Updated zwave shown above. All ghosts removed.
Why do I have theses ghosts?
Do I have to reinstall or can I update from s0 to None
Because of failed pairings.
If you go to the device page and click on/off is it reflected in the attributes? If not, what driver is it using?
Please read this since you are new to hubitat
Not new to zWave I had 3 Vera hubs for over 10 years on two sites. They worked fine. They died of old age and I was recommended Hubitat.
I have not been able to get it to work properly.
I still have 1 Veraplus hub working and I am dreading it dying.
These are on different sites so no interference etc.
They all work sometimes but quite often I get the egg timer and they won't switch.
This is one of the new modules. It won't switch even from the device list at the moment.
Whats the make/model of the plug?
The plug is now working. Two above have now decided not to work.
The main modules I have are Fibaro Double switch FGS 223 (new ones)
and Fibaro Double switch FGS 221.
Use these drivers [as those aren't on the compatibility list...]
Thank you.
Have you updated your hub’s zwave radio firmware? This update is separate from hub platform updates.
No I don’t have that button.
That means it's updated.
Oh if the configure button is there after you install those drivers click it...
