@bravenel
Since the last update, scenes do not show any newly added devices to add to an already existing scene. Groups show the new devices, but not scenes.
Edit: also renaming a device does not show the new name in the list of devices in a scene.
Doing something wrong or a bug?
Another edit: I rebooted the hub, waited 5-10 minutes and it seems everything works now. Leaving this message here in case others see the same thing. Apparently, it just takes a while for things to trickle through.
It happens to me also. A new device does not show so that it can be selected in a scene, and in some of the other apps like Alexa. You have to go in and out a few times, or reboot the Hubitat and then it appears.
I'm seeing a similar issue, except that no devices in the scene are selected in the dropdown menu. That is, when i go into a scene to edit it, the dropdown menus have no items selected in them. Not sure what to do with that...Hitting "Done" as suggested here doesn't populate them the next time into the scene.
