Okay got it, and it's installed now. Did the wwn reset but trying to find tstat now
Well I'm not sure what's the story. I did get the application to install, but I don't see any sensors, mainly my thermostat to come up. I did do the WWN reset at the tstat, even did a complete reset of the thermostat, deleted the app, and reinstalled the app. Not sure.
Comes up under logging but that's just each time I try to run the program it's generating that I guess.
Update....And just like that now I see it avail
Hi, you'd need to reset your tstat with the WWN option.
See my previous post.
However, if you don't see any sensors, it may be that your cookie is not valid.
Make sure to follow all the steps (and the screenshots) at the wiki to extract the right cookie.
Regards
Hi,
Just want to inform my contributors and all Nest users that new version of MyNextTstat (v3.6) can be downloaded at my e-commerce solution provider (sellfy) using the original download link.
You can download the Next devices at my store:
https://ecomatiqhomes.com/hubitatstore
The new version of MyNextTstat (v3.6) corrects the supportedThermostatModes and supportedThermostatFanModes attributes in order for them to be compatible with Hubitat's dashboards.
All you need to do is to copy &paste the new code over the existing device's code under the IDE and save
Since V3 of MyNextDevices, the UI presentation adds the following commands for controlling your HVAC:
- setTargetHumidity: to control your humidity inside your home via your dehumidifier/humidifier connected to Nest
- setHotWaterBoost: to set a boiler's hotWaterBoost timer in minutes (Europe)
- Nest Home or Away: to set your Nest structure to Home or Away.
- setThermostatFanSchedule: to create fan schedules at your tstat
- setThermostatFanTimer: to set the fan timer in minutes
- setDualFuelBreakpointTemp: if you have dualFuel/alt/emergency heating, you can set the breakpoint temperature for switching to dualFuel/alt/emergency heating
- setDualFuelBreakpointMode: You can set the following mode for alt/emergency/dual heating: "DUALFUEL_BREAKPOINT_ALWAYS_ALT" or "DUALFUEL_BREAKPOINT_ALWAYS_PRIMARY". This command allows finer control of your dualFuel/alt/emergency heating.
MyNextTstat (p1)
MyNextTstat (p2)
MyNextAlarm For Protects
MyNextSensor with new capabilities (switch on/off to make it active/inactive)
On top of it, there are many complimentary smartapps designed for My NextTstat DTH and are located at my github.
You can also refer to the 1st post of this thread for all the use cases supported.
MyNextManagerV3.6, MyNextTstatV3.6, MyNextAlarmV3 (For Protects), MyNextSensor V3 are available at my store:
Thnx, it's been corrected.
The thermostat's function no longer works at all. It will always show 0 thermostats. However, protects and other sensors show no problem. Connection logs show it finds a thermostat, but it never puts the ID into the array. This is a coding problem.
Hi, it does work as many Nest users including myself have been running several instances of MyNextManager at home with a C7 hub for the last 3 years.
Please refer to my previous post
However, if your tstat comes from a partner such as a utility, it won't work. And, it only works with the Nest branded tstats.
Regards
This is a Nest Learning Thermostat directly from Google. I have tried to remove from Google Home and re-add. It still shows 0. With verbose logging enabled it shows the thermostat, but the code is not adding the thermostat's ID to the array. This appears to be a coding problem from what I have seen. Maybe Google changed something on their end?
Log shows the thermostat was found, but is never added to the array and it always says 0 thermostats are found. Other people here have the same problem.
This is the one I have: https://store.google.com/us/product/nest_learning_thermostat_3rd_gen?hl=en-US
Hi, it needs to be a Nest branded tstat, not a Google one.
You need to be able to reset it with the WWN option at the unit. Also, you'd need to add it to the Nest app.
Send me your detailed logs to services@maisonsecomatiq.com and I will look into it.
Regards
It is in the Nest app. What is the difference between Nest and Google? Google owns Nest and has firmware updated all devices to have the Google branding, even the original older ones that used to say Nest on them now say Google on their boot-loader.
The thermostat shows up in the Nest app. Also in the logs I see it says "thermostats:1" so it appears it is finding it.
Hi,
The recent tstats are no longer branded as Nest thermostats but are now Google branded tstats, and are accessible from the Google home app, not the Nest app.
Moreover, like I replied to you in my last post, just send me your logs to where you're trying to add your tstat to services@maisonsecomatiq.com, and I will see what I can do.
I cannot help you without the detailed logs.
Regards
Oh ok I wasn't aware of that.
My Thermostat is showing in Nest app and Google Home app. Both show it.
I can send you detailed logs, anything specific you're looking for?
cookiep1 start with '1P_JAR=2022-11-28-06;'
now. Do I need to include this?
Like I said, all other devices are syncing and communicating properly, only the thermostat isn't showing up.
All I need for the moment is your detailed logs when you're trying to add the tstat.
Regards
The info is very specific and gives away quite a bit of data. What log level do you need minimum?
Like I wrote earlier, I'd like to have the detailed logs (level=5), just when you're trying to add the tstat.
You can send me the excerpts, no need to send anything unrelated to your tstat.
Hi, I haven't received any logs from you. Still waiting.
Hello,
I will send logs as soon as possible.
I have to redact a lot of personal information before I can send them.
It's very weird as it says 'thermostats:1' but then shows 'thermostats:[]' (nothing in the array)
I see nothing else of value in all of these logs, no errors show up. No information about the thermostat other than what I stated above. I'm not sure what you'd be looking for in any of these logs. Nothing useful.
All other devices show up. It's very weird that the Thermostat doesn't. Do I need a Google SDM Dev account to make the thermostat work? I see you have calls to the SDM OAUTH in your code.
Send me what you have, and I will judge if anything else is required.
The thermostat has to be present in the Nest structure, if it's not linked, then my code won't be able to expose it obviously.
My code is not flawed as it's been tested over and over again: it all depends if your tstat is exposed in the Nest structure.
That's why the only workaround is to reset your tstat with the WWN option at the unit and add it to the Nest app again before trying to expose with MyNextManager.
You don't need to redact a lot of information, just global replace the tstat Id by X, then I will be able to determine if I can find your tstat or not in the Nest structure.
Waiting for your logs..
getObject>key= REDACTED, object=[away:false, city:REDACTED, manual_eco_all:false, latitude:REDACTED, demand_charge_enabled:true, vacation_mode:false, type:structure, num_thermostats:1, address_lines:[REDACTED], eta:null, eta_preconditioning_active:false, manual_away_timestamp:REDACTED, geofence_enhanced_autoaway:[enabled:true, is_set:true], id:REDACTED, longitude:REDACTED, eta_unique_id:null, devices:[], away_timestamp:REDACTED, away_setter:0, manual_eco_timestamp:null, time_zone:REDACTED, country_code:REDACTED, topaz_away:false, swarm:[REDACTED, topaz.REDACTED, topaz.REDACTED, kryptonite.REDACTED, topaz.REDACTED, topaz.REDACTED, kryptonite.REDACTED], name:REDACTED, location:REDACTED, postal_code:REDACTED, user:REDACTED]
getStructures>end.. objectType=Thermostats, List=[]
getStructures>id = REDACTED, objectType=structure, thermostats linked to IDUSUALLYHERE.REDACTED = []
num_thermostats:1, entitlements:[:],
getStructures> num_thermostats: 1
It sees the thermostat, links it to an ID, but then never adds it to the array. This is a coding issue, and it's not on Google's end. Communication is not the problem because all other devices show up. (Protects + Sensors)
