They are the drivers I have used when I first installed them..
Hmm... Not sure then... They're not on the official list of supported devices. You may want to post in the author's thread.
I'm sorry I haven't kept track of this thread in detail. But have you excluded these devices and re-included them with no security? As at @rlithgow1 mentioned, S0 uses three times the amount of traffic as no security. For devices that report power, this increased traffic can be debilitating to a network.
Is there any other way apart from excluding and including?
No. And if it cabt pair without security then you need a stick to do it
Do you have any secondary hand-held controller, like an Aeotec Minimote? That can also be used to easily include an S0 device with no security.
This is less work than setting up PC Controller and a USB zwave stick as a secondary controller.
on the hub. if you go to settings -> z-wave details, on the top will be some buttons. if you have a firmware update button, that means you do not have the latest z-wave firmware on your hub
As already shown above this update was done a while ago.
