182023-04-10 13:30:25.651debugraw value:18 reScaled=7
dev:2182023-04-10 13:30:25.649tracemult=2.55, minValue255=0, maxValue255=255
dev:2182023-04-10 13:30:25.411infoDimmer (CH01) set level 9 %
dev:2182023-04-10 13:30:25.409debugonSwitchLevel: Value=22 level=9 (value=22)
dev:2182023-04-10 13:30:25.407debugraw value:22 reScaled=9
dev:2182023-04-10 13:30:25.404tracemult=2.55, minValue255=0, maxValue255=255
dev:2182023-04-10 13:30:25.166infoDimmer (CH01) set level 10 %
dev:2182023-04-10 13:30:25.164debugonSwitchLevel: Value=26 level=10 (value=26)
dev:2182023-04-10 13:30:25.161debugraw value:26 reScaled=10
dev:2182023-04-10 13:30:25.159tracemult=2.55, minValue255=0, maxValue255=255
dev:2182023-04-10 13:30:24.921infoDimmer (CH01) set level 12 %
dev:2182023-04-10 13:30:24.918debugonSwitchLevel: Value=30 level=12 (value=30)
dev:2182023-04-10 13:30:24.916debugraw value:30 reScaled=12
dev:2182023-04-10 13:30:24.914tracemult=2.55, minValue255=0, maxValue255=255
dev:2182023-04-10 13:30:24.676infoDimmer (CH01) set level 13 %
dev:2182023-04-10 13:30:24.673debugonSwitchLevel: Value=34 level=13 (value=34)
dev:2182023-04-10 13:30:24.671debugraw value:34 reScaled=13
dev:2182023-04-10 13:30:24.669tracemult=2.55, minValue255=0, maxValue255=255
dev:2182023-04-10 13:30:24.432infoDimmer (CH01) set level 15 %
dev:2182023-04-10 13:30:24.429debugonSwitchLevel: Value=38 level=15 (value=38)
dev:2182023-04-10 13:30:24.427debugraw value:38 reScaled=15
dev:2182023-04-10 13:30:24.424tracemult=2.55, minValue255=0, maxValue255=255
dev:2182023-04-10 13:30:24.189infoDimmer (CH01) set level 16 %
dev:2182023-04-10 13:30:24.186debugonSwitchLevel: Value=42 level=16 (value=42)
dev:2182023-04-10 13:30:24.184debugraw value:42 reScaled=16
dev:2182023-04-10 13:30:24.181tracemult=2.55, minValue255=0, maxValue255=255
dev:2182023-04-10 13:30:23.948infoDimmer (CH01) set level 18 %
dev:2182023-04-10 13:30:23.946debugonSwitchLevel: Value=46 level=18 (value=46)
dev:2182023-04-10 13:30:23.943debugraw value:46 reScaled=18
dev:2182023-04-10 13:30:23.941tracemult=2.55, minValue255=0, maxValue255=255
dev:2182023-04-10 13:30:23.701infoDimmer (CH01) set level 20 %
dev:2182023-04-10 13:30:23.698debugonSwitchLevel: Value=50 level=20 (value=50)
dev:2182023-04-10 13:30:23.696debugraw value:50 reScaled=20
dev:2182023-04-10 13:30:23.693tracemult=2.55, minValue255=0, maxValue255=255
dev:2182023-04-10 13:30:23.461infoDimmer (CH01) set level 21 %
dev:2182023-04-10 13:30:23.458debugonSwitchLevel: Value=54 level=21 (value=54)
dev:2182023-04-10 13:30:23.456debugraw value:54 reScaled=21
dev:2182023-04-10 13:30:23.453tracemult=2.55, minValue255=0, maxValue255=255
dev:2182023-04-10 13:30:23.211infoDimmer (CH01) set level 23 %
dev:2182023-04-10 13:30:23.208debugonSwitchLevel: Value=58 level=23 (value=58)
dev:2182023-04-10 13:30:23.206debugraw value:58 reScaled=23
dev:2182023-04-10 13:30:23.203tracemult=2.55, minValue255=0, maxValue255=255
dev:2182023-04-10 13:30:22.967infoDimmer (CH01) set level 24 %
dev:2182023-04-10 13:30:22.964debugonSwitchLevel: Value=62 level=24 (value=62)
dev:2182023-04-10 13:30:22.961debugraw value:62 reScaled=24
dev:2182023-04-10 13:30:22.959tracemult=2.55, minValue255=0, maxValue255=255
dev:2182023-04-10 13:30:22.729infoDimmer (CH01) set level 26 %
dev:2182023-04-10 13:30:22.727debugonSwitchLevel: Value=66 level=26 (value=66)
dev:2182023-04-10 13:30:22.724debugraw value:66 reScaled=26
dev:2182023-04-10 13:30:22.722tracemult=2.55, minValue255=0, maxValue255=255
dev:2182023-04-10 13:30:22.479infoDimmer (CH01) set level 27 %
dev:2182023-04-10 13:30:22.476debugonSwitchLevel: Value=70 level=27 (value=70)
dev:2182023-04-10 13:30:22.474debugraw value:70 reScaled=27
dev:2182023-04-10 13:30:22.471tracemult=2.55, minValue255=0, maxValue255=255
dev:2182023-04-10 13:30:22.240infoDimmer (CH01) set level 29 %
dev:2182023-04-10 13:30:22.237debugonSwitchLevel: Value=74 level=29 (value=74)
dev:2182023-04-10 13:30:22.235debugraw value:74 reScaled=29
dev:2182023-04-10 13:30:22.232tracemult=2.55, minValue255=0, maxValue255=255
dev:2182023-04-10 13:30:21.988infoDimmer (CH01) set level 31 %
dev:2182023-04-10 13:30:21.986debugonSwitchLevel: Value=78 level=31 (value=78)
dev:2182023-04-10 13:30:21.983debugraw value:78 reScaled=31
dev:2182023-04-10 13:30:21.981tracemult=2.55, minValue255=0, maxValue255=255
dev:2182023-04-10 13:30:21.746infoDimmer (CH01) set level 32 %
dev:2182023-04-10 13:30:21.744debugonSwitchLevel: Value=82 level=32 (value=82)
dev:2182023-04-10 13:30:21.741debugraw value:82 reScaled=32
dev:2182023-04-10 13:30:21.739tracemult=2.55, minValue255=0, maxValue255=255
dev:2182023-04-10 13:30:21.502infoDimmer (CH01) set level 34 %
dev:2182023-04-10 13:30:21.499debugonSwitchLevel: Value=86 level=34 (value=86)
dev:2182023-04-10 13:30:21.497debugraw value:86 reScaled=34
dev:2182023-04-10 13:30:21.494tracemult=2.55, minValue255=0, maxValue255=255
dev:2182023-04-10 13:30:21.263infoDimmer (CH01) set level 35 %
dev:2182023-04-10 13:30:21.260debugonSwitchLevel: Value=90 level=35 (value=90)
dev:2182023-04-10 13:30:21.258debugraw value:90 reScaled=35
dev:2182023-04-10 13:30:21.255tracemult=2.55, minValue255=0, maxValue255=255
dev:2182023-04-10 13:30:21.012infoDimmer (CH01) set level 37 %
dev:2182023-04-10 13:30:21.010debugonSwitchLevel: Value=94 level=37 (value=94)
dev:2182023-04-10 13:30:21.007debugraw value:94 reScaled=37
dev:2182023-04-10 13:30:21.005tracemult=2.55, minValue255=0, maxValue255=255
dev:2182023-04-10 13:30:20.790infoDimmer (CH01) set level 38 %
dev:2182023-04-10 13:30:20.786debugonSwitchLevel: Value=98 level=38 (value=98)
dev:2182023-04-10 13:30:20.783debugraw value:98 reScaled=38
dev:2182023-04-10 13:30:20.778tracemult=2.55, minValue255=0, maxValue255=255
