I do not own any peanuts so I can't speak definitively on this subject.. But here is my theory..
If they are constantly dropping their routing table due to low memory.. It could be a major latency issue if it is on a main route back to your hub.. But may not cause any issues if they are on the edge of your network..
I just bought 3 for now. I put 1 of each level of my house. What I was noticing was some lights just not working causing me to either turn them off and back on OR rejoin them to the HE again. Its usually the same lights. My HE is in the basement. So let's see if these work. I also bout TRADFRI outlets that will be here tomorrow. If the PEANUTS dont work, i'll have those to try as well.
These things are awesome mesh builders.. I wish they were still being made.. Z-wave Plus and Zigbee repeaters in 1 device.. I bought a ton of these on ebay..
I know they were made specifically for Iris by Centralite.. but we should start a petition to get them to make these again..
You have one messy device list. Those devices are going to give you nothing but headache. Cree and GE bulbs are Zigbee mesh killer. Adding in the peanut plugs.......
Thanks, appreciate the support. Keep i mind that some of us just started this so we learn through trial and error as I'm sure you did. Doesn't help much calling someone's baby 'ugly' though.
You are so right. We all have devices we wish had stayed on the shelf. Before you make new purchases, it might be a good idea to check here to see if there any issues or comments. For a laugh, you might take a gander at Devices in your Drawer of Shame
I am coming from Wink2...CREE, GE bulbs....all worked fine without any issues. I would have still been with WINK if not for the company issues. I bought these bulbs years ago. I just switched to Hubitat in the past few months. Any new bulbs I purchase have been HE compatible. Sengled has worked pretty well so far. Thanks for the kind words....appreciate it.
Bulbs are fine when all they're repeating for is other bulbs. The instability issues arise when mixing bulbs on the same zigbee network as zigbee end-devices like contact & motion sensors.
Interesting. So i have seen others say get a 2nd HE. I didn't realize you could connect them...does that make them seemingless work the same and together as one? The instability issues you mentioned....what were the ones you saw? For me it was 1 or 2 light bulbs either staying on in the dashboard even though they were actually off? Having 3 lights in a set only 1 or 2 of them could be controlled...non-responsive lights causing me to have to rejoin it to the HE. Stuff like that?
@jonasd1 FYI - Sylvania === Osram. If all you have are GE and Cree bulbs, @ogiewon's solution is inexpensive and an excellent solution to the bulb instability issue .....
Ok, wait, i like this. So I'm working to reduce the CREES - i have just received some Sengled's today so now i am down to 6 CREEs. The GE link bulbs - 2 inside a ceiling fan and the other 7 are all the bigger spot lights outside. At the time I hadn't been able to find outside spot lights, so i just kept getting GE bulbs. Those fall off every now and then and I have to go back readd them. If I get the Phillips HUE, connect the CREE and GE Bulbs to it you guys are making me think this just might work!
And the Hue bridge will integrate with Hubitat bringing your bulbs into Hubitat. Just make sure you get a Hue Bridge v2 (Philips just obsoleted the v1).
