Driver needed for a 6 gang Mercator Ikuu ZIgbee switch
Hi all, I bought a 6 gang switch and already paid a fortune for the electrician to run a new neutral wire and install it in my kitchen however I cannot get it to work with the generic multi end point' built-in driver although I have another 4 gang switch from a generic brand which does work, see below.
Would anyone here know of another driver please?
G’day. @hpgurgel ,
Mercator Ikuu devices are built on the Tuya platform, so it shouldn’t be hard to be supported in Hubitat.
Please follow the instructions here : How to identify a Zigbee device .
Once we know this device model/manufacturer, we can find the appropriate driver.
G'day mate, sorry about the late reply, see below:
Sorry, as I have asked in the instructions above, I really need the Zigbee manufacturer of this device as a text, the screenshot is not searchable.. :frowning: -
So sorry again for the late reply mate, I've been away for work.
I noticed that you shared the Github code with me, that's much appreciated - You're the best!!
I've remotelly installed the driver and I can now see the 6 end points, yay!! I won't be able to test it until I get home later this week though.
I also noticed that the end points came up as 'Generic Component Switch' , see below, should I leave them with that driver? Will this driver also work with my other 5 gang switch (same brand and model)?
@kkossev Thank you so much for your help with this, I finally managed to test everything and it worked as expected.
I assume the other 5 gang switch should just work with this same driver right?
For the 5 gang switch I will need again the Zigbee particular Model/Manufacturer
Please select/copy/paste the data as a text, not as a screenshot.. Thanks!
This is welcome news. Id be keen to get help with ikuu outdoor plugs and cheap light strips I just bought. I'm new to hubitat.
Most Mercator Ikuu devices should work with HE stock drivers, but you may need to manually assign the right inbuilt driver and check whether it works.
Because Mercator Ikuu is actually a rebranded Tuya, some devices may require custom drivers in HE. After you pair the device to your Hubitat hub, and if no specific driver was automatically assigned - please post the Zigbee details (see the link in the post above).
Hi there, complete newbie here.
I also purchased and installed a Mercator Ikuu 5-gang switch.
I tried to follow the steps and installed the driver for Model TS0601 but it did not identify that is was a 5-gang switch or a switch at all. I am not sure what I am doing wrong.
Manufacturere: _TZE200_leaqthtqq
Model: TS0601
Thank you for the help.
Hi Gio, which driver did you try?
Your particular device fingerprint is not here, but the driver should default to a 4-gang switch.
Pair the switch again to your hub, after you manually assign this driver.
The one for TS0601 zigbee switch which appeared as Moes 1/2/3 gang. It did not recognise the 5th child switch which was the middle switch, until I asked google Gemini to add it on.
