C7 Stops running automations and will not work zWave devices
Yes, it's much more DIY than off the shelf. My goal was simply to stop all my traffic going to South Korea and not be dependent on the cloud for lights and chimes (huge house lots of doors). Cameras will still be cloud. So, I thought Hubitat, but instantly ran into the z-wave issues, then arlo support is lacking. I've been trying to configure Home Assistant with Aarlo integration, but I can't test it because the z-wave lights keep failing. Support has given me zero help, so I reached out to the forum.
It's too early for me to tell if I've had success, but you might want to get the community drivers for the z-wave devices and get off the generic ones. Next, I really had zero luck with S2 security on Zooz, so I re-attached them with no security. My thought here is that if the S2 security fails and another device is using this S2 device as a hop, it'll fail too. IDK if it's helping yet, as we've only been up a few hours, but so far everything is still working.
If this works I'll be happy. If it continues to fail I might try using ST for just z-wave (until I replace all z-wave for Zigbee devices) and use Home Assistant as an integration between the two. I will tell you though, HA is not easy to get running, so if you're not into installing Linux and configuring it, this solution might not be helpful for you.
Wait, did you ever actually get any help from Samsung? I ran ST for 2 years and got no help whatsoever. Had very good support from Zooz, Hue and ok support from Sonos. ST is so riddled with sunset support, old integrations, etc, that i used WebCore for everything, whish was slooooooooow. I really hoped Hubitat would be a fast, local alternative. I didn't expect these headaches with Z-Wave. Till now, I was toting that Z-Wave was the way to go. No more, Zigbee is so much better on HE it's laughable.
I like the Arlo/Smartthings integration and have 8 Arlo pro 2 cameras I use for monitoring and motion sensors, activating devices on both of my HE hubs. Before they integrated all their support into one group I had reasonable luck with them, though a lot of times the community sold the problem before support...
How are you getting ST and Hubitat to talk? I was thinking HA as I had zero luck getting NodeRed to work with Arlo.
Search for Hubconnect
I do wonder about the performance of running hubconnect and RuleEngine4 on Hubitat. I keep reading about performance issues, people buying a second Hubitat to run rules, etc....This is one reason I was considering Home Assistant running on a RasberryPi as a connector between the two. I'm already using the RaspberryPi for Sonos Api, Pi-Hole (everyone needs this badly) and MQTT. HA is on it and trying to get arlo events,.
I like where Hubitat is aimed at, but I do really miss how easy SmartTHings was. If only they'd have a local only option with WebCore (LocalCore maybe) fewer people would leave that platform. Or many, like me, are considering running both because of integration issues, firmware updates and general z-wave instability. OR, Hubitat could fix these z-wave issues and I'd throw ST in the bin.
Are these ZSE40 4-in-1 battery powered sensors? If so, S0 will run the batteries down very quickly and then in their dying process will stop working reliably and will adversely affect your mesh. These sensors need to be paired unsecurely, but that that is only possible by using a secondary Z-Wave controller and PC Controller software.
Indeed, the two devices I have left that have S security are a Kwikset 916 lock and the zse40 sensor. I cannot figure out how to join them with no security, but I'll keep trying if that might be an issue. I didn't think it'd destabilize the mesh because they're battery powered so other z-wave devices shouldn't connect through them. Is this not correct? The battery in the zse40 only lasts a month, but it is in the kitchen. I'm really using it for motion at night (lux) to turn on some above cabinet lighting as a night light.
Mine didn't last much more than a week when paired S0. They can impact your mesh as S0 is "chatty" and I suspect extra chatty when dying. As I said, you need a Z-Stick and PC Controller to pair them insecurely to a C7.
If you only need lux, I'd recommend Hue Zigbee motion sensors. They're about the same price as the ZSE40s from Costco. The lux reporting is much more precise as well. And they take AAA batteries.
I'm using hubconnect for HE and ST. and learning node red to offload the other HE hub with the potential (if I can figure it out enough not to bring my network down) of just using Node Red for rules, it is on its own rPi.
I forgot to add this: [RELEASE] HubConnect - Share Devices across Multiple Hubs (even SmartThings!)
Is the Release candidate for v2.0 stable? the link says that version 1x is out of development/support as of april 2020
Update: Repeater installed, custom drivers for all switches installed, zwave repair ran twice. Only a Kwikset Lock and the ZSE40 are S0 security, but I don't have a PC/Zwave stick to rejoin the ZSE40 MS without security, and the Kwikset lock seems difficult, as there are no actual Kwikset drivers. It's using a Sledge driver right now, but I'm not sure why.
So, every Z-Wave device has at least 1 other z-wave device to hop. So far nothing is using the repeater. However, every automation/switch has worked all day. So, maybe the issue I was really having wasn't signal strength, it was the S1/2 security errors and using generic drivers. I'll check in again after a few days to let everyone know if I'm still having z-wave issues.
Again, thank you to everyone on this forum for their help. No thank you to Hubitat support as they were of absolutely no help, really on par with SmartThings there. Very disappointing, but you all stepped up and offered great advice. So, again, Thank you!
i converted all my kwikset 912 914 916 to zigbee. i just bought used other locks or the amazon kits and pulled the cards out and added to the locks.. they work much much better now on zigbee.
I installed V 2.0 RC2 on ST and the hub and it seems to work as advertised. I had an issue with an error message on my second C2 and my Server C7 so I've taken it off the client till I get the zWave sorted out.
It will take a while for the devices to find the repeaters and use them consistently assuming that it's actually a better path for them and there are actually mesh issues to begin with.
ya i wish we could but route hints in. As you say if there are no mesh issues. ie its taking one or two hops and you get .6 -.8 sec times it wont automatically switch even though the better route takes half the time.. Ive gotten some to switch to using the repeater by using node level repair a few times.. and now at least it seems to be sticking.
Well, I don't know if it was the generic drivers or the S security messing with my z-wave, but things are much better now. 1 device shows 9.6kbs, 1 shows 40 kbs and the rest are all 100. Devices not in the same room as the hub have 2 or 3 hops, none using the repeater yet. But, the great news is, I woke up and all z-wave devices are still working, regardless of what the z-wave details section shows.
As for the lock, it seems to be working even though it's S0. I don't mess with the digital keys, we only use a code or unlock/lock from the dashboard, so I don't know if all the features are ok.
Just throwing in my issue as well to this thread - will contact support shortly. Very few application running on the C7 since all of my automation has been moved to NR. Roughly 80 ZWave devies on the network with most being GE dimmer or fan switches. Constantly losing control, for weeks, of random ZWave switches. Reboot seems to fix it for anywhere from an hour to a day.
Looking at the routing there are no common devices in the path and when the devices stop responding the logs no longer register any events for the device when I attempt to turn it on or off from the Hubitat GUI. My dining room GE switch, as an example, is no longer responding and shows a last update time of 9:30pm last night. Went years and never had this kind of issue with ST.
Rebooted the hub while writing this and now everything is working perfectly. Also noticed that my ZWave stick I use with Z-Wave PC controller to validate routing and health was showing as "OK" in the ZWave settings section even after doing a refresh and repair. It's showing exactly the same after the reboot. It's been unplugged for almost 24 hours.
I wonder if anyone without GE switches/dimmers is having these problems. It seems to be a common element.
