I am trying to migrate from a C5 to a C8. When I try to restore the C8 using the free cloud backup feature, I get the message "Hub failed to restore. Internal error occurred while restoring backup."
I have been able to successfully restore the C8 from a local backup, but it was not able to control any of my zigbee devices. It seems that when I restore this way, the zigbee pan ID and channel are not copied over
Has anyone encountered this issue and figured out how to fix it?
Could you please try again to load the cloud backup. If your devices aren't working after restoring the cloud backup, please send us a private message at @support_team.
The C8 seemed ready to go out of the box. I rebooted after the first restore failure. At that point it said it required a soft reset. After the soft rest, it downloaded an update. After that I tried and failed multiple times as I described above
I have one email address that contains an exclamation point in the username portion. It’s amazing how many systems choke on that, considering it’s a perfectly valid character for an email address.
I have a dot (period) in the username portion and also surprised how many systems choke on that even though its perfectly valid character for an email address.
Now that I know there's an issue with special characters in e-mail addresses, I found that changing to a different e-mail is a workaround. Changing e-mails is not as straightforward as just updating your address.
THAT WORKED!!!! I had a successful migration and the Zigbee is working. WAF was at an all-time low last night when she got home from work. I thought that changing email addresses might be a workaround but my other email address has a "." in it so wasn't sure if that was going to be a problem too. It wasn't. I went ahead and moved my 3rd hub to new email address without an "_" since I already had 2 of the hubs there. AWESOME!!!
Reset to a different email address. Issue prevails
Also, after the restore fails, the backup and restore page just hangs. Have to go into Diagnostics mode and soft reset the C8 each time
