Devices in Hubitat Elevation C-8 Not Responding to Commands (Gledopto Zigbee LED Controller and Zigbee Power Metering Switch
You're getting there, it gets easier. :smiley:
This is a good thread to read.
You need to find the proper Drivers for your devices, unfortunately ZigBee devices are pretty bad with manufacturers putting different bits inside but using the same outside.
The best way to find the right driver is to use the information the Hubitat hub displays during the pairing process.
For example.
This TS0004 is really a TZ3000_ltt60asa:
The model information that edit: you would be used to find this device driver is ltt60asa.
Which although it doesn't show up in a search, is supported by this driver:
You can also find some of the model and cluster information on the Device Detail Page in the data section:
