Cant remove zwave node
I have a pair of zwave nodes that are unknown devices, cant be discovered when i click discover and when i hit refresh they just sit in pending forever until i reboot. If i click remove, nothing happens.
These are the logs i have when i hit remove:
2022-07-08 05:39:12.530 pm Failed node 2E remove status: no reply
2022-07-08 05:39:02.535 pm Z-Wave Network responded with Busy message.
2022-07-08 05:39:02.528 pm Failed node 2E remove status: no reply
Any idea how to get rid of these?! They seem to be causing issues in my network.
If it is still communicating, it might prevent removal. They are probably a device that paired immediately after this. I would see if the 1-2 devices after this have a similar Device Class as this ghost node.
In other words, if this 2E node is a SPECIFIC_TYPE_POWER_SWITCH_MULTILEVEL then find the next instance of that same thing.
Remove power from that next device in the column, and try to remove the ghost again.
They are ghosts. These are caused by failed pairings. As @neonturbo says, look at the device after it. Likely that device is what caused the ghost and it must be completely disconnected from power to remove the ghost.
Make sure your z-wave stack is updated (on the z-wave details page there will be an update z-wave firmware button. If it's not there you've already done it)
Remove power from device.
Shut down hub from settings menu then unplug the hub (at wall not hub) for 5 mins and power back up.
Go back to your z-wave details page. If the remove button is not there, click refresh on that line till it's there then click remove. Only click once. It will disappear or prompt for a force remove.
Rinse and repeat for each ghost.
??... it must be completely disconnected from power to remove the ghost.??
So, if the next unit is a wall switch/dimmer, that wall switch/dimmer must be disconnected from power? Is there no other way? What if the suspect wall switch is excluded and them re-included, would that work?
Should not matter if the device was reset or paired with a different node ID, but that is the current wisdom. Really it is just people taking random guesses at what could be going on since the zwave node removal process is apparently broken.
If removal is still not working, IMO the only explanation is that the zwave node removal is broken garbage, which we have been told is the fault of the SDK and out of control of the Hubitat team.
Thanks for your answers
??... the fault of the SDK and out of control of the Hubitat team...? Is the removal tool not an element of the Hubitat system?
Hubitat presents to us in a UI but its operation is coordinate by the z-wave chip which has its own firmware / SDK provided by Silicon Labs. Basically the hub asks the chip to remove the node, and the chip responds back with a code, either success or failure.
Thanks for your explanation, and attempts to help. Much to ponder. As for removing the power from the switch/dimmer, as suggested, probably the easiest way is to deal with the circuit at the breaker/fuse panel.
A question. What if I created a backup, then factory reset the C-8, then reloaded the backup,...would the ghosts still be there?
Only if you use a cloud backup with hub protect. Local backups do not back up the radios. That said, the backups backup the corrupt radio database and restore as such. Your best bet is to get a usb z-wave stick (amazon, probably a zooz) and pair it as a secondary controller and use the silabs software to remove the ghost(s)
@bcopeland has said before that if the physical device is pingable (as in joined under another software node id) the ghost will have problems removing it. I assume because the physical device has a constant identifier (serial number) that is used in the removal process.
Thanks for that. I have an Aeotec ZW095-A that I haven't used for years. I'll give that a shot. This may not be the place to mention this, but I am experiencing significant delay between command and action (i.e. using the HE interface, the time between pressing ON or Off, and having the associated device responding can be many seconds to minutes.) I thought my transition from Vera to HE would be smother. Also, I had a C-7 with a few devices and didn't seem to have any significant issues. I bought the C-8 when I decided to move all (currently 91) to it. Thanks for listening. 73
Can you post your z-wave details page in it's entirety?
Z-Wave Radio Devices
Node Stats Status Device Class Device Security Route
0x0B (011) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 52, Route Changes: 0 OK SPECIFIC_TYPE_NOTIFICATION_SENSOR
Fibargroup Kitchen ZW5 S0 01 -> 18 -> 0B 9.6kbps
0x0D (013) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 45, Route Changes: 0 OK SPECIFIC_TYPE_NOTIFICATION_SENSOR
Fibargroup Foyer ZW5 S0 01 -> 25 -> 0D 100kbps
0x0E (014) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 50, Route Changes: 0 OK SPECIFIC_TYPE_ROUTING_SENSOR_BINARY
Ecolink MD Office Desk left None 01 -> 0E 40kbps
0x14 (020) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 1, Route Changes: 0 PENDING SPECIFIC_TYPE_SIMPLE_METER None
0x18 (024) PER: 0, RTT Avg: ms, LWR RSSI: 15dB
Neighbors: 37, Route Changes: 0 OK SPECIFIC_TYPE_POWER_SWITCH_MULTILEVEL
HomeSeer Technologies RearBR Dimmer None 01 -> 18 100kbps
0x1A (026) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 1, Route Changes: 0 PENDING SPECIFIC_TYPE_POWER_SWITCH_MULTILEVEL
Jasco Products Generic Z-Wave Dimmer None
0x1B (027) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 1, Route Changes: 0 PENDING SPECIFIC_TYPE_POWER_SWITCH_BINARY
Jasco Products Spare wall switch None
0x1C (028) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 1, Route Changes: 0 PENDING SPECIFIC_TYPE_POWER_SWITCH_MULTILEVEL None 01 -> 42 -> 5F -> 2A -> 1C 40kbps
0x21 (033) PER: 23, RTT Avg: 15191ms, LWR RSSI:
Neighbors: 48, Route Changes: 1 PENDING SPECIFIC_TYPE_POWER_SWITCH_BINARY None 01 -> 18 -> 21 100kbps
0x23 (035) PER: 0, RTT Avg: ms, LWR RSSI: 12dB
Neighbors: 36, Route Changes: 0 OK SPECIFIC_TYPE_POWER_SWITCH_BINARY
Leviton Tool Room Light None 01 -> 23 100kbps
0x25 (037) PER: 0, RTT Avg: ms, LWR RSSI: 34dB
Neighbors: 54, Route Changes: 0 OK SPECIFIC_TYPE_POWER_SWITCH_BINARY
Jasco Products Garage light None 01 -> 39 -> 46 -> 25 40kbps
0x26 (038) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 57, Route Changes: 0 OK SPECIFIC_TYPE_NOTIFICATION_SENSOR
Zooz RearBR Z4 None 01 -> 26 40kbps
0x27 (039) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 1, Route Changes: 0 NOT_RESPONDING GENERIC_TYPE_SWITCH_BINARY
Zooz ZEN32 None
0x28 (040) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 2, Route Changes: 0 PENDING SPECIFIC_TYPE_POWER_SWITCH_BINARY
Leviton Santa Sings None
0x29 (041) PER: 0, RTT Avg: 1ms, LWR RSSI: 33dB
Neighbors: 27, Route Changes: 1 OK SPECIFIC_TYPE_POWER_SWITCH_BINARY
Leviton HT heater None 01 -> 29 100kbps
0x2A (042) PER: 0, RTT Avg: ms, LWR RSSI: 25dB
Neighbors: 60, Route Changes: 0 OK SPECIFIC_TYPE_POWER_SWITCH_BINARY
Jasco Products RearBR Closet None 01 -> 2A 100kbps
0x2B (043) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 77, Route Changes: 0 OK SPECIFIC_TYPE_SCENE_SWITCH_MULTILEVEL
Evolve Evolve LDM-15W dimmer None 01 -> 7D -> 25 -> 7A -> 2B 40kbps
0x2C (044) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 52, Route Changes: 0 OK SPECIFIC_TYPE_POWER_SWITCH_MULTILEVEL
Leviton Spare DZPD3 dimmer 1 None 01 -> 2C 100kbps
0x2D (045) PER: 0, RTT Avg: ms, LWR RSSI: 15dB
Neighbors: 29, Route Changes: 0 OK SPECIFIC_TYPE_POWER_SWITCH_BINARY
Leviton Office Desklamp Left None 01 -> 2D 100kbps
0x2E (046) PER: 0, RTT Avg: ms, LWR RSSI: 27dB
Neighbors: 32, Route Changes: 0 OK SPECIFIC_TYPE_POWER_SWITCH_MULTILEVEL
Leviton ODR None 01 -> 2C -> 2E 9.6kbps
0x2F (047) PER: 0, RTT Avg: ms, LWR RSSI:
Leviton Generic Z-Wave Outlet None
0x30 (048) PER: 0, RTT Avg: ms, LWR RSSI: 12dB
Neighbors: 41, Route Changes: 0 OK SPECIFIC_TYPE_POWER_SWITCH_BINARY
Leviton Office Fan None 01 -> 30 100kbps
0x31 (049) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 49, Route Changes: 0 OK SPECIFIC_TYPE_POWER_SWITCH_BINARY
Leviton Office Work Table None 01 -> 31 100kbps
0x32 (050) PER: 0, RTT Avg: ms, LWR RSSI:
Leviton Office Radio PS None 01 -> 2B -> 32 9.6kbps
0x33 (051) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 1, Route Changes: 0 PENDING SPECIFIC_TYPE_POWER_SWITCH_BINARY None
0x34 (052) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 40, Route Changes: 0 OK SPECIFIC_TYPE_POWER_SWITCH_BINARY
Leviton Office RPi None 01 -> 34 100kbps
0x35 (053) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 60, Route Changes: 0 OK GENERIC_TYPE_SWITCH_BINARY
Aeotec Limited LRTV SS7 None 01 -> 35 100kbps
0x36 (054) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 55, Route Changes: 0 OK GENERIC_TYPE_SWITCH_BINARY
Aeotec Limited SS7 A None 01 -> 36 100kbps
0x37 (055) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 43, Route Changes: 0 NOT_RESPONDING SPECIFIC_TYPE_POWER_SWITCH_BINARY
Leviton Office RR Power None 01 -> 37 100kbps
0x38 (056) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 78, Route Changes: 0 NOT_RESPONDING SPECIFIC_TYPE_SCENE_SWITCH_MULTILEVEL
Leviton Spare DZPD3 dimmer 2 None 01 -> 38 40kbps
0x39 (057) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 47, Route Changes: 0 NOT_RESPONDING SPECIFIC_TYPE_POWER_SWITCH_BINARY
Leviton Spare DZPA1 switch 1 None 01 -> 39 100kbps
0x3A (058) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 45, Route Changes: 0 OK SPECIFIC_TYPE_POWER_SWITCH_BINARY
Leviton Grow lamp None 01 -> 3A 100kbps
0x3C (060) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 69, Route Changes: 0 NOT_RESPONDING SPECIFIC_TYPE_POWER_SWITCH_BINARY
Jasco Products Spare ZW4201 outdoor plug None 01 -> 3C 40kbps
0x3D (061) PER: 0, RTT Avg: 4ms, LWR RSSI: 36dB
Neighbors: 50, Route Changes: 1 OK SPECIFIC_TYPE_SCENE_SWITCH_BINARY
Evolve HTBRL None 01 -> 70 -> 3D 40kbps
0x3E (062) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 16, Route Changes: 0 NOT_RESPONDING SPECIFIC_TYPE_POWER_SWITCH_MULTILEVEL
Leviton HTTL None 01 -> 3E 100kbps
0x3F (063) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 33, Route Changes: 0 PENDING SPECIFIC_TYPE_BASIC_WALL_CONTROLLER
AEON Labs WallMote Quad None
0x40 (064) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 18, Route Changes: 0 OK SPECIFIC_TYPE_POWER_SWITCH_BINARY
AEON Labs Spare SS6 ZW096 None 01 -> 32 -> 40 100kbps
0x41 (065) PER: 0, RTT Avg: ms, LWR RSSI: 42dB
Leviton LRTL South None 01 -> 18 -> 41 100kbps
0x42 (066) PER: 0, RTT Avg: ms, LWR RSSI: 25dB
Neighbors: 78, Route Changes: 0 OK SPECIFIC_TYPE_SCENE_SWITCH_MULTILEVEL
Leviton LRPSL None 01 -> 42 40kbps
0x43 (067) PER: 0, RTT Avg: ms, LWR RSSI: 19dB
Leviton LRTL Window None 01 -> 43 40kbps
0x44 (068) PER: 0, RTT Avg: ms, LWR RSSI: 25dB
Neighbors: 70, Route Changes: 0 OK SPECIFIC_TYPE_SCENE_SWITCH_MULTILEVEL
Leviton DRCL None 01 -> 44 40kbps
0x45 (069) PER: 0, RTT Avg: ms, LWR RSSI: 18dB
Neighbors: 68, Route Changes: 0 OK SPECIFIC_TYPE_SCENE_SWITCH_MULTILEVEL
Leviton FTLN None 01 -> 45 40kbps
0x46 (070) PER: 0, RTT Avg: ms, LWR RSSI: 20dB
Leviton FTLS None 01 -> 57 -> 46 40kbps
0x47 (071) PER: 0, RTT Avg: ms, LWR RSSI: 28dB
Neighbors: 48, Route Changes: 0 OK SPECIFIC_TYPE_POWER_SWITCH_BINARY
Leviton Humidifier (RB) None 01 -> 47 100kbps
0x48 (072) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 55, Route Changes: 0 OK SPECIFIC_TYPE_POWER_SWITCH_MULTILEVEL
Leviton Spare dimmer x None 01 -> 48 100kbps
0x49 (073) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 67, Route Changes: 0 OK SPECIFIC_TYPE_SCENE_SWITCH_BINARY
Leviton DHWRCPowerZ None 01 -> 49 40kbps
0x4A (074) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 26, Route Changes: 0 OK SPECIFIC_TYPE_POWER_SWITCH_BINARY
AEON Labs Spare 2 SS6 ZW096 None 01 -> 30 -> 4A 100kbps
0x4B (075) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 48, Route Changes: 0 OK SPECIFIC_TYPE_POWER_SWITCH_MULTILEVEL
Jasco Products Office Main None 01 -> 4B 100kbps
0x4C (076) PER: 0, RTT Avg: ms, LWR RSSI: 14dB
Jasco Products Furnace Room None 01 -> 4C 100kbps
0x4D (077) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 28, Route Changes: 0 PENDING SPECIFIC_TYPE_POWER_SWITCH_MULTILEVEL None 01 -> 3E -> 37 -> 38 -> 7D -> 4D 40kbps
0x4E (078) PER: 0, RTT Avg: ms, LWR RSSI: 36dB
Neighbors: 49, Route Changes: 0 OK SPECIFIC_TYPE_SCENE_SWITCH_BINARY
Evolve LL WC None 01 -> 70 -> 4E 40kbps
0x4F (079) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 53, Route Changes: 0 NOT_RESPONDING SPECIFIC_TYPE_NOTIFICATION_SENSOR
Ecolink MD Tool Room None 01 -> 4F 100kbps
0x50 (080) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 49, Route Changes: 0 OK SPECIFIC_TYPE_NOTIFICATION_SENSOR
Ecolink MD LibHall None 01 -> 50 100kbps
0x51 (081) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 53, Route Changes: 0 OK SPECIFIC_TYPE_ROUTING_SENSOR_MULTILEVEL
AEON Labs MD Office (MS6) None 01 -> 51 100kbps
0x52 (082) PER: 0, RTT Avg: 1ms, LWR RSSI: 23dB
Neighbors: 71, Route Changes: 1 OK SPECIFIC_TYPE_POWER_SWITCH_BINARY
Jasco Products Stairs None 01 -> 52 40kbps
0x53 (083) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 40, Route Changes: 0 NOT_RESPONDING SPECIFIC_TYPE_POWER_SWITCH_MULTILEVEL
Jasco Products RDN None 01 -> 53 100kbps
0x54 (084) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 42, Route Changes: 0 NOT_RESPONDING SPECIFIC_TYPE_POWER_SWITCH_MULTILEVEL
Jasco Products RDS None 01 -> 35 -> 54 100kbps
0x55 (085) PER: 0, RTT Avg: ms, LWR RSSI: 21dB
Neighbors: 61, Route Changes: 0 OK SPECIFIC_TYPE_POWER_SWITCH_BINARY
Jasco Products KPP None 01 -> 30 -> 55 40kbps
0x57 (087) PER: 0, RTT Avg: ms, LWR RSSI: 18dB
Neighbors: 62, Route Changes: 0 OK SPECIFIC_TYPE_POWER_SWITCH_MULTILEVEL
Jasco Products KCPD None 01 -> 23 -> 57 40kbps
0x59 (089) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 64, Route Changes: 0 NOT_RESPONDING SPECIFIC_TYPE_POWER_SWITCH_MULTILEVEL
Jasco Products FBS None 01 -> 59 40kbps
0x5A (090) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 59, Route Changes: 0 NOT_RESPONDING SPECIFIC_TYPE_POWER_SWITCH_BINARY
HomeSeer Technologies Foyer WC None 01 -> 5A 100kbps
0x5B (091) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 69, Route Changes: 0 NOT_RESPONDING SPECIFIC_TYPE_POWER_SWITCH_MULTILEVEL
Jasco Products FML None 01 -> 29 -> 25 -> 5B 40kbps
0x5C (092) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 53, Route Changes: 0 NOT_RESPONDING SPECIFIC_TYPE_POWER_SWITCH_MULTILEVEL
Jasco Products FFD None 01 -> 29 -> 25 -> 5C 40kbps
0x5D (093) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 1, Route Changes: 0 PENDING SPECIFIC_TYPE_NOTIFICATION_SENSOR None
0x5E (094) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 42, Route Changes: 0 PENDING SPECIFIC_TYPE_NOTIFICATION_SENSOR
Jasco Products Front Door Status None 01 -> 5E 100kbps
0x5F (095) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 48, Route Changes: 0 NOT_RESPONDING SPECIFIC_TYPE_POWER_SWITCH_MULTILEVEL
Jasco Products Front Bedroom Dimmer None 01 -> 5F 100kbps
0x60 (096) PER: 0, RTT Avg: ms, LWR RSSI:
Jasco Products FG3L None 01 -> 65 -> 60 40kbps
0x63 (099) PER: 0, RTT Avg: ms, LWR RSSI: 36dB
Neighbors: 61, Route Changes: 0 OK SPECIFIC_TYPE_POWER_SWITCH_MULTILEVEL
Jasco Products Middle Bedroom Dimmer None 01 -> 70 -> 25 -> 63 40kbps
0x64 (100) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 59, Route Changes: 0 OK SPECIFIC_TYPE_POWER_SWITCH_MULTILEVEL
Jasco Products FDGEL None 01 -> 18 -> 74 -> 64 40kbps
0x65 (101) PER: , RTT Avg: ms, LWR RSSI:
Neighbors: , Route Changes: OK SPECIFIC_TYPE_POWER_SWITCH_MULTILEVEL
Jasco Products DRT None 01 -> 23 -> 7E -> 65 40kbps
0x67 (103) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 1, Route Changes: 0 PENDING None
0x68 (104) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 52, Route Changes: 0 OK SPECIFIC_TYPE_POWER_SWITCH_BINARY
Jasco Products Garage side light None 01 -> 68 100kbps
0x69 (105) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 42, Route Changes: 0 OK SPECIFIC_TYPE_POWER_SWITCH_BINARY
Leviton GEF None 01 -> 69 100kbps
0x6A (106) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 36, Route Changes: 0 NOT_RESPONDING SPECIFIC_TYPE_POWER_SWITCH_BINARY
Leviton GDP None 01 -> 6A 100kbps
0x6B (107) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 55, Route Changes: 0 PENDING SPECIFIC_TYPE_NOTIFICATION_SENSOR
Ecolink Garage Entrance Door None 01 -> 6B 100kbps
0x6C (108) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 63, Route Changes: 0 NOT_RESPONDING SPECIFIC_TYPE_POWER_SWITCH_MULTILEVEL
Jasco Products Sconce None 01 -> 6C 100kbps
0x6D (109) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 51, Route Changes: 0 OK SPECIFIC_TYPE_ROUTING_SENSOR_MULTILEVEL
AEON Labs LR MS6 S0 01 -> 6F -> 7C -> 70 -> 3A -> 6D 100kbps
0x6E (110) PER: 0, RTT Avg: 3ms, LWR RSSI:
Neighbors: 29, Route Changes: 1 OK SPECIFIC_TYPE_ROUTING_SENSOR_MULTILEVEL
AEON Labs HT MS6 None 01 -> 68 -> 6E 100kbps
0x6F (111) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 47, Route Changes: 0 NOT_RESPONDING SPECIFIC_TYPE_POWER_SWITCH_MULTILEVEL
Jasco Products HT SSD None 01 -> 6F 100kbps
0x70 (112) PER: 0, RTT Avg: ms, LWR RSSI: 31dB
Neighbors: 36, Route Changes: 0 OK SPECIFIC_TYPE_POWER_SWITCH_MULTILEVEL
Jasco Products HT WB None 01 -> 70 100kbps
0x71 (113) PER: 0, RTT Avg: ms, LWR RSSI: 20dB
Jasco Products HT CS None 01 -> 71 100kbps
0x73 (115) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 27, Route Changes: 0 OK SPECIFIC_TYPE_NOTIFICATION_SENSOR
HomeSeer Technologies North Sidewalk Front facing None 01 -> 2A -> 73 100kbps
0x74 (116) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 35, Route Changes: 0 OK SPECIFIC_TYPE_NOTIFICATION_SENSOR
HomeSeer Technologies North Sidewalk Rear facing None 01 -> 74 100kbps
0x75 (117) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 15, Route Changes: 0 NOT_RESPONDING SPECIFIC_TYPE_SCENE_SWITCH_BINARY None 01 -> 75 100kbps
0x76 (118) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 22, Route Changes: 0 NOT_RESPONDING SPECIFIC_TYPE_SCENE_SWITCH_BINARY
Leviton Generic Z-Wave Switch None 01 -> 30 -> 7B -> 76 40kbps
0x77 (119) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 48, Route Changes: 0 NOT_RESPONDING SPECIFIC_TYPE_POWER_SWITCH_BINARY
Jasco Products RGL None 01 -> 34 -> 77 40kbps
0x78 (120) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 17, Route Changes: 0 OK SPECIFIC_TYPE_NOTIFICATION_SENSOR
HomeSeer Technologies Driveway Sensor None 01 -> 78 100kbps
0x79 (121) PER: 0, RTT Avg: ms, LWR RSSI: 22dB
Neighbors: 59, Route Changes: 0 OK SPECIFIC_TYPE_POWER_SWITCH_BINARY
HomeSeer Technologies RearBR EnSuite None 01 -> 79 100kbps
0x7A (122) PER: 0, RTT Avg: ms, LWR RSSI: 20dB
Neighbors: 51, Route Changes: 0 OK SPECIFIC_TYPE_POWER_SWITCH_MULTILEVEL
Jasco Products LibStor None 01 -> 7A 100kbps
0x7B (123) PER: 0, RTT Avg: ms, LWR RSSI:
Neighbors: 69, Route Changes: 0 OK SPECIFIC_TYPE_REPEATER_SLAVE_[SIC]
Aeotec Limited Range extender 1 None 01 -> 7B 100kbps
0x7C (124) PER: , RTT Avg: ms, LWR RSSI:
Neighbors: , Route Changes: OK SPECIFIC_TYPE_REPEATER_SLAVE_[SIC]
Aeotec Limited Range Extender 2 None
0x7E (126) PER: , RTT Avg: ms, LWR RSSI:
Aeotec Limited Range Extender 3 None
0x7F (127) PER: , RTT Avg: ms, LWR RSSI:
Neighbors: , Route Changes: OK SPECIFIC_TYPE_POWER_SWITCH_BINARY
Jasco Products FGO House a None
I honestly can't read that. Can you do a screen shot using Windows snip? So it looks like this
Need to know how long since the last hub reboot when those screenshots were taken?
You have a number of ghost nodes with a bunch of neighbors, were these recently force removed from the devices list?
@brwill as @jtp10181 says, you have a bunch of ghosts. You need to get rid of those to make your mesh healthy. Right now it's in bad shape.
Yes, I know, but as previously written, I am not being too successful. There was a suggestion to get a hub stick, and I mentioned that I had one, but I also have an HE C-7 in service with a single device. Can I link the two ( c7 & c8) to help get rid of the ghosts?
No... But if you have a z-wave stick, just follow this step by step
