💡 Configuring EZ Dashboard for Mobile use with separate areas
EZ dashboard for Mobile devices does not allow the use of the navigation button to access other screens such as lighting, sensors or other any other screen you have created for your mobile device like you can locally.
Link to thread that started this adventure - Updated to .141 and have mobile screen working via cloud however - - #5 by dpdurst
What I've done is separated each area using a virtual image tile and a label so that as I scroll down I have a main area for presence, doors, locks, mode and HSM status tile, then a tile that is a virtual tile with an image and label for all my lights and finally another virtual time with an image and label for all my sensors in the house such as water, smoke/co2 and repeaters. This gives a clean way to separate all area's and kind of a way to jump to a specific section if you want to check on something.
To configure this create a new virtual dashboard as an image device, give it a name and select the create button
1
2
Once you have done that go to your devices and find your newly created virtual image device and open it up and you will configure the commands area in red as shown below
I grabbed a few images off the internet that had a valid URL that I could paste in the web browser and make sure they opened up the image I wanted and then pasted that URL into the string line of the Set Image Url area and pressed the setimageurl button to save it. I then set the refresh rate to 0 as well and pressed that button to save the setting and the settings should show up on the right side of the screen configured, then you want to press the save preferences button at the bottom in red
Now you can configure your mobile ez dashboard and using the above method and can have separate area's easy to find without having just one giant area with everything mixed in.
Below is what you can do with a little creativity (click image for full screen)
Very cleaver and great idea!
This is similar to the functionality I was asking for when requesting a text label to separate functional groups of devices. I still hope the developers will consider the text box approach but very much like this approach as well. I may use this as an interim approach for several key groups.
Thank you!
  • Don
This is currently in development :wink:
Awh man. This is great. Thank you :grinning::+1::+1:
I've been wanting to be able to create nestable room for the EZ dashboard like we have for the classic dashboard mostly because right now I can't choose to show just the EZ dashboards and when they had the navigation button inside a dashboard/room on phones it didn't scroll, and now it is simply gone.
So I was hoping there was a way I could create a virtual button device and when that button was pushed it would go to a URL, which I would copy by actually going to an EZ dashboard room and then pasting it into a button pushed action (like how you pasted in a URL for an image). Is there anyway to use a virtual device directly, or with a rule, that when pushed it would go to a URL (which would then have the same effect as nesting a dashboard/room)?
...and is live:
Was out of town and couldn't wait to get back and implement it. Was so easy to implement and worked perfectly!
Thank you again.
Don
I just spent an hour making a dashboard like this but when I look at it in my phone it puts every tile in one long column, and they are no longer grouped! What am I missing?
Each device maintains it's own layout. So lets say you have your pc desktop laid out in one fashion, while the buttons may be on your phone they're independent of the desktop layout. So when you arrange your layout on your phone that will stay while your desktop won't change. (Does that make sense?). Then if you add a tablet, that will also have an independent layout.
It does make sense, unfortunate but I get it :slight_smile: Thanks
I think it's better than the old system. That way one thing doesn't affect the other and you don't lose layouts or have to worry about 1 layout working for all devices. This was always problematic the old way (at least for me) because it makes you compromise more. That said, I don't really use dashboards. I do automation. I have a couple of dash's for testing during beta, and one for locks just in case. That's about it. For me I don't want remote control.
At work where I am a software developer, responsive means we design it once and it adjusts to the different screen sizes automatically. But this is good, I agree.
