FYI, for those that are interested, I just discovered that the Leviton z-wave dimmers allow this function.
Through the use of a custom driver, you can change the parameter on the dimmer that sets the "preset level" which is what the dimmer comes on to when the top paddle is pushed. Here's the custom driver for them that exposes this capability through commands.
For those looking to change the level when the device is physically turned on, this should definitely be considered.
* Copyright 2017 Jason Xia
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
metadata {
definition (name: "Leviton Decora Z-Wave Plus Dimmer", namespace: "jasonxh", author: "Jason Xia", ocfDeviceType: "oic.d.light") {
capability "Actuator"
capability "Configuration"
//capability "Health Check"
capability "Indicator"
capability "Light"
capability "Polling"
capability "Refresh"
capability "Sensor"
capability "Switch"
capability "Switch Level"
attribute "loadType", "enum", ["incandescent", "led", "cfl"]
attribute "presetLevel", "number"
attribute "minLevel", "number"
attribute "maxLevel", "number"
attribute "fadeOnTime", "number"
attribute "fadeOffTime", "number"
attribute "levelIndicatorTimeout", "number"
command "low"
command "medium"
command "high"
command "levelUp"
command "levelDown"
fingerprint mfr:"001D", prod:"3201", model:"0001", deviceJoinName: "Leviton Decora Z-Wave Plus 600W Dimmer"
fingerprint mfr:"001D", prod:"3301", model:"0001", deviceJoinName: "Leviton Decora Z-Wave Plus 1000W Dimmer"
preferences {
input name: "levelIncrement", type: "number", title: "In-App Level Increment",
description: "1 - 100 (default $defaultLevelIncrement)", range: "1..100", defaultValue: defaultLevelIncrement,
displayDuringSetup: false, required: false
input type: "paragraph", element: "paragraph", title: "Device Preferences",
description: "The following preferences are configuring the device behaviors. " +
"All of them are optional. Leave a preference empty to skip configuring it."
input name: "loadType", type: "enum", title: "Load type",
options: ["Incandescent (default)", "LED", "CFL"],
input name: "indicatorStatus", type: "enum", title: "Indicator LED is lit",
options: ["When switch is off (default)", "When switch is on", "Never"],
input name: "presetLevel", type: "number", title: "Light turns on to level",
description: "0 = last dim level (default)\n1 - 100 = fixed level", range: "0..100",
input name: "minLevel", type: "number", title: "Minimum light level",
description: "0 to 100 (default 10)", range: "0..100",
input name: "maxLevel", type: "number", title: "Maximum light level",
description: "0 to 100 (default 100)", range: "0..100",
input name: "fadeOnTime", type: "number", title: "Fade-on time",
description: "0 = instant on\n1 - 127 = 1 - 127 seconds (default 2)\n128 - 253 = 1 - 126 minutes", range: "0..253",
input name: "fadeOffTime", type: "number", title: "Fade-off time",
description: "0 = instant off\n1 - 127 = 1 - 127 seconds (default 2)\n128 - 253 = 1 - 126 minutes", range: "0..253",
input name: "levelIndicatorTimeout", type: "number", title: "Dim level indicator timeout",
description: "0 = dim level indicator off\n1 - 254 = timeout in seconds (default 3)\n255 = dim level indicator always on", range: "0..255",
def installed() {
log.debug "installed..."
initialize()
response(refresh())
def updated() {
if (state.lastUpdatedAt != null && state.lastUpdatedAt >= now() - 1000) {
log.debug "ignoring double updated"
return
log.debug "updated..."
state.lastUpdatedAt = now()
initialize()
response(configure())
def configure() {
def commands = []
if (loadType != null) {
commands.addAll(setLoadType(loadType))
if (indicatorStatus != null) {
commands.addAll(setIndicatorStatus(indicatorStatus))
if (presetLevel != null) {
commands.addAll(setPresetLevel(presetLevel as short))
if (minLevel != null) {
commands.addAll(setMinLevel(minLevel as short))
if (maxLevel != null) {
commands.addAll(setMaxLevel(maxLevel as short))
if (fadeOnTime != null) {
commands.addAll(setFadeOnTime(fadeOnTime as short))
if (fadeOffTime != null) {
commands.addAll(setFadeOffTime(fadeOffTime as short))
if (levelIndicatorTimeout != null) {
commands.addAll(setLevelIndicatorTimeout(levelIndicatorTimeout as short))
log.debug "Configuring with commands $commands"
commands
def result = null
def cmd = zwave.parse(description, [0x20: 1, 0x25:1, 0x26: 1, 0x70: 1, 0x72: 2])
if (cmd) {
result = zwaveEvent(cmd)
log.debug "Parsed $cmd to $result"
} else {
log.debug "Non-parsed event: $description"
result
def on() {
def fadeOnTime = device.currentValue("fadeOnTime")
def presetLevel = device.currentValue("presetLevel")
short duration = fadeOnTime == null ? 255 : fadeOnTime
short level = presetLevel == null || presetLevel == 0 ? 0xFF : toZwaveLevel(presetLevel as short)
delayBetween([
zwave.switchMultilevelV2.switchMultilevelSet(value: level, dimmingDuration: duration).format(),
zwave.switchMultilevelV1.switchMultilevelGet().format()
], durationToSeconds(duration) * 1000 + commandDelayMs)
def off() {
def fadeOffTime = device.currentValue("fadeOffTime")
short duration = fadeOffTime == null ? 255 : fadeOffTime
delayBetween([
zwave.switchMultilevelV2.switchMultilevelSet(value: 0x00, dimmingDuration: duration).format(),
def setLevel(value, durationSeconds = null) {
log.debug "setLevel >> value: $value, durationSeconds: $durationSeconds"
short level = toDisplayLevel(value as short)
short dimmingDuration = durationSeconds == null ? 255 : secondsToDuration(durationSeconds as int)
sendEvent(name: "level", value: level, unit: "%")
sendEvent(name: "switch", value: level > 0 ? "on" : "off")
delayBetween([
zwave.switchMultilevelV2.switchMultilevelSet(value: toZwaveLevel(level), dimmingDuration: dimmingDuration).format(),
], durationToSeconds(dimmingDuration) * 1000 + commandDelayMs)
def poll() {
delayBetween(statusCommands, commandDelayMs)
def ping() {
poll()
def refresh() {
def commands = statusCommands
if (getDataValue("MSR") == null) {
commands << zwave.manufacturerSpecificV1.manufacturerSpecificGet().format()
for (i in 1..8) {
commands << zwave.configurationV1.configurationGet(parameterNumber: i).format()
log.debug "Refreshing with commands $commands"
delayBetween(commands, commandDelayMs)
def indicatorNever() {
sendEvent(name: "indicatorStatus", value: "never")
configurationCommand(7, 0)
def indicatorWhenOff() {
sendEvent(name: "indicatorStatus", value: "when off")
configurationCommand(7, 255)
def indicatorWhenOn() {
sendEvent(name: "indicatorStatus", value: "when on")
configurationCommand(7, 254)
def low() {
setLevel(10)
def medium() {
setLevel(50)
def high() {
setLevel(100)
def levelUp() {
setLevel(device.currentValue("level") + (levelIncrement ?: defaultLevelIncrement))
def levelDown() {
setLevel(device.currentValue("level") - (levelIncrement ?: defaultLevelIncrement))
private static int getCommandDelayMs() { 1000 }
private static int getDefaultLevelIncrement() { 10 }
private initialize() {
// Device-Watch simply pings if no device events received for 32min(checkInterval)
//sendEvent(name: "checkInterval", value: 2 * 15 * 60 + 2 * 60, displayed: false, data: [protocol: "zwave", hubHardwareId: device.hub.hardwareID])
private zwaveEvent(hubitat.zwave.commands.basicv1.BasicReport cmd) {
dimmerEvent(cmd.value)
private zwaveEvent(hubitat.zwave.commands.switchmultilevelv1.SwitchMultilevelReport cmd) {
private zwaveEvent(hubitat.zwave.commands.switchmultilevelv1.SwitchMultilevelStopLevelChange cmd) {
response(zwave.switchMultilevelV1.switchMultilevelGet().format())
private zwaveEvent(hubitat.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd) {
if (cmd.value == 0) {
switchEvent(false)
} else if (cmd.value == 255) {
switchEvent(true)
} else {
log.debug "Bad switch value $cmd.value"
private zwaveEvent(hubitat.zwave.commands.configurationv1.ConfigurationReport cmd) {
def result = null
switch (cmd.parameterNumber) {
case 1:
result = createEvent(name: "fadeOnTime", value: cmd.configurationValue[0])
break
case 2:
result = createEvent(name: "fadeOffTime", value: cmd.configurationValue[0])
break
case 3:
result = createEvent(name: "minLevel", value: cmd.configurationValue[0])
break
case 4:
result = createEvent(name: "maxLevel", value: cmd.configurationValue[0])
break
case 5:
result = createEvent(name: "presetLevel", value: cmd.configurationValue[0])
break
case 6:
result = createEvent(name: "levelIndicatorTimeout", value: cmd.configurationValue[0])
break
case 7:
def value = null
switch (cmd.configurationValue[0]) {
case 0: value = "never"; break
case 254: value = "when on"; break
case 255: value = "when off"; break
result = createEvent(name: "indicatorStatus", value: value)
break
case 8:
def value = null
case 0: value = "incandescent"; break
case 1: value = "led"; break
case 2: value = "cfl"; break
result = createEvent(name: "loadType", value: value)
break
result
private zwaveEvent(hubitat.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
log.debug "manufacturerId: $cmd.manufacturerId"
log.debug "manufacturerName: $cmd.manufacturerName"
log.debug "productId: $cmd.productId"
log.debug "productTypeId: $cmd.productTypeId"
def msr = String.format("%04X-%04X-%04X", cmd.manufacturerId, cmd.productTypeId, cmd.productId)
updateDataValue("MSR", msr)
updateDataValue("manufacturer", cmd.manufacturerName)
createEvent([descriptionText: "$device.displayName MSR: $msr", isStateChange: false])
private zwaveEvent(hubitat.zwave.commands.hailv1.Hail cmd) {
createEvent(name: "hail", value: "hail", descriptionText: "Switch button was pressed", displayed: false)
private zwaveEvent(hubitat.zwave.Command cmd) {
log.warn "Unhandled zwave command $cmd"
private dimmerEvent(short level) {
def result = null
if (level == 0) {
result = [createEvent(name: "level", value: 0, unit: "%"), switchEvent(false)]
} else if (level >= 1 && level <= 100) {
result = createEvent(name: "level", value: toDisplayLevel(level), unit: "%")
if (device.currentValue("switch") != "on") {
// Don't blindly trust level. Explicitly request on/off status.
result = [result, response(zwave.switchBinaryV1.switchBinaryGet().format())]
} else {
log.debug "Bad dimming level $level"
result
private switchEvent(boolean on) {
createEvent(name: "switch", value: on ? "on" : "off")
private getStatusCommands() {
// Even though SwitchBinary is not advertised by this device, it seems to be the only way to assess its true
// on/off status.
zwave.switchBinaryV1.switchBinaryGet().format(),
private short toDisplayLevel(short level) {
level = Math.max(0, Math.min(100, level))
(level == (short) 99) ? 100 : level
private short toZwaveLevel(short level) {
Math.max(0, Math.min(99, level))
private int durationToSeconds(short duration) {
if (duration >= 0 && duration <= 127) {
duration
} else if (duration >= 128 && duration <= 254) {
(duration - 127) * 60
} else if (duration == 255) {
2 // factory default
} else {
log.error "Bad duration $duration"
0
private short secondsToDuration(int seconds) {
if (seconds >= 0 && seconds <= 127) {
seconds
} else if (seconds >= 128 && seconds <= 127 * 60) {
127 + Math.round(seconds / 60)
} else {
log.error "Bad seconds $seconds"
255
private configurationCommand(param, value) {
param = param as short
value = value as short
delayBetween([
zwave.configurationV1.configurationSet(parameterNumber: param, configurationValue: [value]).format(),
zwave.configurationV1.configurationGet(parameterNumber: param).format()
], commandDelayMs)
private setFadeOnTime(short time) {
sendEvent(name: "fadeOnTime", value: time)
configurationCommand(1, time)
private setFadeOffTime(short time) {
sendEvent(name: "fadeOffTime", value: time)
configurationCommand(2, time)
private setMinLevel(short level) {
sendEvent(name: "minLevel", value: level)
configurationCommand(3, level)
private setMaxLevel(short level) {
sendEvent(name: "maxLevel", value: level)
configurationCommand(4, level)
private setPresetLevel(short level) {
sendEvent(name: "presetLevel", value: level)
configurationCommand(5, level)
private setLevelIndicatorTimeout(short timeout) {
sendEvent(name: "levelIndicatorTimeout", value: timeout)
configurationCommand(6, timeout)
private setLoadType(String loadType) {
switch (loadType) {
case "Incandescent (default)":
sendEvent(name: "loadType", value: "incandescent")
return configurationCommand(8, 0)
case "LED":
sendEvent(name: "loadType", value: "led")
return configurationCommand(8, 1)
case "CFL":
sendEvent(name: "loadType", value: "cfl")
return configurationCommand(8, 2)
private setIndicatorStatus(String status) {
switch (indicatorStatus) {
case "When switch is off (default)": return indicatorWhenOff()
case "When switch is on": return indicatorWhenOn()
case "Never": return indicatorNever()
